Lowbrow Customs: Apparel, David Bird Hardtails, Biltwell 7/8" Bars, Hunt Magnetos - Page 8 - The Jockey Journal Board
Go Back   The Jockey Journal Board > The Jockey Journal Marketplace > Jock Shops
Old 11-07-2009, 07:59 AM   #141
lowbrowcustoms
lowbrowcustoms's Avatar
Default Re: Lowbrow Customs: Apparel, David Bird Hardtails, Biltwell 7/8" Bars, Hunt Magnetos
28X Vertical License Plate Bracket with Model A Tail Light - No School Choppers
http://lowbrowcustoms.com/index.asp?...ROD&ProdID=594
It doesn't get much better than this..
- 10 gauge laser cut steel construction w/ black powder coat finish.
- Axle mount plate is 3/16" steel with TIG welded fabrication. Stronger then any on the market.
- Polished stainless steel 12V Duolamp taillight w/ license plate light.
- Chrome license plate frame and mounting hardware.
- Choose your own style lens (see photo in gallery below for different styles)
These license plate brackets will fit either a 1" or a 3/4" axle. They are drilled for 1" and come with a stainless steel stepped spacer to allow it to be run on a 3/4" axle with no modifications. These are left side mount, and the lights are 12v dual filament so they work as your running and brake light, as well as featuring a handy license plate light to appease The Man. All glass lens, no cheap plastic here. $99
lowbrowcustoms is offline   Reply With Quote
Old 11-09-2009, 05:39 PM   #142
lowbrowcustoms
Shovelhead Motor T-Shirt - Shovelhead Engine '66 - '83
http://lowbrowcustoms.com/index.asp?...ROD&ProdID=544
A classy t-shirt with a cutaway view of a Shovelhead motor on the back and Shovel 1966 - 1983 on the front with a small image of the Shovel motor. Water based ink imprint on left chest and full back for that vintage look and feel. Printed in the USA on a heavy, 100% cotton black t-shirt. $16
Old 11-11-2009, 08:33 AM   #143
lowbrowcustoms
BSA A50 / A65 Joe Hunt Magneto - Pre '70
http://lowbrowcustoms.com/index.asp?...ROD&ProdID=295
Increase the performance, reliability and looks of your BSA with this Joe Hunt BSA magneto kit. Kit includes a cast aluminum side cover that mounts the Joe Hunt Magneto. Simply remove stock cover and point plate and install the Joe Hunt side Cover. Outside mounting of the magneto makes for easy on the spot timing. The stock electrical system can be retained for street or removed for competition.
Your choice of black or red bakelite magneto cover. Also, you can choose to have an on/off keyswitch added in the housing for an additional $65, the Joe Hunt side cover beautifully polished for $50, the aluminum magneto housing polished for an extra $50, and you can also choose whether you want a Joe Hunt 8mm Plug Wire Set for only an extra $10!
Old 11-12-2009, 12:39 PM   #144
lowbrowcustoms
Sideburn Magazine Issue #4 is here! Rob Rouser makes an appearance..
http://lowbrowcustoms.com/index.asp?...ROD&ProdID=602
"The world's finest, most glamorous, most colourful, most informative, global-reaching go fast, turn left magazine. The place where every weekend is a dirty weekend"
HOW TO WIN THE SPRINGFIELD MILE by Chris Carr | DON CASTRO Who? when? Why? How? | NIKKISAKI cover queen and her Kay Zee 400 | ONE ARM IS ENOUGH for Jason Griffin | HUSQUARLY Danish baked Monkee XLCH | PER AMORE a passionate Marco Belli | JUICY BRUCEY speedway's wheelie king | BONER BRIGADE Death Spray Custom's XS650 | PHANTOM from beyond the grave | RIVERSIDE BOMBERS thrill seeking WWII vets | SUPER MONO Orlando Bloom's Oz built special | SNOW PATROL off piste with Valentino Rossi | DAI JOBU a night on the town | THE RED MENACE Ducati crashes the AMA party | WAYNE KARCICH ripping up Las Vegas | A WAY OUT Rouserworks' knobby chop | KIN BRILLIANT the Bostroms' family album | SIDEBURN subscriptions T's and stickers | TROPHY QUEEN John Hateley custard pie fight
Digest-sized, 100 pages, full color.
Old 11-18-2009, 04:28 PM   #145
lowbrowcustoms
DiCE Magazine #29 November / December 2009
http://lowbrowcustoms.com/index.asp?...ROD&ProdID=603
"Diego Maradona had one. ...Brian May still has a dodgy one...Robert Plant thinks he still looks good with one....Vera's from Corrie goes down past her ears.....Kevin Keegan would only be half the man he is today without his one....The whole of Bon Jovi had shares in them...Your Momma Had One...Kylie Minogue and Jason Donovan got famously stuck together with theirs....Even Chesney Hawkes rocked one for a minute. Yes people I'm talking about the 'Perm'. Sure, styles come and go...but not this one baby...this one is back for good...Issue 29....The Perm Issue.
The Cover for Issue 29 was styled in a tight knit way by none other than that man about town, James Owens!"
Full color, digest sized, and a whopping 132 pages.
$8
Old 11-23-2009, 06:56 AM   #146
lowbrowcustoms
Whitworth Tap and Die Set - Triumph, BSA, Norton, MG, Jaguar
http://lowbrowcustoms.com/index.asp?...ROD&ProdID=590
If you have an old British motorcycle, chances are it has been around long enough for a ham-fisted mechanic to cross thread a bolt or try and use standard hardware on your delicate Whitworth threads. This Whitworth tap and die set is the answer to your problems, the cure to the headache that is your hobby.
It has a starting and bottoming tap for each size, 1/4"-26, 5/16"-26 and 3/8"-26, for a total of 6 taps. It also includes a round die, one each for the same sizes. Also included are a tap handle and a die handle, a screw driver and it all comes in a nice wooden case to keep it organized and handy.
This is the perfect tool set to make assembly go easier by chasing your threads, fix buggered holes or bolts, and generally be extremely handy to have around when you just can't run to the local hardware store for some Whitworth hardware. An essential kit for the British motorcycle owner turned enthusiast.
Old 11-25-2009, 07:20 AM   #147
lowbrowcustoms
Triumph Exhaust 1.75" chrome Drag Pipes - Made in England
http://lowbrowcustoms.com/index.asp?...ROD&ProdID=610
These brand new Triumph drag pipes are 1.75" OD throughout and feature a front mounting tab. Beautiful chrome, these pipes will slip right over your exhaust spigots and look great. Why mess with old beat up exhaust pipes? And these are not some cheapo ones, they are made in England!
Old 11-26-2009, 10:24 AM   #148
lowbrowcustoms
FOUR new colors of Biltwell, Inc. Megaflake helmets now available only from Lowbrow Customs!
Pacific Blue, Disco Gold, Gang Green and Wine are now available. You can check out these and the rest of the helmets here:
http://www.lowbrowcustoms.com/index....TS&Category=69
Cheers
Tyler
Old 11-26-2009, 01:58 PM   #149
calicruiser
calicruiser's Avatar
Cheers
Tyler
HELL YEAH!!!! BEautiful colors fellas!!!! kudos to biltwell.
josh
Old School Helmets
DIG THE LID?
Old School Helmets
& Custom Paint
calicruiser is offline   Reply With Quote
Old 11-27-2009, 03:20 PM   #150
lowbrowcustoms
Just in!
Two Wheel Terrors 2 DVD
http://www.lowbrowcustoms.com/index....ROD&ProdID=622
The newest release from the VanSchyndel brothers is out, Two Wheel Terrors 2! Lowbrow Customs is a proud sponsor of Two Wheel Terrors 2, along with DiCE Magazine, Mooneyes, Dickies and Lucky 13. $25
What: Knuckles, Pans, Shovels, Triumphs, Choppers, Bobbers, and skateboards.
Running time 35 minutes + extras.
Old 11-30-2009, 03:20 PM   #151
lowbrowcustoms
English 101 DVD & Triumph 650 Rebuild DVD - 2 DVD Set - Save $5!
http://www.lowbrowcustoms.com/index....ROD&ProdID=624
Buy both the English 101 DVD and the Triumph 650 Rebuild DVD as a set for only $75! Perfect for a Triumph or BSA motorcycle owner, between these two films you can rebuild your motor and keep your vintage British motorcycle on the road and running reliably!
Old 12-01-2009, 02:39 PM   #152
lowbrowcustoms
WTF these new colors are rad, we just got in a new one that we didn't think we would have this shipment, Biltwell Inc Dark Silver helmet!
Biltwell Dark Silver Megaflake Metalflake Helmet
http://www.lowbrowcustoms.com/index....ROD&ProdID=546
Old 12-02-2009, 03:05 PM   #153
lowbrowcustoms
Counterbore Steel Bungs for 5/16" and 3/8" Allen Head Bolts
http://www.lowbrowcustoms.com/index....TS&Category=90
Counterbore bungs are great as they allow for very clean mounting, as the head of a standard allen bolt will fit flush inside. These bungs are for 5/16" hardware. The outside measurements are 3/4" diameter and .625" long.
Also available are bungs for 3/8" allen hardware, the outside measurements are 3/4" diameter and 3/4" long.
These are nice when used in conjunction with our threaded bungs as they are the same diameter and make for a seamless mount. Our counterbore bungs are 1018 cold rolled steel for easy welding and are great for mounts of all sorts. Sold individually.
Old 12-06-2009, 08:11 AM   #154
lowbrowcustoms
Triumph Exhaust 1.75" chrome High Shotgun / Scrambler Pipes - Made in England
http://www.lowbrowcustoms.com/index....ROD&ProdID=636
These brand new Triumph high shotgun exhaust pipes are 1-1/2" OD throughout with a flare to 1-3/4" to fit over the exhaust head spigots on your pre unit or unit Triumph motorcycle. One pipe goes down each side of your bike. Perfect for that custom application, these will make your chopper, bobber or desert sled look cool as it gets. Made In England. $195 per pair.
Old 12-07-2009, 01:38 PM   #155
lowbrowcustoms
Dual Carb Adapters for your single carb bike - Maund Speed
http://www.lowbrowcustoms.com/index....ROD&ProdID=629
This pair of Triumph twin dual intake manifolds are dual carb adapters to run dual carbs on your single carb motorcycle. The dual carb adapters will fit all 650 c.c. pre unit and unit single carburetor heads, as well as 500 c.c. (pre unit) long stroke cast iron head models, and TR7 Tiger 750 c.c. heads.
Increase performance with 45 degree splayed port design allowing adequate clearance for velocity stacks or filters that are not possible with single carburetor manifolds.
$128 a pair
Old 12-09-2009, 04:59 PM   #156
lowbrowcustoms
Mustang Dual Cap Gas Tank, 2.2 gallon
http://www.lowbrowcustoms.com/index....ROD&ProdID=635
These 2.2 gallon Mustang tanks are great, nice and small with classic lines. These tanks measure 16-1/2" long (17" long center to center on mounting tabs), 9" wide and 7" deep. The tunnel measures 2-1/4" wide x 2-1/2" deep and features both a front and rear mounting tabs.
The dual cap Mustang tank has one functional filler, the other is a dummy. Included with your tank are two new chrome gas caps and a single 3/8" NPT petcock.
$99 with both caps and petcock
Old 12-10-2009, 03:54 PM   #157
lowbrowcustoms
Devils & Angels - Kustom Kulture is Alive and Well DVD - Lowbrow Art, Pinstriping, Hot Rods & Pinups, $25
http://www.lowbrowcustoms.com/index....ROD&ProdID=640
Lowbrow Art, Hot Rods, Customs & Girls. We got interviews with all sortsa cool folks. We've corralled Japan's masters of striping Makoto, Mr. G and Grimb.
We also take a close-up look in studio with the amazing Doug Dorr, get a peek inside the twisted mind of Jeral Tidwell and spend the day with Hot Rod/Surf Art legend Damian Fulton. We see up close the artists at work, and at play, and see what makes these characters tick...
Take a ride with the Straight Jacket Kustoms car club to the Grand National
Roadster Show, 'Weld This' Art Show, and finally Gasoline Gallery's 'California Screamin' Art & Hot Rod Show.
Feature run time over 1 hour, with extras
This is an All Region DVD and features English & Japanese subtitles.
http://www.youtube.com/watch?v=EaTa2R4mAjc
Old 12-12-2009, 03:36 PM   #158
lowbrowcustoms
Bolt On Motorcycle Chain Tensioner for 530 chain - MonsterCraftsman
http://www.lowbrowcustoms.com/index....arch=GO&Page=1
We now have in stock 4 different chain tensioners by MonsterCraftsman. These include both a bolt on and a weld on sprocket style chain tensioner, as well as a bolt on and a weld on version of a skateboard wheel chain tensioner with a Peralta wheel. Prices are $99 - $125
Old 12-14-2009, 04:50 PM   #159
lowbrowcustoms
TCB Takin' Care of Business Lapel Pin - Fink Style
http://www.lowbrowcustoms.com/index....ROD&ProdID=642
We took our Fink-style TCB design and made these cool 3D cast TCB lapel pins! Gold plated with black enamel and a pin backing, these are 1-1/8" tall. See the photo below next to the quarter for scale. Elvis would be proud. $4 each
Old 12-15-2009, 04:42 PM   #160
lowbrowcustoms
Whitworth Combo Tool Set - 6 piece Koken Socket Set & 8 piece combination Rolson Wrench Set - Triumph, BSA, Norton, MG, Jaguar
http://www.lowbrowcustoms.com/index....ROD&ProdID=652
Save money and get a Whitworth 6 piece, 12-point socket set and 8 piece combination wrench set for $89.00.
A high quality set of Whitworth 12-point sockets by Koken (Japan). 3/8" drive. Includes a socket holder. This set of 6 12-point sockets includes 1/8 WW, 3/16" WW, 1/4" WW, 5/16" WW, 3/8" WW, and 7/16" WW.
8 piece, drop forged, combination wrench / spanner set by Rolson includes 1/8 WW, 3/16" WW, 1/4" WW, 5/16" WW, 3/8" WW, 7/16" WW, 1/2" WW, and 9/16" WW.
Tags
front end mod, harley, lowbrow customs, pangea speed, sportster
HTML code is Off
