Triumph cylinder block before/after - The Jockey Journal Board
Old 08-26-2013, 09:26 AM   #1
Tre900
Default Triumph cylinder block before/after
Hit the parts washer and some High temp grill rattle can paint and I like how its looking.
I think I'll do another coat, but I'm wondering if someone can tell me what that screw is (Red arrow) for??
Name:	Cylinder block Before.jpg
ID:	102217   Click image for larger version
Name:	Cylinder block after.jpg
Tre900
_
(_)=='(_)
Tre900 is offline   Reply With Quote
Old 08-26-2013, 09:45 AM   #2
Rem
Rem's Avatar
Default Re: Triumph cylinder block before/after
That looks like the impression from one of the screws used on the original pattern to make the mold. It isn't actually a screw, just looks like it.
Rem is offline   Reply With Quote
Old 08-26-2013, 10:06 AM   #3
Jack Adams
Jack Adams's Avatar
I believe it is a " Idiot gauge",if you find one that the screw slot is buggered up,there has been an idiot afoot,so check out all the parts really well. Jack
Jack Adams is offline   Reply With Quote
Old 08-26-2013, 10:07 AM   #4
Quaffmeister
Quaffmeister's Avatar
Yep one of the screw heads that held the letter tag to the original wooden pattern.
If a thing's worth doin', it's worth doin' to excess
www.britishironworks.com
The Alloy 500 Triumph Site
Quaffmeister is offline   Reply With Quote
Old 08-26-2013, 11:02 AM   #5
Tre900
Thanks folks!!
Tre900
_
(_)=='(_)
Old 08-26-2013, 11:47 AM   #6
drainsurgeon
drainsurgeon's Avatar
Looks good. Hi-Temp grill paint? I'll have to remember that. I like it.
drainsurgeon is offline   Reply With Quote
Old 08-26-2013, 02:05 PM   #7
old.wrench
old.wrench's Avatar
This made me crack up !
"it ain't rocket surgery"
"hony swacky mally asbestos"
Old 08-26-2013, 03:02 PM   #8
vintagespeed
there was an oil passage to the tappet block on some unit cylinders that you might want to look into. (it's not anything with that "screw" head) you'll need to block this passage either in the head or the case depending on what year tappet block & cylinder combination you're using.
just something to look into. i think it was pre-65 cylinder with a '66 later case.
-jb
that's JunkBitch to you.
vintagespeed is offline   Reply With Quote
Old 08-26-2013, 04:15 PM   #9
Tre900
Good looking out! I've got a 68 bottom end but I don't recall which of my baskets this block was off (could be a 65. I picked up some tappet blocks but those are new in the bag and have a part number so I should be able to ID those.
Thanks!!
Tre900
_
(_)=='(_)
Old 08-26-2013, 04:17 PM   #10
Tre900
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
Tre900
_
(_)=='(_)
Old 08-26-2013, 11:37 PM   #11
RetroRob
RetroRob's Avatar
The BBQ paint works well on headers too
RetroRob is offline   Reply With Quote
Old 08-30-2013, 07:01 AM   #12
Tre900
Here's a couple more shots after I got my BRM Flex hone (dingleberry) in the mail. Final product, first pass, and how it started.
Name:	after flex hone.jpg
ID:	102626   Click image for larger version
ID:	102634   Click image for larger version
Tre900
_
(_)=='(_)
