Removing Chrome... Secrets Revealed Pics and Video - The Jockey Journal Board
Old 05-24-2009, 01:58 PM   #1
Marco.Creep
Marco.Creep's Avatar
Send a message via AIM to Marco.Creep
Default Removing Chrome... Secrets Revealed Pics and Video
I hate chrome and bad chrome is even worse...Ive searched the internet for years for a way to remove chrome and came up with nothing Its been discussed over and over But as of yet no soulution except having it chemically stripped, which is just as expensive as having it plated. Ive tried sanding...Dont Work! Muratic Acid...Dont Work!
But I finally got it. All you need is some F'ed up Chrome, a razor blade, Jim Morrison, and some time. Its really amazing how easy this is and hardly any effort.
Picture:
Videos Click to watch:
http://www.machmodified.com
Marco.Creep is offline   Reply With Quote
Old 05-24-2009, 02:16 PM   #2
GrimeyGrim
Default Re: Removing Chrome... Secrets Revealed Pics and Video
I've been Doing the same thing to the shitty old Chrome on my Girder.
Talked to my powdercoater about it for a while and came to the same conclusion, while pulling off a few big flakes of chrome. It's a lot more tedious with the thin tube, than large flat surfaces,but works just as easy.
Tom waits is usually playin' around here,hah.
GrimeyGrim is offline   Reply With Quote
Old 05-24-2009, 02:31 PM   #3
alaskanrocket
alaskanrocket's Avatar
Now everyone go out and and dechrome everything until chrome is cool again. All kidding aside, good post.
alaskanrocket is offline   Reply With Quote
Old 05-24-2009, 03:19 PM   #4
Marco.Creep
Quick spin on the buffer and lookin nice again.
Old 05-24-2009, 04:45 PM   #5
Underworld stevo
Underworld stevo's Avatar
Quote: But as of yet no soulution except having it chemically stripped, which is just as expensive as having it plated.....
Expensive having chrome stripped....and they charge you for that? You need to talk to them about that - and build up some sort of rapport with them - it'll save you a lot of time if you need to strip chrome often!
We can go to our chromers here, hand them the stuff then stand around telling jokes for 10 - 15 mins while they electrically dip (reverse current) and strip it while we watch & wait - and it's always free....they know we'll be back to have chrome done soon enough and wouldn't think of charging for such a quick & simple procedure.
Of course I always comment to them as I'm leaving, that there's no charge for the chrome they just gained off my old parts....ha.... and I throw them a few cases of beer at xmas.
I/G: straightleg_steve
Underworld stevo is offline   Reply With Quote
Old 05-24-2009, 04:59 PM   #6
Marco.Creep
Its illegal to chrome in NY because of the caustic chemicals, so all chroming has to be shipped out of state. Its would be nice to have a local guy to go to and build a rapport with, but even the locals that chrome ship out of state, or the few illegal spots that do chrome...wont cut ya a deal...well because why should they, where else ya gonna go.
Old 05-24-2009, 05:18 PM   #7
38knuckle
38knuckle's Avatar
i use muratic acid and a bead blaster. i blast it first then let it sit in muratic. then blast again then continue the process till it's done. thats for small parts of course. nothing like crash bars or big parts. thanks for the tip, i'll try it. chromers here charge my ass to strip the big stuff.
38knuckle is offline   Reply With Quote
Old 05-24-2009, 05:48 PM   #8
Underworld stevo
Sorry Marco - If I'd been awake and sharp enough, I'd have seen you were on LI.
I lived on "the Island" for a while - and yes you are right, getting anything chromed or finding a decent plater there is next to impossible - we sent stuff to Jersey where apparently, the inspectors are too frightened to check up on chemical discharge anymore - the ones that did, we heard, ended up in the river.....but the plating was good.
Old 05-24-2009, 06:37 PM   #9
RYZART
RYZART's Avatar
Chrome rules !!!!
www.ryzart.com http://ryzart.blogspot.com/
www.neveragainclothing.com
Helping dudes get laid since 2001
RYZART is offline   Reply With Quote
Old 05-24-2009, 07:40 PM   #10
Osprey
Osprey's Avatar
Glass bead is the cheapest and probably the best.
Osprey is offline   Reply With Quote
Old 05-24-2009, 09:17 PM   #11
justin m.
justin m.'s Avatar
I had flaking chrome and light pitting on my shovel rocker boxes...used a razor as far i could then polished the rest. I was unhappy the polished aluminum didn't match. So, in the end, I just took em to plating place, charged 50 to remove in one day turnaround.....Super clean, then just sanded and buffed and polished....
all in all getting it stripped professionally has the best result
justin m. is offline   Reply With Quote
Old 05-24-2009, 10:22 PM   #12
swellguy
swellguy's Avatar
In my case there's a local iron shop that has a media blasting cabinet anyone can "rent" for $16/hour. Really speeds things up for me, maybe there's a local shop near you that could do the same thing?
I used to be somebody, now I'm somebody else.
swellguy is offline   Reply With Quote
Old 05-25-2009, 07:27 AM   #13
Cotten
Chrome is evil.
Every piece is different, but occasionally the plating is so poor that it will wrinkle off in leaves when blasted with steel shot. It has a hammering effect that literally expands the layer of plate to loosen it from the parent metal.
It leaves a finish resembling sand-cast, much better than just beads or even sand itself. Aluminum is easiest to strip and texture.
But there is usually some spots where plating sticks tight, and it must be ground through first with a sanding roll or something, as even aggressive aluminum oxide media will cut the softer metal first, leaving the tough plated area elevated, and ugly, even when it does finally come off.
Did I mention that chrome is evil?
....Cotten
Cotten is offline   Reply With Quote
Old 05-25-2009, 08:46 AM   #14
WhiteFox
Does brake fluid work? I remember my father spilled some on his chrome bumper of his old Subaru GL hatch, and the chrome bubbled up.
WhiteFox is offline   Reply With Quote
Old 05-25-2009, 11:47 AM   #15
Cotten
Probably, if it is chromed plastic!
....Cotten
Old 07-29-2009, 04:04 PM   #16
pat english
pat english's Avatar
Default pool acid
i got this manifold.the crome is chipping off.i tryd sandblasting it and 90% of the crome came off.
a guy told me try mixing 50/50 pool acid,water and that should take the rest off.anyone ever tryd this on somthing aluminum?
pat english is offline   Reply With Quote
Old 07-29-2009, 04:06 PM   #17
Hippi
Default Re: pool acid
you mean lye?
Hippi is offline   Reply With Quote
Old 07-29-2009, 04:25 PM   #18
pat english
no i mean muriatic acid (pool acid)ive used it to clean rust out of gas tanks(works very well.just dont leave it in too long cuz it will eat the metal),never tried it with aluminum though thats why i was asking if anyone has done it before
Old 07-29-2009, 04:30 PM   #19
foureasy
foureasy's Avatar
test it out on an L series carb
foureasy is offline   Reply With Quote
Old 07-29-2009, 04:33 PM   #20
gapwelder
gapwelder's Avatar
I've used the process in the Caswell manual to strip chrome off metal with good results. (Sulfuric acid and water solution along with current). I have never tried the process with aluminum tho.... If it is a valuable part I think I would use acid only as a last resort. That shit can be dangerous, too. Will blasting not take the rest of the chrome off? That would be the simplest and safest way.......
gapwelder is offline   Reply With Quote
