HD (probably sportster) frontend specs? - The Jockey Journal Board
Old 05-01-2009, 10:16 AM   #1
JLeather
JLeather's Avatar
Default HD (probably sportster) frontend specs?
Got an aftermarket frame I'm mocking up in my garage at the moment and trying to figure out what neck it's got. I believe it's a sporty neck cause it's 6 7/8 long. it's not the removable bearing-cup style, it's just one piece of tube with a tapered race pressed in at each end. What HD frontends fit it (bikes and year-ranges)? I'm not up on which ones had what length stems and all?
Second question, since I think it's a sporty frontend. I need a frontend that's about 33.5" from the top of the tube to the axle. What is the stock-length of a sporty tube frontend so I know how much over-stock I need? I'd prefer to run a later-model dual-disc setup with a spoke front wheel (like an early 80's IH frontend) if it's gonna fit. Thanks guys, and pardon my ignorance on stock HD parts.
JLeather is offline   Reply With Quote
Old 05-01-2009, 12:46 PM   #2
Canadian_Bagger
Canadian_Bagger's Avatar
Send a message via MSN to Canadian_Bagger
Default Re: HD (probably sportster) frontend specs?
Are any numbers stamped into the parts?
Canadian_Bagger is offline   Reply With Quote
Old 05-01-2009, 01:54 PM   #3
Destralo Roach
Moderator
Destralo Roach's Avatar
He just has the frame, need's info on what front end to use, I would say 35mm would work, any year, but the dual disc was from 78-82 after you get one for about $250 then you can see if you need to lower the front or get new shorter tubes....................
Old 05-01-2009, 05:27 PM   #4
Canadian_Bagger
Duh, that is what I get for talking a day off work. My brain shuts down.
What is the berring cup diameter, or can you see a part number on the edge of cup?
My wife's sporty is an 88 and it has a 7" neck so as far as neck length you should be good getting a front end up to 91. That does not account for the internal bearing size.
Old 05-01-2009, 05:53 PM   #5
Destralo Roach
Moderator
The last front end that will work on the shorter neck is 1981, the 82-03 will fit a big twin bolt on, the shorter wont.....Roach.
Old 05-01-2009, 09:14 PM   #6
JLeather
JLeather's Avatar
Ah-ha. See, that's what I needed to know since I don't have any HD frontends in my stash. A sporty frontend up to '81.
Now, to further complicate matters, what if I wanted a 39mm frontend? A wide-glide is too wide for this bike, but isn't there some kind of mid-glide in between that and a narrow-glide? Are there any years of those that would fit, or would I have to get sporty wide-glide conversion trees to do it?
Old 05-01-2009, 10:21 PM   #7
Irish Rich
Irish Rich's Avatar
Don't get all fucking confused here, and make things more complicated than they are. It would have saved a lot of guesses if you'd have at least given the frame manufacturer, or a picture of the neck itself would have sure helped.
The neck you probably have is the FLT/FXR/late Softail style, that doesn't have seperate neck cups. Aftermarket frame manufacturers have been doing this style neck for a long time.
The races you probably have installed in the neck right now are probably Timkin #L 44610. Drop a set of Timkin neck bearings #L 44643 in your neck, and run any H-D 1" stem front end you want to. Trust me.
Irish Rich is offline   Reply With Quote
Old 05-02-2009, 06:39 AM   #8
JLeather
JLeather's Avatar
The neck is on an Amen frame made in the late 70's. I'll snag a pic of it when I get a chance. The races in it came that way when I bought it, so I don't know if there are any numbers on it or not.
Old 05-02-2009, 08:42 AM   #9
Destralo Roach
Moderator
And like I said, the neck is set up for the 35mm sporty neck, the bigtwinn neck witch I went out and mesured on my shovel and a roadking(dont use the reversed triple tree geomitry of the RK for reference) that is in my garage right now was 7" from flang to flang, the Ironhead sporty 52-81 uses the slightly shorter neck...........you can use the 39mm but make shure that you can slide a 1" neckstem in your frame, you would have to use a spacer ON TOP to make it work bolt on, never space your tripletree on the bottom!!
.........................................Roach.
