Left twist drill bits? - Page 2 - The Jockey Journal Board
Old 12-30-2014, 09:50 AM   #21
drainsurgeon
drainsurgeon's Avatar
Default Re: Left twist drill bits?
Originally Posted by Tony the torch View Post
it is Pam, and Pam works great as an anti-splatter spray
I just tried Pam a couple of days ago on my welding table. All those little itty bitty splatter balls just roll away. Clean up with a paper towel. I sprayed the inside of my MiG nozzle and had the same effect. Just remember to keep that can of Pam FAR AWAY from where you're welding. Boom!
drainsurgeon is offline   Reply With Quote
Old 12-30-2014, 10:01 AM   #22
conn.rod
I bought some left hand drill bits at harbor freight,they were not expensive,I have been using them at work and they hold up well,I think a 13 pc set was like 19 bucks.Drill slow and use a small amount of oil to cool,once the bit catches a good piece of carbon,the broken bolt most times spins right out of the hole.Also you can heat it slightly and melt a candle over the broken stud,the fat from the candle gets into the threads and helps to loosen it
conn.rod is offline   Reply With Quote
Old 12-30-2014, 10:01 AM   #23
Pam also works great for all your Christmas cookies...they just slide right off the cookie pan.
....oh !....wrong forum
Old 12-30-2014, 11:02 AM   #24
Mike Britton
Mike Britton's Avatar
^^^^^ Don't ya just love the JJ ??
Pay no attention to the garage!! My best work comes from chaos!!
Mike Britton is offline   Reply With Quote
