Funny numbers ? - The Jockey Journal Board
Old 07-17-2013, 09:27 PM   #1
lilbill
lilbill's Avatar
Default Funny numbers ?
whatch'all think of these numbers ?
http://texarkana.craigslist.org/mcy/3927006312.html
RIP SwedeBobb
Old 07-17-2013, 09:59 PM   #2
iiggii
iiggii's Avatar
Default Re: Funny numbers ?
yup fishy.
CornBread mafia...
iiggii is offline   Reply With Quote
Old 07-17-2013, 10:08 PM   #3
Larry T
Larry T's Avatar
I don't like the way they look, but the fonts on the numbers look right, don't they? Not many stamp sets have straight back 6/9 and the 2 with the tail on it.
My old Panhead build: https://www.jockeyjournal.com/forum/s...ead.php?t=9455
Occasionally updated Knucklehead project: https://www.jockeyjournal.com/forum/a...p?albumid=3625
Old 07-17-2013, 10:33 PM   #4
greasystain
it could have been legally done by a harley mechanic repairing a case or replacing the case. do those years still have line bore numbers on the bottom?
greasystain is offline   Reply With Quote
Old 07-17-2013, 11:32 PM   #5
panheadmark
Maybe that was done on Friday after happy hour lunch! And rember hash was legal till 1970
panheadmark is offline   Reply With Quote
Old 07-17-2013, 11:35 PM   #6
JAWS
JAWS's Avatar
Odd number years had odd numbers for the first digit after the model.....65 is odd, but 2290 aint!
Or am I messed up?
Old 07-17-2013, 11:42 PM   #7
caschnd1
caschnd1's Avatar
Or am I messed up?
Yup. That's the dead giveaway. Those numbers are bogus.
-Craig
caschnd1 is offline   Reply With Quote
Old 07-17-2013, 11:47 PM   #8
caschnd1
caschnd1's Avatar
Or am I messed up?
-Craig
EDIT- the add says its a 66 so the first two digits must be 66. Looks like 65 in the photo but that may be a shadow. If that's the case, the 2290 after FLH is ok. These numbers may be fine. I found two other examples from 66 with straight back sixes.
http://www.vintageamericanmotorcycles.com/v/Numbers/
I'm more bothered by the cracks near the timing plug.
Old 07-18-2013, 06:33 AM   #9
HD48FL
Super Moderator
Bogus!
Old 07-18-2013, 08:45 AM   #10
Larry T
Larry T's Avatar
Originally Posted by Dragstews View Post
Hatch, you got good eyes..(At least for spotting a deal)...
Is that second number a five or a six...???
66 Shovelhead.
Old 07-18-2013, 09:19 AM   #11
Winston Wolf
I'd check the case numbers to see if they match. And look at the back top of the case halves, they should have an "H" stamped into each half if its an FLH. Does dude have a title that matches up?
Winston Wolf is offline   Reply With Quote
Old 07-18-2013, 09:36 AM   #12
slim55g
slim55g's Avatar
As a 66, I have no issue with those numbers, as a 65 however there is many ???. I would first look at the belly line bore numbers & then rear case halves motor mount. Then, does the title say 66 or 65? Kinda hard to jump to conclusions before a complete investigation is conducted. It may be completely legitimate, or not!!!
Honesty is doing the right thing for the right reason!!!
Integrity, is doing the right thing, when no one else will know !!!
slim55g is offline   Reply With Quote
Old 07-18-2013, 09:36 AM   #13
Larry T
Larry T's Avatar
Kinda drifting off topic, but there were folks that modified stamps to make straight back 6/9, probably still are. Anyway, they ground the leg off a curved 9 or the bottom off an 8 and used a 1 to make the straight back for the number.
If you look closely at the numbers on the polished 65 cases that Jesse posted, the 6 and the 9 are a little suspect. They look like they might have been stamped by two seperate stamps. I would probably pass on this bike before I passed on the numbers in the original post, although there's something I don't like about them too. Maybe grind marks?
Old 07-18-2013, 09:53 AM   #14
slim55g
slim55g's Avatar
If you go to the cl AD , blow up the pic, it looks like shadowing or grease/oil in the groove of the 6's if you look to the left of the vin pad, you will see the same lateral grooves. It is my opinion that it's the picture does not do it justice, the very same marks are on the case to the left of the pad, making it legitimate.
Old 07-18-2013, 10:14 AM   #15
MIKE47
MIKE47's Avatar
I'm no AMCA expert or HD history buff but those original posted numbers, at least from what I see i the pic without enhancement software look just fine. They look like typical factory "I had a couple beers at lunch" placement and spacing. Its a 66 so even number rule/straight back and the numbers boss looks even and raised about the right amount. If the belly numbers matched and didn't look tampered, the paper was in order, and the price was agreeable I'd not hesitate. If in doubt, have the guy go to DMV with you to do the paperwork. If anything is gonna come up it'll happen there. The police here will even do a VIN verification running the numbers through NCIC database to verify it's not hot if you ask nicely.
Forgot to add that the bike (engine anyway) is approaching 50 years old. So replaced and restamped cases are kinda gonna be a part of life for a good bunch of bikes out there that are available. Great craftsman that can do number job are hard to find. One with skill to do it near flawless even more so. But there's been a shit ton of "good" repair guys that can swap a case and clean/restamp a number pretty ok though. So if was a restamp and the numbers are clean and the paper is good then why not buy it. I understand that the resale to a collector or whatever may be price reducer but for a chopper or ridden bike?
47 Industries-Custom Bikes and Hotrods
WWW.47FAB.COM
MIKE47 is offline   Reply With Quote
Old 07-18-2013, 11:01 AM   #16
Tony the torch
Tony the torch's Avatar
it's a well known fact that dealerships stamped replacement cases all the time, (and there are still number sets available out there). the fact that those numbers don't look like they came from the MoCo does not mean the cases are stolen or even the numbers were illegally done.
There are instances where replacement Shovel cases are stamped with Pan numbers and no crime was committed.
If the numbers are not on the NCIC list, and an acid test does not show it's been altered, the paperwork matches those numbers then ......"Move along folks, There's nothing to see here".
Old 07-18-2013, 02:16 PM   #17
govmule84
Forum Dipshit
Probably true, but I don't want cases like that... there's an exception to every rule, this might be a time when being the exception is not a good thing.
Old 07-18-2013, 02:56 PM   #18
redasphalt3
redasphalt3's Avatar
Send a message via AIM to redasphalt3
isnt the acid test to see if the number boss has been welded on? If so, any case that has cracked and was repaired in that area would fail the test. I could be wrong though
redasphalt3 is offline   Reply With Quote
Old 07-18-2013, 03:07 PM   #19
Rem
Rem's Avatar
Looks like it needs rescuing from that frame, whatever its history . . .
Rem is offline   Reply With Quote
Old 07-18-2013, 03:17 PM   #20
Tony the torch
the acid test will show the molecular compression area of a stamped number, similar to a magna-flux crack signature
as I have been told by CHP the acid test is it is used injunction with a a photo enhancement program that ignores the existing numbers and will define compression areas of the previous numbers.
but if the cops find an altered vin area your done anyway, they will impound it as an "altered vin" even if they can't find an old number,
we all know it's against the law to alter a vin stamping even it it ain't stolen.
but dealer stamped cases are not altered.
