fouled plug on #2 everytime - The Jockey Journal Board
Old 05-18-2011, 11:10 AM   #1
jkrzmarzick
Default fouled plug on #2 everytime
maybe y'all can help. i have 650 triumph tiger - single carb, boyer ignition and 6v coils. without fail, i seem to foul the plug on #2 every time i ride it. i've tried cooler plugs and hotter ones..... same result. it doesn't smoke/ burn oil and is timed right. my only guess is that it's valve related since it's a single carb bike and #1 is just fine. any ideas / suggestions?
jkrzmarzick is offline   Reply With Quote
Old 05-18-2011, 12:11 PM   #2
dfauerbach
Default Re: fouled plug on #2 everytime
bad rings on that jug? or like you mentioned sticky valve
dfauerbach is offline   Reply With Quote
Old 05-18-2011, 12:12 PM   #3
compression, then leak down test. this will give you a idea if there is a cylinder problem...if they are balanced it may help point into the direction of a valve or head (behind valve) problem...possible guide.
..just make sure you have the front wheel against the wall before you do the leak down test.....
Old 05-18-2011, 01:09 PM   #4
jkrzmarzick
thanks fellas. much appreciated. i know how to conduct a compression test, but what exactly is a "leak down" test?
Old 05-18-2011, 04:52 PM   #5
Glider
Bad rings or bad guides (or both!).
When people who should have known better cautioned me about the dangers of motorcycle racing I told them that a fear of death is nothing more than a fear of life in disguise.
Glider is offline   Reply With Quote
Old 05-18-2011, 10:53 PM   #6
before you pull the head off, it could be something as simple as a bad plug wire, just for fun switch the wires and see if it moves the problem
Old 05-19-2011, 01:55 AM   #7
http://www.youtube.com/watch?v=GvG22YMOzUI
650, fouled, issue, plug, single carb
