Bolt-on hard-tail Problem - The Jockey Journal Board
Old 09-01-2014, 01:42 AM   #1
Swearfinger
Exclamation Bolt-on hard-tail Problem
Maybe I'm worrying too much but as you can see on this '74 Sporty, the holes for the exhaust support mount is drilled way off center. The Bird hard-tail is supposed to utilize these holes. I think I'm screwed. I think I may need to go the weld-on route, leaving me with a brand new useless bolt-on. My two concerns are;
1- That bracket will break under the stresses
2- The hard-tail wont fit right, or be tweaked
Do I need to get that filled in with welding and punch a new hole?
Any experienced recommendations are greatly appreciated. Thanks in advance!!!
The link below is to my pic album but it appears not to be working, it's in my profile, I will try to embed into this post ASAP.
Swearfinger is offline   Reply With Quote
Old 09-01-2014, 01:52 AM   #2
VonWegener
VonWegener's Avatar
Default Re: Bolt-on hard-tail Problem
It all depends on when in the assembly of the frame at the factory those holes were drilled. They maybe be in the right location but the bracket got on the frame wrong.
You need to compare the hole locations from right and left versus a known point on the front of the frame.
If the hole location is correct I would not worry about the wall thickness as long grade 5 bolts are used and tightenend to spec.
If the bolt holes are off maybe you can offset the holes in the hardtail?
Old 09-01-2014, 01:53 AM   #3
Swearfinger
[IMG][/IMG]
Old 09-01-2014, 01:55 AM   #4
C1340
I would not use it. Probably would fill it up and drill a new hole.
C1340 is offline   Reply With Quote
Old 09-01-2014, 01:56 AM   #5
Swearfinger
Thanks, VonWegener. My hope is that they are in the correct spot and that they wont crack under the stress of that hard tail. Aside from two bolts that mount to the top of the frame, those below are what get and keep the job done.
Old 09-01-2014, 01:59 AM   #6
Swearfinger
That seems like the safest option. Do you have a recommendation as to how to go about that? Grind that thin wall away and have a buddy weld across it or is it possible to fill the hole some way?
Old 09-01-2014, 09:33 AM   #7
highcomp
highcomp's Avatar
I'd cut or grind away the hole then weld it in. That's a quick easy fix.
The vultures are getting closer but I ain't dead yet
highcomp is offline   Reply With Quote
Old 09-01-2014, 09:39 AM   #8
natez1
natez1's Avatar
If it was me I'd run it. Bolt it up make sure everything is straight and square, use good hardware, then put a weld on the bottom side to the frame. Make it easy to grind off if needed. Easy, simple, effective.
natez1 is offline   Reply With Quote
Old 09-01-2014, 01:16 PM   #9
Swearfinger
Thanks for the input everybody. I measured it up and the holes are aligned. I guess they didn't weld frames using jigs back in the day. My crude-style measuring shows that the offset-holes are square to the frame. Those "exhaust mounts" were welded differently from each other. One is welded to the frame farther forward, so when they punched those holes, the one is offset. I think the best option is to do a hybrid of all your suggestions. High quality grade-5 hardware, bolt the tail on and weld it along the bottom where it meets the frame. Hopefully I wont find myself skidding down the road on a unicycle one day.
Old 09-02-2014, 07:54 PM   #10
jcs64
I would build up the back side of that boss w/ a little extra weld just so there was some more meat there. you will probably have to redrill the hole after welding since it will try to shrink the diameter.
at least that would give me a little pc of mind
jeff
jcs64 is offline   Reply With Quote
Old 09-02-2014, 08:18 PM   #11
bobscogin
A fond reminder of the AMF years.
Bob
Old 09-03-2014, 12:52 PM   #12
gasketscraper
Since most of the load will be to the top of the hole, I think you're fine. But if your nervous about it wrap some flat bar around the radius and fill both side of that with weld. I would still put some weld on the bottom joint after its bolted up.
Lets Hang Glide off the Fiscal Cliff!!
gasketscraper is offline   Reply With Quote
Tags
bolt-on, david bird, frame, hard tail, welding
