Bonneville & LSR Update - Page 12 - The Jockey Journal Board
Old 10-04-2014, 05:18 AM   #221
Truckedup
Default Re: Bonneville & LSR Update
Originally Posted by astek View Post
What tachometer are you using?
Equus electric tach. The bike crosses the finish at an indicated 7300 rpm in high gear at 125 with 4.66 overall gearing.
Old 10-05-2014, 03:24 AM   #222
astek
astek's Avatar
I never had luck with tachs, anybody knows a tach that can pick-up signal from a mag?
www.alpracingdesign.com
Old 10-05-2014, 03:27 AM   #223
Dan Boy
Dan Boy's Avatar
You mean like this Alp?
http://www.ebay.co.uk/itm/1-7-8-MINI...item417be44c39
D.
Blown Triple Build
Old 10-05-2014, 03:43 AM   #224
astek
astek's Avatar
Originally Posted by Dan Boy View Post
That one requires a 12v battery and does not work well with a mag. I would prefer a gauge with a built in battery.
Old 10-05-2014, 05:18 AM   #225
Truckedup
The 8000 rpm Equus tach I use works with 1-12 cylinders and does have an external inductive pick up like a timing light. But it does need a 12 volt power source and wrapped in foam to protect against vibration.
Old 10-05-2014, 09:10 AM   #226
little d
little d's Avatar
Astek,
look at the top, left product on this page; http://www.shop.morrismagneto.com/ca...2?categoryId=4
Or give Dave or his son a call, fax or e-mail; phone 973-540-9171, fax 973-605-8910,
Email: [email protected]
These guys go way above and beyond when helping others, if they don't have an answer, they will do research and get back to ya.
Old 10-06-2014, 12:31 AM   #227
Blown CBR
Blown CBR's Avatar
I have used these Astek, not flash, or accurate, but sure beats counting,,,,
http://www.ebay.co.uk/itm/Tiny-Tach-...item3a797b6b63
Tiny
Blown CBR is offline   Reply With Quote
Old 10-06-2014, 01:34 AM   #228
astek
astek's Avatar
Originally Posted by little d View Post
Astek,
I talked to Dave about that set up, he sent me one, you still need a external battery. I did try it, but the tach that i used was erratic and on a race bike like mine it was just too much stuff. Thank you for the suggestion.
Tiny
Thanks Blown CBR, this looks like a compact & simple solution, I like it! Did you run it on a magneto?
Old 10-06-2014, 01:38 AM   #229
Hoofhearted
Hoofhearted's Avatar
Mine is a Stewart-Warner. Its the only one I found that works on a single. Requires a battery though and being digital its a bit difficult to see. I have to change the mounting angle.
Old 10-06-2014, 03:25 AM   #230
Blown CBR
Blown CBR's Avatar
It has a black that just wraps around a TH lead astek, one wire, nothing to connect, internal battery, Iv'e had one for years, just sits on a shelf gathering dust these days,, the only trouble I has was it read 1/2 the rpm is should have, so I halved the red line too
Tiny
Old 10-16-2014, 01:36 AM   #231
astek
astek's Avatar
Hi all, El Mirage is this weekend. Who is coming? I am bringing two bikes;
I will see if i can get the 145.979 mph "Tatro Machine Special" fuel record from 1995.
I believe this is the fastest 650cc pushrod record on a naked bike?
Old 10-16-2014, 02:00 AM   #232
Hoofhearted
The best of luck Alp. Keenan's record will be a tough nut to crack. He wasn't afraid of nitro and ran it in fair amounts. I won't be there. My right knee is causing a lot of trouble right now. But I'll be rooting for you.
Old 10-16-2014, 02:16 AM   #233
astek
astek's Avatar
Thanks Bill, sorry about your knee! I hope it is nothing serious and you can be back for November's meet.
It has been 19 years and his record is still in the books, definitely a tough one to get.
Old 10-16-2014, 05:32 AM   #234
Truckedup
Tatro bike looks like half a Sportster engine....Man.that's an old record.. Alp,will your engine be burning something other than gasoline? How long is the El Mirage run, 1.3 miles?
Good luck!
Old 10-16-2014, 01:01 PM   #235
astek
astek's Avatar
Good luck!
Actually my engine is set-up for alcohol/nitro, ignition timed accordingly. The entire engine is aluminum with dual GP carbs, fuel supplied by two matchbox floats. I made custom size jets. I do not want to lean out, they say with nitro, when something is wrong the aluminum melts.
Yes, it is 1.3 miles.
I need luck! Thank you.
Old 10-16-2014, 02:27 PM   #236
Hoofhearted
Alp, What did keenan run for the 650 record? When I raced with him he had the "half a Harley" as a 500. I spent a couple of seasons chasing his gas record without success. And watched him waste a bunch of motors trying to run 150 with a 500. He also ran a flathead Harley in the vintage class I never realized he ran in the 650 class.
Old 10-16-2014, 02:37 PM   #237
astek
astek's Avatar
He has two records in the 650 classes, I don't know what he was running.
Old 10-24-2014, 06:24 AM   #238
Truckedup
Did you make it to El Mirage?
Old 10-24-2014, 12:10 PM   #239
astek
astek's Avatar
The engine wasn't running fine, I stopped around 105mph, The aftermarket steel magneto gear was causing problems, I replaced it with a stock fiber one.
The M frame bike went 126 on a 129 aps-vg record. I couldn't get to run more than once this time.
I dissasembled the whole bike/engine. All looks ok except the magneto gear.
Old 10-24-2014, 01:01 PM   #240
Hoofhearted
I saw the results last night on the SCTA site. Good run with the vintage bike. Hard luck on Keenan's record. He set some tough ones. What were you running for fuel? Going to give it another shot in Nov.?
Tags
alp, bonneville, pre unit, salt flats, triumph
