49 triumph bobber rebuild - Page 11 - The Jockey Journal Board
Old 11-29-2013, 04:56 AM   #201
richbob
richbob's Avatar
Default Re: 49 triumph bobber rebuild
Now i read somewhere on net that pre unit is the same as unit
fwd feed rear return
a couple of fucked knees later it is not
Old 11-29-2013, 09:47 AM   #202
richbob
richbob's Avatar
What a day swopped oil lines
then put me boot on lots of flames but one side then other couple of bangs
3 hours same injected some fuel in cylinders nothing got a massize spark nearly gave me cardiac arrest so fuel flames spark has to be timing?
but spent some time thinking i was a ok or 180 out
only other thing is i spent yesterday injecting oil all around wrong way but shouldn't be problem? breather dripping a little?
Old 11-30-2013, 03:09 AM   #203
richbob
richbob's Avatar
Pretty sure i found the problem
i set up points at 38 at the end of the cam portion on ring not at start(must have been late in the day!) points would break another half a revolution around
thats why i had flames out the carb?
Recheck all again today.
Old 11-30-2013, 07:32 AM   #204
richbob
richbob's Avatar
Done started first kick
now I'm going to get shitfaced
Old 11-30-2013, 07:41 AM   #205
HD48FL
Super Moderator
Congrats, great looking bike!
Old 11-30-2013, 08:53 AM   #206
richbob
richbob's Avatar
Cheers man,your doing a good job.
Old 11-30-2013, 06:26 PM   #207
mitchell tannahill
looking great man.
mitchell tannahill is offline   Reply With Quote
Old 11-30-2013, 06:47 PM   #208
whittiger650
whittiger650's Avatar
Cool Re: 49 triumph bobber rebuild
Well done !!
Probably take you at least half the case with those Peroni's
Jon
Old 12-01-2013, 03:04 AM   #209
'59
get that motor bedded in, time for 'girls' beer later. nice build and excellent build thread, a right rivetting read. ++A
Old 12-04-2013, 12:50 PM   #210
richbob
richbob's Avatar
Yea bedded in more like lets get tucked up.
So spent 2 days (not solid, beer breaks) getting back to where i started
i was told engine has been tuned when i bought it ,drag pipes proved impossible so baffled today and can finally get it to idle
Running rich but havnt had chance to go more than 1km or so tomorrow
try some more
Old 12-04-2013, 05:27 PM   #211
'59
yep, getting everything dialled in is a chore. I would say don't make the mistake i've made of running the motor too long if it's running lean, it gets dang unhealthy hot even without pinking.
Old 12-04-2013, 07:18 PM   #212
oilfield money
I really like what you've done . Dont let the dialing in part get in your head sometimes I have to step back and get a new perspective on the situation and in my case take the beer goggles off .
oilfield money is offline   Reply With Quote
Old 12-06-2013, 01:59 AM   #213
richbob
richbob's Avatar
I have established bike is running to lean on pilot jet circuit ,bike has difficulty idling, mixture screw nearly all way out,and cupping hands over carbs can get a steady idle,but went on the road a few times and once past 1/4 throttle accelerates away so maybe main jet is fine (but that is later)
I was amazed at how loose everything got on this engine cylinder base nuts got a full turn on them(but some of this is due to paint settling ) Head gasket started to blow studs had about 9lb on them
torqued it all up again and is good to go (this didn't help jetting process )
today i go up a size on pilot if i can find one.
Old 12-06-2013, 01:11 PM   #214
richbob
richbob's Avatar
Spent most the morning riding around to find keihin pilot jets.Did all motocross shops and Vespa/piaggio(polini bore kits run pwk carbs) got 2 40s up from 38s now bike is a lot better but mixture screw is 3/4 turn out at optimum fast idle, so tomorrow i go to 42 (i borrowed jets from ktm dealer and said id be back to pay or swop he said 'Prego'!translation;your welcome) I'm aiming for 1 1/2 turns out with correct idle and no surging etc then its throttle chops etc.
Crankcase Breather still spitting gearbox pissing oil (probably seal on drive side) so plenty of little jobs to do
Old 12-07-2013, 10:52 AM   #215
richbob
richbob's Avatar
On with the carb settings got another set of pilot jets today 42 .
But had a couple of erratic moments yesterday so thought id check for air leaks
back together with hylomar trim gaskets internally tomorrow morning ,start again
Old 12-08-2013, 07:42 AM   #216
croucho
Im sure you re adjusted the valve lash after retorquing everything.
Can the needle in the slide be adjusted up and down? That seems to have a big affect on low speed operation as well.
croucho is offline   Reply With Quote
Old 12-08-2013, 09:50 AM   #217
Loffer
Loffer's Avatar
I do that all the time . I remember while I'm doing it I'm on the wrong lobe and then next time I start doing it again! Really great build inspires me on mine.
Old 12-08-2013, 10:01 AM   #218
richbob
richbob's Avatar
Yes adjusted valves, needle will go up and down but stay in centre clip for the moment .Pilot 42 today but now 1 turn out so 44 next if i can find(otherwise is order off internet or Keihin Napoli but thats a little epic) still if i cup hands over stacks i can bring down to steady idle, so we need more fuel less air
Old 12-08-2013, 10:07 AM   #219
richbob
richbob's Avatar
All you need is time and money
Old 12-08-2013, 12:05 PM   #220
vorhese
vorhese's Avatar
dialing in is such a pain. Jetting aside, trying not to annoy your neighbors and finding an open spot to wide open throttle can be difficult.
