my BSA V.I.N is confusing the hell out of me - Page 2 - The Jockey Journal Board
Old 09-21-2011, 01:23 PM   #21
that_stupid_kydd
that_stupid_kydd's Avatar
Default Re: my BSA V.I.N is confusing the hell out of me
Originally Posted by CB550 Matt View Post
take blue painters tape and tape off the area where the numbers should be and then take the spray paint remover from home depot and spray some into a glass jar or bowl (OUTSIDE) and then brush it on the area you want to remove paint.
wouldn't it be easyer and cheaper to just use sandpaper and a wire brush or wheel
i own a bike, not just a shirt
that_stupid_kydd is offline   Reply With Quote
Old 09-21-2011, 01:56 PM   #22
Santa2
Santa2's Avatar
Sometimes the numbers are stamped very shallow. Wire brushes, wheels and sandpaper may rub them out permanently. Because they are so shallow, primer and paint can hide them.
Santa2 is offline   Reply With Quote
Old 09-21-2011, 03:20 PM   #23
that_stupid_kydd
OK, I removed the paint and there's no vin but you can see the casting marks ( dimples in the metal) so it hasn't been ground off now my newest question is should i leave it the way it is and tell people ( cops, licensing center, guy doing safety, etc.) that they are factory replacement cases or take my stamp set and stamp the vin on the ownership into the case
Old 09-21-2011, 06:42 PM   #24
Cluster
Cluster's Avatar
First no ones going to care about numbers
68 Doesn't need Signals , Day running Light and barely needs a Horn so what are they looking at?
Tires?
Go to Princess auto and buy Stamps and stamp the Motor to match the ownership you got with the bike
If the true vin is A65F then it's a 69
which going by your A6F-XXXX it is
If it's a 68 then it's A65FC (Single carb)
Hope this ends some of your Confusion and Take all that shitty black paint off
Or Buy a Shit load of Gaskets and seals
Since you'll need to replace every time it over heats
buy some 50W oil and have a Drain bung welded to the sump cover
Cluster is offline   Reply With Quote
Old 09-21-2011, 08:22 PM   #25
that_stupid_kydd
i was planning on removing the black paint and as for the year the ownership says 68 and for the vin it is A6F30XX
Tags
bsa, v.i.n
