49 triumph bobber rebuild - Page 13 - The Jockey Journal Board
Old 09-07-2015, 04:50 PM   #241
Lester
Lester's Avatar
Default Re: 49 triumph bobber rebuild
You need to know what type of steel it is,, if low carbor you will need to case harden
Lester
'62 DuoGlide Mine for 25yrs
'62 Triumph T-Bird in boxes
'83 BMW R100 commuter
'80's couple of Jap chops too
Old 09-08-2015, 10:54 AM   #242
SxExCx
I'm digging the color and stance.
SxExCx is offline   Reply With Quote
Old 09-08-2015, 03:42 PM   #243
richbob
richbob's Avatar
yea so i heat cherry red then heat again to blue then rest on some thing cold
belt is BnR
Old 09-08-2015, 05:43 PM   #244
Nobey
Nobey's Avatar
Sweet little bike richbob. My first Triumph was a 49 with a 1956 6T engine.
Nobey is offline   Reply With Quote
Old 09-08-2015, 08:14 PM   #245
Ratso
Ratso's Avatar
Absolutely beautiful bike. Is the tinware a muted green, like Francis Beart's old Nortons, or a more intense color as suggested in the later photographs? (Might be my old computer reading the color inexactly).
Old 09-12-2015, 01:39 AM   #246
richbob
richbob's Avatar
Cheers for the compliments.
Green is like pastel not blingy like in professional pics.(photo mate has some funky settings makes everything pop)
My pushrod end came off with like an oil suction pop maybe this was cause of tappet wear?
Should have it buttoned up today.
Old 12-18-2015, 12:55 PM   #247
Dan Boy
Dan Boy's Avatar
Hell, those carbs have a splay on them like a French tarts legs!
Blown Triple Build
Old 12-19-2015, 04:14 AM   #248
croucho
You did an awesome job on that bike Rich... It was a pleasure viewing it all. Brought back some good memories from when I did mine... Thanks for sharing.
croucho is offline   Reply With Quote
Old 12-29-2015, 12:06 AM   #249
Lowsprung
Beautiful bike!
Lowsprung is offline   Reply With Quote
Old 04-01-2016, 12:00 PM   #250
richbob
richbob's Avatar
Finally got round to doing the rear wheel
was a mess took off tyre and saw maybe 1/4'" of spokes sticking through rim tape
surprised didn't blow.
I Was told wheels rebuilt by professional (Yea right).
Old 04-02-2016, 02:23 AM   #251
'59
got a couple of bikes that smoke a little, guides and bores ok, so was interested how your honeing worked out?
My two may have been put together with a little too much assembly oil that I think may have glazed the bore, I thought that was the way at the time: feck!.
The pastel green is a little too much '50's Great Britain' for me but hey ho it's your ride and everything else is a credit to you, Sweet little Triumph you have there.
Old 04-03-2016, 02:43 AM   #252
richbob
richbob's Avatar
Well so far so good on both bikes
Honer said he said hone is 80 to 120ish (but he uses that on all older type engines,cars,tractors,static motors)
I washed bore in soapy water wiped a tiny smear of oil on bottom lip of skirt with finger.
Then started and rode hard through gears(kicked pulled clutch and off no dilly dallying)
