homemade leaf spring frontend - Page 2 - The Jockey Journal Board
Old 07-14-2006, 09:13 AM   #21
Moonshiners
Default Re: homemade leaf spring frontend
Originally Posted by Danny F.
All great stuff, as long as you don't mention the "Leaf Springer"...WTF..!!!
(this was 1997)
hahahahahahahahahahaha - Oh man seeing that made my day!
That's gotta handle worse than anything i've ever seen! oh don't get me started... hahahaha....
Moonshiners is offline   Reply With Quote
Old 07-14-2006, 09:29 AM   #22
sumo
sumo's Avatar
i was thinking about getting myself a set of them untill ou all started mocking... best not get them now then if everone will take the piss... ha ha
sumo is offline   Reply With Quote
Old 02-12-2011, 03:35 PM   #23
Panshowa
Itīs quite easy to DIY, if you own a lathe, pipe bender and tig. Hereīs mine:
Panshowa is offline   Reply With Quote
Old 02-12-2011, 03:39 PM   #24
Destralo Roach
Moderator
Destralo Roach's Avatar
Nice!!! You have some good details going on there!!!
Old 02-12-2011, 04:19 PM   #25
theageofindustry
theageofindustry's Avatar
I was just thinking what a car wreak leaf springers look like on bikes and than you had to go and trump me. All the right stuff in all the right places.
theageofindustry is offline   Reply With Quote
Old 02-12-2011, 07:29 PM   #26
TurboRoadster
TurboRoadster's Avatar
looks like its set up to pull down, reckon the top leaf doesnt do much.
looks nice, any advantage or preference for pushing up or pulling down? basically rim location on rocker changes that.
www.ConroePowderCoating.com
JJ member discounts 832-818-3905
[email protected]
Highway HorrorS cc
TurboRoadster is offline   Reply With Quote
Old 02-12-2011, 08:37 PM   #27
rgf
rgf's Avatar
bastybikes fab this (hand made)
rgf is offline   Reply With Quote
Old 02-13-2011, 03:50 AM   #28
gearhead1951
Turbo , even on the stock Indian version there is a leaf (or 2) that are in there to be "rebound" springs !!
gearhead1951 is offline   Reply With Quote
Old 02-13-2011, 05:51 PM   #29
el diablo
el diablo's Avatar
don't buy the ones from ebay from Rich Philips ....do a search here on the JJ for those
all fucked up leafer for way to much money ...and he didn't dealt with the guy who got the F#CKED UP leafer that R.philips made
el diablo is offline   Reply With Quote
Old 02-13-2011, 06:52 PM   #30
TurboRoadster
ah ha! thanks!
[email protected]
Highway HorrorS cc
Old 03-15-2012, 09:10 PM   #31
BIG JD
hey man great job on that front end where did you get plans from? i'm interested in building one myself , any help with blueprints would be appreatiated cheers JD.
BIG JD is offline   Reply With Quote
Old 03-15-2012, 09:31 PM   #32
iflybyu
Very Nice
iflybyu is offline   Reply With Quote
Old 03-15-2012, 10:07 PM   #33
billyfly
billyfly's Avatar
billyfly is offline   Reply With Quote
Old 03-17-2012, 05:02 PM   #34
greasystain
dang that last one is sweet. the spring sits a bit far out front tho for my tastes, but hell yeah.
greasystain is offline   Reply With Quote
Old 03-17-2012, 05:54 PM   #35
twowheeledhell
twowheeledhell's Avatar
+1 on that......the spring action likely depends on length, and relation to where strut is located on rocker (angle) to pivot on the spring-maybe you can start pulling it back some as you go-the shorter the stiffer the action should be as well-or could change leaf sizes. Otherwise looks like it's off to a good start.
Justen
Here for the same reason as you-but not the same as some others.....
Justen @ Nipple Twisters Wheelcraft
Genoa City, WI
[email protected]
twowheeledhell is offline   Reply With Quote
Old 03-17-2012, 06:01 PM   #36
billyfly
billyfly's Avatar
Justen
thats the plan...better long to start!...billy
Old 03-18-2012, 01:52 AM   #37
Friday
those panshowa forks look good. heres some plans for leaf forks. theyre CHB
http://mantaraygraphics.com/leaf.html
Friday is offline   Reply With Quote
Old 03-18-2012, 02:36 AM   #38
worn
worn's Avatar
(this was 1997)
This was in a show here in Toronto '70 or '71
Name:	Warren Slde 3200dpi 015.jpg
worn is offline   Reply With Quote
Old 03-18-2012, 10:35 AM   #39
Jeff L
Jeff L's Avatar
I dont think you will change much by shortening that spring.You might find it better to set the length of spring where you want it, then experiment with ride by adding or subtracting springs above or below main spring for shock & rebound.
Jeff L is offline   Reply With Quote
Old 03-19-2012, 04:02 AM   #40
chipmcluk
chipmcluk's Avatar
Picture links broke on the other thread.
chipmcluk is offline   Reply With Quote
