Inner Fork Tube Cleaning - The Jockey Journal Board
Old 05-22-2011, 01:04 PM   #1
Chevota
Chevota's Avatar
Default Inner Fork Tube Cleaning
Anyone have a good way to clean the inside of the fork tubes. Took a 72 bonny setup I bought recently and tore it down to replace fork seals and the 0-rings and found that the inside of the tubes were full of surface rust. I can guarantee that the 0-rings wont appreciate it. Just need a good way to get in that diameter all the way to the bottom to clean em up. Ideas? Also, have surface here and there on the upper and lower springs... is it worth blasting these?
Chevota is offline   Reply With Quote
Old 05-22-2011, 01:06 PM   #2
Scavenger
Scavenger's Avatar
Default Re: Inner Fork Tube Cleaning
Round Brass wire brush ,, they make bristle brushes for inside tubes
Du doch nicht!
Scavenger is offline   Reply With Quote
Old 05-22-2011, 01:15 PM   #3
Chevota
Chevota's Avatar
Awesome... I'll just search for ones the right diameter. Hope that's all it takes to clean these up. Don't want to have to get new tubes.
Old 05-25-2011, 08:31 PM   #4
OGGandhi
Plumbing supply-They sell round bore brushes to clean boiler tube.They are good because you can get them at different lengths.Also they come in steel,brass,bronze etc.
OGGandhi is offline   Reply With Quote
Old 05-25-2011, 08:46 PM   #5
lackluster
lackluster's Avatar
I just cleaned mine up. Didn't have any brushes, but I had a tiny junked cylinder hone that I welded some 1/4 rod onto to make it really long. Worked like a champ and they cleaned up beautifully.
lackluster is offline   Reply With Quote
Old 05-25-2011, 10:04 PM   #6
Chevota
Chevota's Avatar
That may work out too. Good idea. Once I find a brush the right size I'll use it to knock the bigger stuff off and finish it with a small cylinder hone. Thanks Lackluster
Old 05-26-2011, 08:12 AM   #7
scrambled beezer
Boiler brushes
Check McMaster and all of your normal industrial supply shops.
scrambled beezer is offline   Reply With Quote
Old 05-26-2011, 08:42 AM   #8
Chevota
Chevota's Avatar
That's exactly who I'm ordering one from if my Dad doesn't have the one I need at his shop. Thanks
Old 05-26-2011, 08:47 AM   #9
MACDADDY!
I have spun some scotchbrite with a coathanger rod in a drill...worked well!
MACDADDY! is offline   Reply With Quote
