Making Alloy Triumph Cylinder Barrels by Alp Racing Engines - The Jockey Journal Board
Old 03-04-2018, 01:49 PM   #1
astek
astek's Avatar
Default Making Alloy Triumph Cylinder Barrels by Alp Racing Engines
Making barrels for Triumph twins, quick change sleeves for top fuel and nikasil plated for street or roadrace. Will test my prototype with my topfuel motors, if I like them and if I have time they will be available.
Name:	Alp Racing Engines Triumph Cylinders 01.jpg
ID:	248538   Click image for larger version
Name:	Alp Racing Engines Triumph Cylinders 02.jpg
ID:	248546   Click image for larger version
Name:	Alp Racing Engines Triumph Cylinders 03.jpg
Name:	Alp Racing Engines Triumph Cylinders 05.jpg
www.alpracingdesign.com
Old 03-04-2018, 05:56 PM   #2
Ratso
Ratso's Avatar
Default Re: Making Alloy Triumph Cylinder Barrels by Alp Racing Engines
[Impressed.]
Old 03-04-2018, 07:51 PM   #3
HD48FL
Super Moderator
Very nice. How do you like Fusion 360?
Old 03-04-2018, 09:42 PM   #4
Rob Axel
Rob Axel's Avatar
So... exactly when do you plan on launching one of your bikes into outer space??
I KNOW it is just a matter of time!!
"The heart is happiest
Old 03-04-2018, 10:22 PM   #5
Ratso
Ratso's Avatar
How does a quick-change sleeve work?
Old 03-04-2018, 11:22 PM   #6
WhizzbangK.C.
Very cool. Just out of curiosity, did you make any changes to the stock jug dimensions to account for the different material characteristics?
Old 03-05-2018, 12:36 AM   #7
astek
astek's Avatar
I'm using rhino for the last 20 years and you can run the T-Splines Plug-in for Rhino and it is the same as fusion, I like it but rhino has specific features/plugins supporting hydrodynamics, marine type design work.
It is not press fit, the design allows you to replace the sleeves easily. Top fuel and some other type of racing engines use these type of sleeves.
Working on it )))
The first prototype will look exactly like the original barrel.
Thanks
Old 03-13-2018, 06:18 PM   #8
Truckedup
Interesting idea..For prduction, are you going to machine from billet or cast the cylinders?
Old 03-13-2018, 07:12 PM   #9
Phlogisticated
Phlogisticated's Avatar
OK, "beautiful" is an inadequate word, but it's beautiful! Carry on!
(I am slowly learning Fusion 360. So far so good, but I really need to invest more time.)
Phlogisticated is offline   Reply With Quote
Old 03-13-2018, 11:37 PM   #10
astek
astek's Avatar
I'm just going to make some billet cylinders for my own racing engines first.
Thanks Phlogisticated, my machinist gets the credit for the machine work.
Tags
alp racing engines, land speed, nitro, top fuel, triumph cylinders
