Opinions on cam choice for Twincam - The Jockey Journal Board
Old 08-30-2012, 06:45 PM   #1
misfitJason
misfitJason's Avatar
Default Opinions on cam choice for Twincam
for starters the bike is a 06 dyna efi with the hydraulic tensioners and six speed trans. Satge 1 kit (ac, and pipes) fuelpak, 25mm injectors. I am changing out the cam roller bearings and putting in a baisley hi-flow oil pump spring. I figure that I should do cams while in there. I am not doing headwork or anything else right now to the bike. Stockish is dependable right. Dependable fun is key here. I have been looking at a couple of cams that don't require a change in valve springs or crazy lift. Andrews 26h, Screamin Eagle 204, S&S 583ce easy start cams. I have found decent prices for the s&s one that put the cams bearings and install kit with gasket right at 284.99. Any opinions would be helpful or suggestions. Thanks
wow.....didn't really see that coming
misfitJason is offline   Reply With Quote
Old 08-30-2012, 06:52 PM   #2
Lee H
Default Re: Opinions on cam choice for Twincam
One word answer...WOODS...
I would not even consider another company for off the shelf cams, right now. IF I was going wild with a twin cam, I have a friend at RB Racing, and they have a deal with Branch heads. I would have them custom grind cams for what I wanted
Lee H is offline   Reply With Quote
Old 08-30-2012, 09:19 PM   #3
old.wrench
old.wrench's Avatar
Well, its been close to ten years since I've done much with the Twincams, when they first came out we were doing a lot of experimenting with them, but anyhow back then in a light bike like a Dyna I had good results with Andrews TW 50 cams and a compression bump when sticking with the stock heads. That combination made for a suprisingly impressive performance increase for not much money, especially considering no headwork. That combination would put you in the low to mid 12 second range in the 1/4 mile, but still run real nice all day long on the highway. I wouldn't go that route with a heavier touring model, but on the Dynas it worked real good. Like I said, its been a while since I've done much with Twincams but I think Andrews still make the TW 50's. Just throwing out an idea for you.
Regards,
Geo.
Old 08-30-2012, 09:50 PM   #4
choptop37
woods is the way to go..the555 or 777 make really good power with head work and a good fuel map, but if you really think your not gonna go farther later you might be suprised with the andrews 26 or 37 depends on how you ride, of course this could turn into a real nasty o/t thread real fast so ill put it like this: the bagger customers with big heavy turds that dont ever want to go 100 love the tw26s they run really good. i just did one with a good tune that made 80 foot-lbs at like 3500rpm 96ers with headwork wil make 95 foot lbs early,really good spread up to 5000 rpm. if you want a little more rpm and a lighter bike like the dyna the 37s make a little more power and rev out more. again the woods i think are king but thyre pricy for most people andi think you really need the compression and head work to take advantage of them. i just did a 107 with woods 555 cnc heads and p/c 5 it made 121 ft-lbs but it was 2500 in parts..you could jamb an andrews in there with pushrods for around 400 bux and get a lot of bang. just my 2 cents.
choptop37 is offline   Reply With Quote
Old 08-30-2012, 10:00 PM   #5
misfitJason
I looked at the woods and I was shocked how much those cams go for. I liked the s&s and it shows that the powerband is from 2000-4500 which is primarily where I stay. I just street the bike. Not looking for absolutely max power. I also like the built in compression release function on the 583ce cams for down the road if a big bore kit comes to mind. I already picked up a set of screamin eagle adjustable pushrods for a score. I assume I could use these pushrods for pretty much any cam unless it has really high lift.
Old 08-30-2012, 10:11 PM   #6
Loffer
Loffer's Avatar
Sure with heads and valves you can make some power but just cams ibdont think your gonna know if you noone told you their in there. The 96" are making over 90 ftlbs with a tuner and exhausts mods. That being said those mods cosy as much as cams even if you diy..
Old 08-31-2012, 09:33 AM   #7
pan620
I really like the S+S 510 grind
pan620 is offline   Reply With Quote
Old 08-31-2012, 10:24 AM   #8
Threadkiller
Threadkiller's Avatar
People usually think that bigger is better/faster. Earlier this year we did a '99 Dyna, so if you're just looking for more push from your butt dyno w/no headwork, I'd suggest Andrews 21's. "Lame" specs/numbers I know BUT, the fun factor is from idle to 80. FWIW, any cam realistically "works" for only a 3-3500 RPM band. TK.
I'm not saying I'm Batman, I'm just saying that nobody has ever seen Batman & me in the same room.
Threadkiller is offline   Reply With Quote
Old 08-31-2012, 11:14 AM   #9
slim55g
slim55g's Avatar
Now I run an 04 ultra, before I did the head work I ran a SE204, waste of money imo, I did the SE255 with the v/h fuel pack, exh & ac like buying a new bike, then did the big bore & heads, turns 100/112 hp/torq I open eyes when my geeezzzer glide runs the front wheel otg for 200' . I cant speak for a dyna, but good torq & steady pull through 6000rpm's
slim55g is offline   Reply With Quote
Old 08-31-2012, 05:43 PM   #10
grynder
I have a 06 dyna. After a basic stage 1 I did Andrews 37's. They are great street cams and woke the bike up nicely. I eventually ported the heads, put 10.5.1 pistons in and went to a 95" motor which I'm still running. Its a fun bike to ride for sure.
grynder is offline   Reply With Quote
Old 09-02-2012, 12:08 AM   #11
misfitJason
I will take a peak at those Andrews
Old 09-02-2012, 12:13 AM   #12
Lee H
and those who think this are correct...
Old 09-03-2012, 11:27 AM   #13
grynder
Originally Posted by Tattoo View Post
Not really, Not if you ride a lot. The more that a motor is built the more problems you will have with it.
Exactly. For a big twin my 95" motor is perfect. It will stand straight up if I want it to but it will cruise all day on the highway at 70-80mph as well-even 2 up. It has plenty of go to dodge old lady's and texters but not so much that I'm constantly breaking parts.
Old 09-03-2012, 12:21 PM   #14
Lee H
I have over 20,000 on my 129 inch nitrous burning stroker... I ride it to the dyno shootouts, and then back home, and since selling my pan last winter, I have been using it for a daily rider
My problems were 3 primary chains in 3 years, when I was trying to keep it looking like a sleeper. Once I went with the belt drive, problems went away
bigger is relative to the builder. If you try to go big with factory parts, you should not be building engines. If you are going to go big, do it right
Old 09-03-2012, 05:33 PM   #15
mrpoizun
mrpoizun's Avatar
For the rpm range you want, I'd go with Andrews' TW21. People who have it love it and it's easy on the valvetrain and the fuel mileage. That S&S 583 has some crazy specs- 203 duration on the intake and 262 on the exhaust! Hard to believe a bike with that cam would run worth a damn. I assume that's S&S' version of an EPA cam.
mrpoizun is offline   Reply With Quote
Old 09-03-2012, 05:44 PM   #16
Lee H
How many years has that bike been together?
I finished it just before the 2008 Salute to America rally (I worked bar security at the rally... I work a lot of the biker events that benefit veterans)
I also had another bike, at the time. That one was a 65 pan frame, with a 103 inch engine. It had evo flywheels in shovel cone cases, with STD pan heads. Evo bottom ends are wider then shovels, so you have to use shovel crank pin, shovel bearings and rods. I rode that bike for over 10 years. I built it to ride cross country to datona in 1996...
my wife decided she liked the hot rod better and a friend wanted the pan
Old 09-05-2012, 02:36 PM   #17
slim55g
slim55g's Avatar
I dont know, but my bullshitmeter is tweekin off the chart right now..... Please explain further.
Old 09-05-2012, 03:43 PM   #18
Early Iron Motorcycles
Early Iron Motorcycles's Avatar
I would go with S&S 510 cams if your not doing head work, they work good in small motors with stock heads, also you don't need easy start cams with stock heads, so you can save some money by useing the standard S&S cams.
Mark.
Early Iron Motorcycles is offline   Reply With Quote
Old 09-05-2012, 04:48 PM   #19
Slabside Mike
My .02, Dave Mackie 514. No spring work and designed for stock heads with no flow work. At 80 mph you can pass an 18 wheeler and not have to downshift.
I love mine.
Slabside Mike is offline   Reply With Quote
Old 04-23-2013, 01:12 AM   #20
misfitJason
Well I finally picked all my parts. I ended up going with 203 cams, screamin eagle adjustable pushrods, better cam bearings, baisley spring, se clutch spring, comp cams 850 lifters, and 95 inch bore cylinders and pistons. Now I just need to get all the stuff in there
