Sportster Help!! - The Jockey Journal Board
Old 04-16-2009, 06:09 PM   #1
brokenking217
Default Sportster Help!!
So Fellas, here's the deal. The bike is an 04 sporty that I'm working on for a friend and the bike is leaking from the shift arm. I went and got the replacement seal but need advice on getting the old seal out?? Hopefully without having to remove the primary cover!! Any help would be appreciated! Thanks!!!
brokenking217 is offline   Reply With Quote
Old 04-16-2009, 06:31 PM   #2
alaskanrocket
alaskanrocket's Avatar
Default Re: Sportster Help!!
you have to remove the primary cover. Sorry but its the only way.
alaskanrocket is offline   Reply With Quote
Old 04-16-2009, 06:51 PM   #3
Blacktooth Grin
I have used a pick to pull the seal out without removing the primary cover.
Zackleys
Blacktooth Grin is offline   Reply With Quote
Old 04-16-2009, 06:54 PM   #4
brokenking217
Are these seals POS?? This bike has like 850 miles on it?? What type of pick did you use to remove the seal? Was it a nightmare or does it come out fairly easy? Thanks!
Old 04-16-2009, 06:54 PM   #5
chopped850
chopped850's Avatar
You can drill to small holes on each side of the shaft and insert some self tapping sheet metal screw into those holes and remove the seal with pliers.
chopped850 is offline   Reply With Quote
Old 04-16-2009, 07:01 PM   #6
alaskanrocket
My bad. I thought there was shoulder on the front of the primary cover holding those in.
Old 04-16-2009, 07:04 PM   #7
jason43
jason43's Avatar
My bro in law had the exact same leak, also a low milage late model Sporty, so it must be a pretty common problem... his is an '03.
"They're gonna talk to you, and talk to you, and talk to you about individual freedom. But they see a free individual, it's gonna scare 'em."
jason43 is offline   Reply With Quote
Old 04-16-2009, 07:07 PM   #8
brokenking217
Yeah, just wanted to see if the seal is able to be pulled easily before I take everything apart.....path of least resistance I guess?
Old 04-16-2009, 07:54 PM   #9
fishnuts
fishnuts's Avatar
+1 this is the best way period to get this seal out, just make sure to stay away from the outer edge in which the seal sits against... when putting new seal in make sure to tape up the shaft with elect. tape and apply a bit of oil to tape so the new seal will slide over it nicely and wont rip, socket and hammer to set the seal in.
The Beatings Will Continue Until Morale Improves.
"They call us walking corpses, unholy living dead..."
fishnuts is offline   Reply With Quote
Old 04-16-2009, 08:29 PM   #10
brokenking217
Thanks for the input! I guess I'll try the pic first and if that doesn't work then I'll pull the primary! Thanks Again for the insight! I appreciate it!!
Old 04-18-2009, 08:11 AM   #11
VTtaco
Ha I am getting ready to replace mine this morning. Like Jason43 said ealier in the thread, mine is an 04 with low miles and it has the same problem. Must be some sort of defect. Next weekend i have to replace the axle seal on my 4Runner. Why can't stuff just not leak? Bah.
VTtaco is offline   Reply With Quote
Old 04-18-2009, 10:17 AM   #12
chopped850
chopped850's Avatar
It's a Harley so it's going to leak!
