seize? - The Jockey Journal Board
Old 04-29-2013, 11:18 AM   #1
newtriumph
Default seize?
Greetings- Newbie here of a few days (to the bb and 1.5 weeks to my '69 Triumph T100)
I took it out yesterday and when I hit about 75KPH I felt a slight tugging (almost like the gas was not flowing properly). I increased the throttle and felt/heard a pull- suddenly I lost power and the engine shut off almost immediately (stopped running). When I pulled it over- i tried to kick it started and the kick was seized. A bit later I was getting towed and we gently pulled it into gear. This "unfroze" the kick but now when I try to start it and kick it I get a loose compression noise(see this link for a video) . I noticed that my throttle ring on my handlebars had been turned upside down and of course the cable was very loose- both at the ring on the bars and where it leads into the corroborator. Wondering what happened and what do I do?
I also noticed that my battery (of 1.5wks) was a bit expanded or swelled. Dunno if this is connected.
newtriumph is offline   Reply With Quote
Old 04-29-2013, 11:20 AM   #2
Dr. Benway
Mod Squad
Dr. Benway's Avatar
Default Re: seize?
I wouldn't kick that over anymore until you pulled the head and had a peek in there...
Old 04-29-2013, 11:31 AM   #3
BSA Nut
BSA Nut's Avatar
Default Re: seize?
Sounds like a seize. You need to find out why, as well as how much damage it did. As Benway stated- don't kick it anymore, til you look inside.
BSA Nut is offline   Reply With Quote
Old 04-29-2013, 11:36 AM   #4
buckman50
buckman50's Avatar
Default Re: seize?
Hole a piston, perhaps?
buckman50 is offline   Reply With Quote
Old 04-29-2013, 11:38 AM   #5
newtriumph
Default Re: seize?
What should I open and what am I looking for?
Old 04-29-2013, 11:39 AM   #6
Nottso
Nottso's Avatar
Default Re: seize?
Listen to the man. He's a doctor. The video made me cringe.
Welcome to the Church Of The Holy Cabbage. Lettuce pray.
For small, extremely clean, remote oil filters please see my new Jock Shop.
Nottso is offline   Reply With Quote
Old 04-29-2013, 11:40 AM   #7
Dr. Benway
Mod Squad
Dr. Benway's Avatar
Default Re: seize?
Short version? Shit sounds broken. Take off the cylinder head and peer in there. If it's what we suspect, it will be obvious. If not, take pics and post them here.
Old 04-29-2013, 11:44 AM   #8
newtriumph
Default Re: seize?
This has actually been sitting for years
I'm going to open it up (gulp) and see what's up. Sorry to be so rudimentary but anything I should do or be careful of when removing this?
Thanks all
Old 04-29-2013, 11:46 AM   #9
buckman50
buckman50's Avatar
Default Re: seize?
For starters, pull the spark plugs and shine a light into the cylinders to see if you can see any carnage on the piston tops, if at all.
Old 04-29-2013, 11:48 AM   #10
Dr. Benway
Mod Squad
Dr. Benway's Avatar
Default Re: seize?
Originally Posted by Dragstews View Post
Yeah....
That locked up at speed....
I have a wonder on if this motor just had a fresh bore job done to it (new Pistons)...???
Personally, my guess is he's about to learn how important a clean sludge trap is.
Old 04-29-2013, 12:08 PM   #11
buckman50
buckman50's Avatar
Default Re: seize?
+1 on that.
And...never trust a "sitting" bike.
Old 04-29-2013, 12:23 PM   #12
newtriumph
Default Re: seize?
hmm.. thanks
Old 04-29-2013, 12:48 PM   #13
little d
little d's Avatar
Default Re: seize?
Newtriumph,
I'm picking up that your new to wrenching on motors....If I'm correct, STOP....
Do a search on here and find a manual, read this cover to cover and reread it untill you know it pretty damn good.
Now, with this knowledge, take your time and start the disassemble. Get yourself some of the zip lock sandwich bags and as your taking things off, bag them and mark what is what. If you have questions as to if a part is good or not, post a pic on here and someone will tell ya. Theres a wealth of knowlege on here, use it. Good luck.
Old 04-29-2013, 12:51 PM   #14
newtriumph
Default Re: seize?
Thank you for the constructive advice- Im already deep in the Haynes Manual...any other suggestions?
Old 04-29-2013, 01:17 PM   #15
newtriumph
Default Re: seize?
Oh and what is the suggested motor oil type?
Old 04-29-2013, 01:28 PM   #16
JAWS
JAWS's Avatar
Default Re: seize?
Originally Posted by little d View Post
Newtriumph,
Great advice D.
The others have said excellent comments also.
Please take your time and inspect everything closely. Most problems can be found with a good visual inspection combined with the understanding of how each component and why each component works.
Study and ask questions, take pictures of it assembled and as you remove each piece. Remove big pieces, like the head. Set it aside and remove the next. Then inspect and disassemble the big pieces, one at a time.
I cover my bench with white butcher paper and lay it out like the exploded view in the assembly manuals. Small parts have a harder time missing that way.
I know it sounds tedious, but for the first time getting into one of these, you will be grateful you took extra care, when it goes back together.
Old 04-29-2013, 01:35 PM   #17
newtriumph
Default Re: seize?
Thanks
Great advice all around... Here we go
Btw what type of motor oil is preferred?
Old 04-29-2013, 02:08 PM   #18
gearhead1951
Default Re: seize?
www.classicbike.biz/triumph/triumph/htm is a good resource it is not the absolute best but its a freebie till you can add to your library !
And even giving my previous comment , this IS a good place to start !!
gearhead1951 is offline   Reply With Quote
Old 04-29-2013, 02:18 PM   #19
gearhead1951
Default Re: seize?
OK , I cant get that link to work at all from here !!??
But you can copy/paste to the google search bar and it will pull it up !!
Old 04-29-2013, 02:24 PM   #20
newtriumph
Default Re: seize?
thanks got it
