Right Tool for the Job type Question - The Jockey Journal Board
Old 06-19-2010, 10:33 PM   #1
A.J.
A.J.'s Avatar
Default Right Tool for the Job type Question
Base gasket blew the other day on my FXR. Figured since I have it apart I'll hop up the hp while I'm inside, Pistons, Cam, Valves etc.
Can anybody recommend a specific brand/tool for pulling and reinstalling the press fit wrist pins? Perhaps what brands to Avoid?
I'm hoping to avoid taking the whole engine to the machine shop. Seems everyone around here is booked up solid for the next few weeks.
www.HouseofChop.blogspot.com
A.J. is offline   Reply With Quote
Old 06-19-2010, 11:45 PM   #2
Destralo Roach
Moderator
Destralo Roach's Avatar
Default Re: Right Tool for the Job type Question
All ya gotta do is use a hammer and a drift, they will come out...Roach.
Wisco.
Old 06-20-2010, 12:06 AM   #3
dan r
dan r's Avatar
harley wrist pins are not a press fit, they float in the piston and the rod.
the clips do hammer the grooves in the pistons and will raise a burr.
pack clean rags around the rods in the cases, remove all of the clips, with an exacto knife or the like remove a sliver of piston material all the way around the groove at the clip location.
after that a light tap on the end of the pin and they should slide out.
be sure to support the piston when tapping out the pin, don't side load the rod.
Last edited by dan r; 06-20-2010 at 12:08 AM. Reason: edited cause my spellin sucks
Old 06-20-2010, 12:15 AM   #4
dinuns1
Get a piece of brass 1'' od , have about 1/4'' of it turned down to .794 thats to fit in the Wristpin then have about 1.25 or a little longer than the width of the rod , turnedown to match the outside of the wrist pin but no big enough to ''grab'' the rod i think .801 will work and hammer out said wristpin .
dinuns1 is offline   Reply With Quote
Old 06-20-2010, 12:43 AM   #5
A.J.
A.J.'s Avatar
Thanks for the help guys... I'll try my luck in the morning and let you know how it comes out.
engine repair, tools
