trio of trumps - Page 6 - The Jockey Journal Board
Old 05-10-2010, 12:35 PM   #101
image1's Avatar
Default Re: trio of trumps
Got to work on my 'new' mids this weekend, pretty much a direct copy of what i already made, just some little tweaks. Started with some nice 90deg bends that craig did up for me, and then made pieces in the lathe for the mounting bits. Triumph con rod bushing, inserted in some DOM for the pivot, and a clevis i had hangin around. Nice and tight, feel good, look good, simple.
Timing/shift side. Will be using a stock shift arm.
Primary/brake side.
August 4-7, 2016!!!!!!!!!
http://r4yl.blogspot.com/
Old 05-10-2010, 02:25 PM   #102
Loffer
Loffer's Avatar
thats tight!!! Kinda in between frisco and stock height...
Old 05-10-2010, 02:49 PM   #103
image1's Avatar
yep, and a lil forward of stock too.
Old 05-18-2010, 10:05 AM   #104
BackPorchChoppers
BackPorchChoppers's Avatar
Thanks image1 all I need to do is bend out some pipe get some bungs get it all lined up and weld it to the frame I got then. And by the way you do bad ass work.
BackPorchChoppers is offline   Reply With Quote
Old 05-18-2010, 12:22 PM   #105
image1's Avatar
got some work done on the brighter side of things...
that motor mount is mild steel. Also got the gearbox cover, primary cover, the other rocker box and the other 2 motor mounts done. Still got the black boog disease going on lol
Old 05-18-2010, 03:19 PM   #106
BackPorchChoppers
hey you speed hole those rocker boxes your self
Old 05-19-2010, 09:22 AM   #107
image1's Avatar
yep
Old 05-19-2010, 09:40 AM   #108
Scab Vendor
Scab Vendor's Avatar
I dig it man, fine work there sir.
"Break your backs and crack your oars men, if you wish to prevail! "
Scab Vendor is offline   Reply With Quote
Old 07-14-2010, 08:47 AM   #109
image1's Avatar
Still moving forward, got the other rocker box assembled, and the new small end bushes pressed into the con. rods. Got my cylinder back, and painted it up. Also got some of my magneto stuff back from my buddy doing the machine work. He's gotta finish up the adapter shaft and its ready to go. *Hopefully* the correct main bearing shows up today and i can really get this show on the road.
Old 07-14-2010, 09:50 AM   #110
SwedeBobb
SwedeBobb's Avatar
Send a message via MSN to SwedeBobb
Man I cry when I see stuf like this, make me feel so bad about myself!
But seriously though, really great work. Will be fun to see how it turns out finished
SwedeBobb is offline   Reply With Quote
Old 07-14-2010, 03:59 PM   #111
Murdoc650
Murdoc650's Avatar
I can't believe I missed this whole thread! The opening pix of the engines all spread out was a great way to break my heart. Fuck, what a nice collection of a lot of really cool shit. Six pages later, all I can say is...Great work, inspiring ideas, and I'll be checkin' in to see how it all comes together. -Murdoc.
Murdoc650 is offline   Reply With Quote
Old 09-13-2010, 01:32 PM   #112
image1's Avatar
Bout got the motor rebuild done, gotta set the valves and time the mag, finish plumbing and tie up a couple other loose ends, but its getting REALLY close, (and I promise the sporty tank is NOT staying)
Old 09-13-2010, 04:06 PM   #113
Bodyworx
Bodyworx's Avatar
Wow, look great. Motor has so much more visual interest after all the mods. Nice work.
Bodyworx is offline   Reply With Quote
Old 09-21-2010, 12:25 PM   #114
image1's Avatar
got my tank back from Jay (special '79), his work is amazing!
Old 09-21-2010, 03:37 PM   #115
Loffer
Loffer's Avatar
Looks great. Love the seat, the tank is awesome.
Old 09-22-2010, 08:01 AM   #116
image1's Avatar
thanks loffer, checked out your thread this morning, coming along nicely!
Old 09-22-2010, 10:35 PM   #117
Loffer
Loffer's Avatar
thanks , its become a winter project again. I was finshing up my chopper for the summer season. End up riding and having a good time dont wanna turn any wrenches till its over.
Did you shave the lip on your fork lowers to get those covers nice and tight like that?
Old 09-23-2010, 08:45 AM   #118
image1's Avatar
nope, thats a 35mm Narrowglide, and some swap meet 33mm covers of unknown origin, i had to open up the tops a bit to get 'em over the tubes, but no mods to the bottoms.
Old 11-23-2010, 08:37 AM   #119
image1's Avatar
Changed up the magneto setup to gain some much needed shifter room. Now running a very modified XH mag, and ARD type setup that i fabbed.
and yes, it RUNS!!!!!!!! First time i've had it running since i broke a rod 3 years ago, it was a good night in the shop!
from Joel Hauenstein on Vimeo.
Old 11-23-2010, 08:41 AM   #120
shades34
shades34's Avatar
some cool stuff you've got going on there. I like the raw look, it looks natural not too contrived.
shades34 is offline   Reply With Quote
