69 Triumph TR6 Fork Options - The Jockey Journal Board
Old 09-28-2014, 08:41 PM   #1
jarlenfos
Default 69 Triumph TR6 Fork Options
Hey all,
We recently purchased a TR6 with a wl springer front end which we have taken off to run on the shovel and are now looking to replace the forks on the triumph with something else. Apart from OEM shocks for that year what other front ends are easily adaptable to the TR6. I've been struggling to find a decently priced OEM front end here in Australia and shipping from the US will cost a fortune. Any ideas?
Cheers
jarlenfos is offline   Reply With Quote
Old 09-28-2014, 08:57 PM   #2
VonWegener
VonWegener's Avatar
Default Re: 69 Triumph TR6 Fork Options
How about the Sportster, Dyna 39mm narrow glide with 1" stem. You get one of those timkin bearing conversions for your TR6. Fit the races in your neck and exchange the bearings for Timkin #L44643 with 1" I.D. and Bob's yer Uncle.
Old 09-29-2014, 08:00 AM   #3
Truckedup
I put a 39 MM Sporty front end on a Triumph. It fits ok but the stock springs are too stiff for bumpy roads. I didn't look into spring options because it was a low priced swap for a guy.
My current 70 T120 build has a 92 Yamaha FZ600R 38MM front end. It's lighter weight and softer springs than the Sporty front end ...I made the adapters to fit it.
Old 09-29-2014, 02:53 PM   #4
ogoki
ogoki's Avatar
Just to clarify: The 1" stem Harley-spec bearings, L44643, will work with the Triumph races? So, if we already have tapered roller bearings in a Triumph neck with a Triumph front end (late 60's stuff, for example), we don't need to swap out the races to run the Harley bearings?
Thanks.
ogoki is offline   Reply With Quote
Old 09-29-2014, 03:05 PM   #5
VonWegener
VonWegener's Avatar
That is correct. The L44649 (1-1/16" I.D.) and the L44643 (1" I.D.) fit the L44610 races which are stock Big Twin Harley and used with a very thin sleeve in those Triumph Timkin bearing conversion invented by JRC.
So if your Triumph has already been converted to Timkin type roller bearings you can substitute the existing roller bearings for the 1" I.D. L44643 bearing and run 1" stem front ends.
Old 09-29-2014, 04:51 PM   #6
Lester
Lester's Avatar
I'd go with a cheap and easy go get a hold of Jap front end and run it until you find a OEM set for a price that suits your pocket.
Lester
'62 DuoGlide Mine for 25yrs
'62 Triumph T-Bird in boxes
'83 BMW R100 commuter
'80's couple of Jap chops too
Old 09-29-2014, 05:13 PM   #7
Coco
Coco's Avatar
I am putting a 39mm Sportster (Showa) front end on mine. It was cheap and easy to find. Parts are available everywhere.
They look good too.
Coco is offline   Reply With Quote
Tags
forks, front end, suspension, swap, triumph
