accelerator pump not working - The Jockey Journal Board
Old 02-28-2019, 07:48 PM   #1
55panman
Default accelerator pump not working
got a super e and i cant get the pump to squirt fuel no matter where i set the screw but when i pull the bowl and actuate the pump by pushing on the rod it will squirt. so what am i missing here
55panman is offline   Reply With Quote
Old 03-01-2019, 01:44 AM   #2
Default Re: accelerator pump not working
Spring under the diaphram might be missing or rotted. The fuel is holding it up enough to manually squirt but diaphram by itself cant push the rod up enough to be operated by the linkage.
I have one now suffering from the same. The linkage moves, but the rod is already pushed down. If I lift up the linkage with a small screwdriver. I can push the rod down and it squirts a little.
I dont know if Im making sense.
Old 03-01-2019, 02:21 AM   #3
55panman
yup your making sense i also tried moving the rod with a screwdriver and was solid also the rod is a little bent but thought that would not be an issue. guess a pump kit is in order. thanx for the tip
Old 03-02-2019, 12:39 AM   #4
The rod might be frozen also. I had one do that after sitting for a few. Straighten it out also. The hole is pretty forgiving but still, it needs to be straightish.
Old 03-02-2019, 08:32 AM   #5
Armand
I just rebuilt an s and s and had the same symptom. I turned out I had reversed the spring and diaphragm. I canít remember now but I had put the spring over the diaphragm rather than under it. Or maybe visa versa.
Could that be possible in your case?
Armand is online now   Reply With Quote
Old 03-02-2019, 02:54 PM   #6
55panman
that could be a possibility carb is not very old and not alot of miles on it cant see worn parts being the issue don't think the pump worked from day one will pull it apart and check your suggestion but leaning towards a weak spring a this point
Old 03-03-2019, 08:28 AM   #7
Armand
The prob for me was working upside down to the picture in the manual.
Similar Threads
Working on a 47 knuck S.T.P. The Board 19 02-10-2014 05:32 AM
"The Case for Working With Your Hands" Parallel Twin Universe The Board 23 05-28-2009 08:02 PM
Need someone with good quality wood working skills Soulfur The Board 10 11-18-2008 07:29 PM
working on this at my new job! squigy The Board 9 07-17-2006 08:16 PM
working on the sporty....... LUKESTER The Board 12 12-20-2005 10:58 AM
