Triumph Picture Thread - Page 63 - The Jockey Journal Board
Old 04-03-2019, 07:43 PM   #1241
Crettbook
Crettbook's Avatar
Hi there, here’s my ‘59 chopper, I bought it generally like this in 2016, changed the bars and the tank and pipes and stuff but she’s mostly how I got her. Chopped in the 70’s or maybe 80’s? Was running Saturday morning and was broke by sat night, but I’m working on it!
Crettbook is offline   Reply With Quote
Old 04-03-2019, 08:45 PM   #1242
Default Re: Triumph Picture Thread
Bike looks good Crettbook!
Old 04-04-2019, 10:09 AM   #1243
Tricky-Ricky
Tricky-Ricky's Avatar
Here is what i believe to be one of a very few Trident T160 chops left in one piece in the UK it had been stored for the last 30 years until i rebuilt it in 2017.
Tricky-Ricky is offline   Reply With Quote
Old 04-13-2019, 05:49 PM   #1244
78bandit
78bandit's Avatar
That thing is sweet!
78bandit is offline   Reply With Quote
Old 04-14-2019, 01:49 PM   #1245
Mean as tiger piss!
Old 06-20-2019, 05:35 PM   #1246
Just Passin' Thru...
That bates desert sled seat ended up on my 750, it could use some new padding, maybe something to do during the winter.... here is a pic.
Old 08-26-2019, 11:39 AM   #1247
Der Henning
Der Henning's Avatar
My 60 5TA southbound and down in Croatia this Summer!
Der Henning is offline   Reply With Quote
Old 08-30-2019, 12:49 PM   #1248
Teesechs
Teesechs's Avatar
Very nice bikes are in here! This is my T6 from 1954. I don't need another
ID:	255322   Click image for larger version
Teesechs is offline   Reply With Quote
Old 08-30-2019, 01:15 PM   #1249
I like it. My kind o' motorcycle!
Old 08-31-2019, 07:11 AM   #1250
Teesechs
Teesechs's Avatar
Thnx😊
Old 08-31-2019, 05:12 PM   #1251
Der Henning
@Teesechs: Where do you live? I'm from Husum. Nice bike!
Old 09-01-2019, 06:15 AM   #1252
Teesechs
Teesechs's Avatar
Wohne kurz vor Flensburg. Danke für die Blumen)
Old 09-01-2019, 06:22 AM   #1253
Teesechs
Teesechs's Avatar
@ Der Henning: very cooles Rücklicht you have!
Old 09-01-2019, 08:46 AM   #1254
Tees, Der, both gorgeous bikes! ++
Old 02-05-2020, 05:40 AM   #1255
Pic is from an Englishman's site (British Iron), but I think I saw the word "Japan" in the caption. Does anybody recognize it? The photo is at least five years old.
Name:	Somebody's swingarm Triumph.jpg
Old 02-05-2020, 09:58 AM   #1256
Elektron
Guessing you're asking for more-info on it from someone who knows it? That's a very practical bike, from the looks of it, though I'd want a front brake instead of a spool hub. That's the kind-of bike that you can ride and it won't wear you out because of crappy suspension. Unit construction twin-carb from what I can see, very clean. Looks to-be a 21" front hoop?
Elektron is offline   Reply With Quote
Old 02-05-2020, 11:02 AM   #1257
Pre-unit with a nine-bolt (unit) head. I absolutely agree about the rideability and the dearth of front brake. Spools look great but you have to shape your riding style around them, i.e. beginning to slow down a longer distance from upcoming corners. Not to even bother with the safety argument. (We are preaching to the choir here.)
Old 02-05-2020, 05:31 PM   #1258
Elektron
From the primary side, and with the later cyl head, I took a guess on it being a unit-construction, I wouldn't know how to differentiate from the view, unless I saw the right side.
One of the domestic magazines used a novice, an experienced rider and an Expert-class roadracer, on identical bikes, hell, maybe even the same bike, I don't exactly-recall. They went to the testing grounds and conducted a series of braking exercises. It was something like rear brake only, front and rear brakes together, then maybe a panic stop. All done at several speeds. Of course the novice's results were much-farther than the other two. The surprising part was that the novice's 'rear-brake only' efforts were hundreds of feet further at the higher speed tested.
The way people around here behave (speaking of where I live), I want all the equipment to do the best job it can, protecting me until that "oh SH_T!" moment that's going to keep you out of the hospital.
Old 02-05-2020, 10:18 PM   #1259
Thunderbird
so with a 9 stud head that has push in header pipes, which model pipes are they then with the kink under the primary cover?
Thunderbird is offline   Reply With Quote
Old 02-06-2020, 12:50 AM   #1260
My mistake! That's a <1963 head, i.e., eight-bolt. The rocker boxes looked at first like the later, more extensively finned ones that fit the nine-bolt.
