Left twist drill bits? - The Jockey Journal Board
Old 12-26-2014, 07:44 PM   #1
Mike Britton
Mike Britton's Avatar
Default Left twist drill bits?
So I pulled off my Bonnie's primary cover and discovered a bolt on the bottom that has broken itself off. It's too flush with the case to back out with vice grips.
I hear you guys talk about left twist drill bits, where do I get such things?
Also, I have three primary holes that that are broken out. Can I build them up with JB weld and tap them, or will I have to split the cases and have them tig'ed up?
Thanks, Mike
Old 12-26-2014, 08:09 PM   #2
ob1quixote
ob1quixote's Avatar
Default Re: Left twist drill bits?
Here they are at Amazon!
Amazon Amazon
ob1quixote is offline   Reply With Quote
Old 12-26-2014, 08:25 PM   #3
Mike Britton
^^^^Cool! Thanks, ob1q !!
Old 12-26-2014, 08:51 PM   #4
flatman
drop a nut on it and mig or arc that sucker on. might take a time ot two to do but usually works 80% of the time, my 2 cents
flatman is offline   Reply With Quote
Old 12-26-2014, 09:56 PM   #5
JAWS
JAWS's Avatar
^^^ ditto! Done it like this for years. BMW rear water passage bolts on the O T v8's no other way to fly.
Also, tighten first then back out. This will help since it bound and broke when removing. Dont get discouraged when the welds dont hold a few times. A hand full of nuts..
Old 12-26-2014, 10:06 PM   #6
old.wrench
old.wrench's Avatar
Mike,
I've never found any type of epoxy thread repair that will take any substantial torque. That includes the stuff like the "locktite thread repair" crap, and JB weld.
Geo.
"it ain't rocket surgery"
"hony swacky mally asbestos"
Old 12-26-2014, 10:13 PM   #7
johnbul
all of this.
"My trailer queens are usually covered with mud and bugs" I said that. Early Bultaco parts wanted. Custom, resto work 39 years in Iowa. John Worden Alliance Member on the H.A.M.B. Thumbs up!
johnbul is offline   Reply With Quote
Old 12-27-2014, 01:52 AM   #8
Tony the torch
Tony the torch's Avatar
I have a set of reverse drill bits from the Snap-on truck, most times all it takes to get a broken off bolt out is to just drill on it with a reverse cut bit and it comes right out.
if that doesn't work then, yes....put a nut on it and mig weld it...
Old 12-27-2014, 02:08 AM   #9
Toolmkr
Left hand twist drills are commonly available at any industrial tool supply house. They are sometimes known as screw machine drills.
Toolmkr is offline   Reply With Quote
Old 12-27-2014, 03:12 AM   #10
'59
I know the reverse drill bits as easy outs, find them very brittle so check they are started dead square, the mig on a nut has got to be one of the best tips I've picked up from JJ and if you have access and kit i'd go for that as 1st option.
Old 12-27-2014, 05:30 AM   #11
Rem
Rem's Avatar
Welding a washer and/or nut to the broken stud is my favourite method, and I have a pretty good success rate. It probably would have been a 100% success but I had one recently where a couple of M6 exhaust studs had been broken in a 750 Kwak: one came out OK but all that came out of the second one was the end of the EZ-Out that the owner had broken off in there
Rem is offline   Reply With Quote
Old 12-27-2014, 07:24 AM   #12
Mike Britton
I'm in the process of readying the engine lump to go on one of Steve's stands on the work bench. That was why the primary cover was coming off, to trim some weight by removing the whole clutch assembly so I could pick the lump up. The head has to come off for thread repair, and I have to address these broken out holes on the primary side. I'm going to find a pro to TIG the holes back up for me, I'll get him to flush out the broken bolt.
Add to this that I still haven't gotten the oil drain bolt out of the bottom of the case. It's really in there!
One of the things I learned from my dad was to never be ashamed to go to a pro when you are above your head. The more I hear from you guys, the more I think I'm over my head on removing this bolt.
I can assemble an engine, I'm not a machinist. Nothing that can't be repaired, just more money. Thanks, guys. I'm kind of thinking like a doctor here," First, do no harm."
Guess I can't complain considering what I paid for a running Bonnie with good papers.
Never done a Triumph engine. I'm looking forward to the process. Thanks again. Mike
Old 12-28-2014, 12:07 AM   #13
thecarfarmer
thecarfarmer's Avatar
Originally Posted by Mike Britton View Post
...One of the things I learned from my dad was to never be ashamed to go to a pro when you are above your head. The more I hear from you guys, the more I think I'm over my head on removing this bolt.
Yeah, my first year as a mechanic taught me to ask questions... a lot more shameful to screw something up because I get my ego involved than to go to someone who's fought that particular fight before!
Bill
https://www.jockeyjournal.com/forum /image.php?type=sigpic&userid=1027&dateline=1297737  445
gabacho por vida
thecarfarmer is offline   Reply With Quote
Old 12-28-2014, 12:58 AM   #14
Daddy Boy
I did the weld a nut trick at work and even though the nut was new it still has lubricant or zinc, drill off the threads and clean surface of broken stud/bolt for a 'first time' weld fusion.
Old 12-28-2014, 08:23 AM   #15
76shuvlinoff
Back in the day (factory maintenance here) there was a high tensile low splatter stick rod that we used to get broken studs out. Set a nut on it then build a stud up into the nut with the rod. I have not used or seen it for years but at the time the stuff was priceless for pieces that were too big to get into a drill press or mill. A lot of times we could just build a tit up on the stud and grab it with vise grips.
Nowadays y'all got fancy MIG welders and nuclear ovens and shit...
76shuvlinoff is offline   Reply With Quote
Old 12-29-2014, 09:05 PM   #16
Racepres
Racepres's Avatar
7018 or 7024?? or Something exotic??
Good info to have.
Edit;
Especially since I aint got no IG [m nor T], and my "special" oven has blowed a fuse apparrently!!!!!
If it Aint a H-D and it Aint from '66 to '84
I might be Guessing!!!
Racepres is offline   Reply With Quote
Old 12-29-2014, 10:37 PM   #17
Unkl Ian
Unkl Ian's Avatar
Location: Just past the corner of Hell and The Twilight Zone.
If you try arc or MIG, use liquid soap as an anti-spatter barrier.
Works well, washes off with water.
FlyingEyeballs.net
Unkl Ian is offline   Reply With Quote
Old 12-30-2014, 07:20 AM   #18
Mike Britton
I'm using a Lincoln 3200 HD, and because I'm the laziest guy I know, I'm using flux wire with no gas. Also, because I'm the laziest guy I know, many times my weld surfaces could be cleaner. But because I've been using Hobart 770075 Anti Spatter,even my booger welds don't have much spatter. Stuff looks like Pam, but it works, even spatter on chrome wipes off, no problem.
Old 12-30-2014, 08:53 AM   #19
Tony the torch
it is Pam, and Pam works great as an anti-splatter spray
Old 12-30-2014, 09:34 AM   #20
JAWS
JAWS's Avatar
Pam? Really? I just learned something... Thanks!!!!!!!!
