Angry Monkey Motorcycles, "unleashed" pre unit build. - Page 3 - The Jockey Journal Board
Old 06-01-2015, 03:08 PM   #41
Lester
Lester's Avatar
Default Re: Angry Monkey Motorcycles, "unleashed" pre unit build.
Dan,
Great fab work as always, a huge inspiration for me.
What toggle switches do you use/recommend. The ones I have come across so far are all rubbish from China. I finally found a use one from the 60s-70s era that is holding up well but few and far between them and a need a couple more.
Cheers
Lester
'62 DuoGlide Mine for 25yrs
'62 Triumph T-Bird in boxes
'83 BMW R100 commuter
'80's couple of Jap chops too
Old 06-01-2015, 05:46 PM   #42
supercrouton
supercrouton's Avatar
Originally Posted by richbob View Post
Funky pipes
Whats that capacitor your using?
2x) 4700 mf
Old 06-01-2015, 05:49 PM   #43
supercrouton
Originally Posted by Lester View Post
Dan,
Cheers
Lester
Thanks so much Lester. Math is your friend with switches. I use ones rated above the load I plan to put on them. The ones shown will also have weather covers on their front, since there is no front mudguard.
Old 06-01-2015, 07:17 PM   #44
supercrouton
Metal finishing all finished. Here is how the pipes fit the bike. This tube follows the right down tube nice and tight.
And brackets done...
Old 06-01-2015, 07:30 PM   #45
supercrouton
Small detail of tail light / license plate bracket. Welded on nuts to the back reduce by half the number of fasteners to drop and lose when putting a tag on it
All 10 gauge construction, and of course an English bottle opener for good measure. Shorter bolts will be fitted to it when it goes together for the last time.
Old 06-02-2015, 12:30 AM   #46
Lester
Lester's Avatar
Thanks Dan, I am awear og the math, my toggles just seem to vibrate to failure after a season or two. I'd like them to hold up a bit longer. You can put your money on it that they will fail during a rainy rush home too. Murphy!
Any particular brand or vendor you can recommend?
Lester
Old 06-02-2015, 01:01 AM   #47
Rob Axel
Rob Axel's Avatar
I ve got small micro toggles I got from radio shack...no issues yet over a year...
Now that I have said that......watch them fail
"The heart is happiest
Old 06-02-2015, 01:11 AM   #48
Rigpig
Rigpig's Avatar
Wow, fantastic fab work! Really like the brackets and supports, reminds me of some of the work i've seen on "MJK"'s bikes, super clean.
Looking forward to seeing it complete.
Cheers!
Rigpig is offline   Reply With Quote
Old 06-02-2015, 08:16 AM   #49
supercrouton
Lester
That's odd. I just assumed you were using under rated switches because I have yet for one to fall apart. It seems that most all of them are chinese, but some really do quite well, even in rough use. E-mail some pics and measurements of what you currently use, and need and I'll see if I can get you some of the ones I use.
Old 06-02-2015, 08:22 AM   #50
supercrouton
Cheers!
Thanks! Who is MJK? This thread is not real time, it has been going on for months now. So you will see some further progress pics pretty soon.
Old 06-02-2015, 08:51 AM   #51
image1's Avatar
cool pipes dan, nice and tight.
August 4-7, 2016!!!!!!!!!
http://r4yl.blogspot.com/
Old 06-02-2015, 09:30 AM   #52
supercrouton
Thanks Joel! That's what I was going for, tucked in, and tight. Also, now if I need to open the timing cover once everything is finished, both pipes can remain in place.
Here is how the switches will sit with the gas tanks in place. Since this client already own one of my bikes, I tried to replicate where the switches are on his other bike so his hand will fall to the same general area for hi-lo headlight control and magneto control.
Old 06-02-2015, 12:42 PM   #53
Lester
Lester's Avatar
Will do, thanks Dan, very kind and helpful of you.
Lester
Old 06-02-2015, 01:01 PM   #54
dvrogers
dvrogers's Avatar
You really do beautiful work!
dvrogers is offline   Reply With Quote
Old 06-02-2015, 03:26 PM   #55
supercrouton
Lester
Glad to help
Old 06-02-2015, 03:51 PM   #56
supercrouton
Thanks for the kind words David.
Here are a couple more details. Oil filter mount first. BTW, DO NOT use a mobil1 M1-102 oil filter. They are too restrictive for triumph oiling systems and will cause excessive oil to go past the rings. If you run a filter, the FLO Oil Filter by PC Racing #PCS4C or #PCS4B functions perfectly.
Also, the filter adaptor is one of "Nottso"s pucks. Just check the jock shop section of the jj. They are tidy, nicely made, and Dan is a great guy to work with.
Here is the saddle pivot. I used an existing set of bosses and some 7/16" round stock and a bit of oxy/acetylene love to get it to the right shape.
Old 06-02-2015, 08:25 PM   #57
cshabang
Looks awesome
cshabang is offline   Reply With Quote
Old 06-04-2015, 01:36 AM   #58
leebo
Very inspirational, excellent craftsmanship as always
leebo is offline   Reply With Quote
Old 06-05-2015, 01:01 PM   #59
supercrouton
Originally Posted by cshabang View Post
Looks awesome
Thanks for the kind words guys!
Here are the tins back from body work.
And here is the whole deal, minus the license plate bracket...
Old 06-05-2015, 02:03 PM   #60
vintagespeed
right click, save as...
damn man another home run! love those pipes!
-jb
that's JunkBitch to you.
vintagespeed is offline   Reply With Quote
Tags
angry monkey motorcycles, pre unit, supercrouton, triumph
