trio of trumps - Page 2 - The Jockey Journal Board
Old 07-07-2009, 06:00 PM   #21
chorro
chorro's Avatar
Default Re: trio of trumps
awesome
chorro is offline   Reply With Quote
Old 07-20-2009, 12:26 PM   #22
image1's Avatar
chippin' away at things still...
got the bottom end of this motor back together (hope to be picking up the fresh cyl. barrels tonight) and then on to the top end. Got a seat pan made up (NATE!), still gotta make some mounts. Just couldn't leave well enough alone and ended up cutting the pipes down some. Got a rear mount made for the exhaust last night. Got all the old exhaust mounting shaved off, forward controls are shaved off. I don't know, there is a CHANCE still....
August 4-7, 2016!!!!!!!!!
http://r4yl.blogspot.com/
Old 07-20-2009, 01:15 PM   #23
R-U-Up2-It
R-U-Up2-It's Avatar
Send a message via Yahoo to R-U-Up2-It
Joel,there are really coming together and lookin good! Is that your 71' in the background too? Those pipes look real good on the white and black bike!Nice work.
Awww FUCK IT going to spend my cab money on MORE shots and just take the ambulance home!
http://img95.imageshack.us/img95/8686/ashleymekz2.jpg
[IMG]http
R-U-Up2-It is offline   Reply With Quote
Old 07-20-2009, 01:18 PM   #24
image1's Avatar
yep, good eye!
Old 07-20-2009, 02:19 PM   #25
R-U-Up2-It
R-U-Up2-It's Avatar
I've had 2 71's and love'em A-bodies are fun! I've had all from 64-72 except a 70 and one of these days I'll get that one. Nice choice Joel!
[IMG]http
Old 08-07-2009, 01:41 PM   #26
image1's Avatar
STILL waiting on the cyl. to come back from the machine shop :/
new bars from Front St. Cycle, he calls 'em Midgets, i call 'em BADASS!!!!!!!!! 7/8 x .120 brings the BEEF!
Old 08-14-2009, 12:41 PM   #27
image1's Avatar
A couple of mine at lunch today,
Old 08-15-2009, 07:59 AM   #28
0264315547
Red face dfg fg
sseaaqiipyyutty
0264315547 is offline   Reply With Quote
Old 08-15-2009, 08:15 AM   #29
drumrooster
drumrooster's Avatar
looks great man..hey why you mount the tail light on the right?? cause of the brake rod?? I always though they need to be on the left so when your in the right lane the passing traffic can see it better?? any thoughts on this ??
"NO PICTURE. NEVER HAPPENED..."
drumrooster is offline   Reply With Quote
Old 08-15-2009, 09:35 AM   #30
bhead1968
bhead1968's Avatar
hope you put somthin' in dem dar spark plug orifices and your gas tank so no nasty squirles or roaches find a new home .... also, you not running any top motor mounts (head steadys)?... nice scoot tho'...
bhead1968 is offline   Reply With Quote
Old 08-17-2009, 01:54 PM   #31
image1's Avatar
spark plug orifices
i wish the head was bolted on.... still waiting to get my good cyl. back from machine shop.
just felt like putting it there i guess... you are orobably right about your theory, but then some people wear helmets....
head steadys
frame was cracked in a couple spots when i got it, so i think i'll add some.
Old 08-17-2009, 02:52 PM   #32
framus
Good luck with those Emgo gaskets. They're crap at best.
~Craig
MAP Cycle
framus is offline   Reply With Quote
Old 08-26-2009, 12:50 PM   #33
image1's Avatar
Been hammering away on this thing so its absolutely ready for the road if i EVER get my cylinders back.
*Got a new kickstand made, and miraculously found my old block, got it all welded up and back on, works great.
* Got the seat mounted, scored some Ford valve springs from a greybeard up the road. Made the pivot, etc.
* Started on my 'new mids' I made forwards for the bike when i first built it, they looked like hell, i cut them off. Soo... i machined a piece of round stock to accept a worn cam bushing, and welded that to my motor mount, and then machined a shaft to fit the bush. I used an old Ironhead brake lever, which is about the right length, and havent decided if i will utilize the ears on the Harley part, or make an 'ear' on the back side of the shaft like a stock triumph. Bent up some round bar to make the foot peg as well, its about an inch and a half longer than stock, and super comfy! Obviously a bunch of cleanup and finish to do yet, but i'm pretty happy so far.
Old 08-27-2009, 12:26 PM   #34
image1's Avatar
some more work, lever and pivot are done, except clean up work. Need to make a new brake rod, and this side is DONE!
* oh and cylinders are DONE, pick 'em up tonight!!!!!!!
Old 08-27-2009, 03:51 PM   #35
6T Sinner
6T Sinner's Avatar
That certainly looks a lot better than yesterday! Good work, I know this stuff isn't easy.
6T Sinner is offline   Reply With Quote
Old 08-28-2009, 12:45 PM   #36
image1's Avatar
lol, thanks
finished (un-painted) brake side:
Old 08-28-2009, 12:57 PM   #37
vorhese
vorhese's Avatar
stop welding on rust and paint. Clean it up!
Old 08-28-2009, 09:27 PM   #38
BRET IRON
BRET IRON's Avatar
Comin' Along!
www.SkinandBoneCustoms.com - 34,000 Triumph, Norton, BSA Parts at below retail, David Bird Frames, British & HD Joe Hunt & Morris Magnetos
BLOG
JJ Jock Shop
www.myspace.com/trumpnut
www.BritIronRebels.com
BRET IRON is offline   Reply With Quote
Old 09-28-2009, 12:30 PM   #39
image1's Avatar
lunchbox mounted
some more progress on the other
Old 09-29-2009, 12:30 PM   #40
image1's Avatar
Got some more work done on the Quickee, got an electrics/battery box sorted out, and mounted, which meant i could finish cleaning up the frame and paint it. Pics aren't the best, but its raining and i was in a hurry. Dude is on a budget so paint is just Duplicolor Red Anodize, with some Fire Red lines here and there.
Also got the tank and fender painted up, semi gloss black w/ Fire Red & Metallic Silver.
This is for this bike:
