Shovelhead timing problems - The Jockey Journal Board
Old 04-22-2009, 06:20 PM   #1
Sinner1
Sinner1's Avatar
Default Shovelhead timing problems
HELP! I picked up a 1983 Shovelhead engine last week and installed in in a friends bike who is waiting on his motor repair. We used a new points kit with all new parts and found that it has to be completely retarded ( turning plate all the way to the left while looking at it ) for it to kick over easy without kickback. It starts first kick, runs better then excellent but with a timing light I'm still to far advanced ( 10 degrees ). After a 30 minute ride I have oil coming out of all the lifter block base bolts ( 4 per side ) and out the fill cap on the oil tank. Maybe this is two different problems? I pulled the cam cover and everything lines up as I expected to find the cam one tooth advanced and the breather gear off one as well. Getting a little gurgiling noise as well when riding at the oil breather filter. No oil burning thru pipes and runs like the 1,000 miles it supposed to have on it. Now I'm totally lost on this one and hoping for a little help. THANKS!
Sinner1 is offline   Reply With Quote
Old 04-22-2009, 06:32 PM   #2
BIG WHEELS
Default Re: Shovelhead timing problems
fully advanced timing on a shovel is 35 degree's (piston at 7/16" btdc), how can you hear gurgling noises out of the breather when riding, must be pretty loud,
so it's still puking oil after you timed up the gears in the cone,?
BIG WHEELS is offline   Reply With Quote
Old 04-22-2009, 06:41 PM   #3
Bigincher
Bigincher's Avatar
It does sound like a couple things going on. Is the breather gear steel or nylon? Is it correctly 'timed'? Only way I know how to do that is with a timing wheel.
As for the ignition timing, have you cleaned and serviced the counterweights? Maybe they are stuck open; a fairly common problem when they are neglected.
Bigincher is offline   Reply With Quote
Old 04-22-2009, 06:45 PM   #4
jbfrmca
do the flyweights move freely. do they open up all the way. sometimes the aftermarket does'nt get it right. if that's good then i would take a small rat tail file and enlongate the slots in the points plate to get it to time right. like i said aftermarket. and as for the gurgleing i would'nt worry about that. it's just the oil that worked itself past the checkball. it should go away when you ride it for alittle while.
jbfrmca is offline   Reply With Quote
Old 04-22-2009, 07:00 PM   #5
Sinner1
Sinner1's Avatar
Wheels- My bro riding it told me he heard the noise but not sure when sorry. No more oil puking out the vent, only one time after original start up.
Bigincher- breather gear is steel and has the nylon spacer. New weights, starts first kick cold or hot and we should all be this lucky the way it runs, low idle and has steady beat and turned up about 800 rpm runs like clock work and going thru the gears, plenty of power. My bro is 6'11" and close to 350 lbs.
Dragstews- yes oil is returning to the tank, bike has about 1 hour ride time from stop and go to 55 mph. I run points on my other Shovel and the plate is just off center to the advance side and this is what gets me as this one has the plate pegged to the left and needs another few degrees. Timed motor with a light and clear plug.
JBFRMCA- the advance weights not being able to open all the way has happened to me before and I had to clean some material away from the inside of the cover to allow it to open all the way.I'll have my friend check it again tomorrow but don't really thing that's the problem as it would effect starting mostly and performance and again this thing really runs great, no smoking, plugs look excellent and performance is great.
I believe the two are tied together, I have neve seen oil push past the 4 bolts holding the lifter blocks to the case before and never used sealant on them either. Not all bolts leak from what I remember. After market lifter blocks... suppose the lifters are install incorrectly? Oil holes not lined up in the blocks would cause what? Thanks guys!
Old 04-22-2009, 07:03 PM   #6
Sinner1
Sinner1's Avatar
JBFRMCA, if I "take a small rat tail file and enlongate the slots in the points plate to get it to time right" am I covering up another problem or have you had to do this before? Maybe the cheap points plate is slotted incorrectly? I have an old original plate but the bikes 1/2 hour away so can't check now.
Old 04-22-2009, 08:31 PM   #7
Creepinogie
Creepinogie's Avatar
OK, I just took a few minutes to type an explanation of what is happening for sure and what may be happeneing elsewhere and it won't let me:
YOU DO NOT HAVE PERMISSION TO PERFORM THIS FUNTION. PLEASE LOG IN....I already am logged it! I thought this forum was about helping one another with motorcycles. I'm not retyping it. If your who I think you are in FLA then call me on the phone.
Creepinogie is offline   Reply With Quote
Old 04-22-2009, 10:09 PM   #8
gh8tor
The marks on the cam breather and pinion drive gear are there for a reason they should line up thats how the motor gets its timing for the breather opening as well as valves. I have heard of changing the breather timing by advancing 1 tooth but haven't needed to try it. As far as aftermarket points plate being wrong I would slot the holes second after correctly timing the cam and breather.
gh8tor is offline   Reply With Quote
Old 04-23-2009, 08:04 AM   #9
bustedlifter
As long as you're there, if you're running a belt or sealed off primary, get one of those S&S reed type breathers. No timing marks to line up and no gears to fail. I've been running one for a couple years and it performs flawlessly.
