might have made myself an ordeal.... - The Jockey Journal Board
Old 04-24-2010, 08:45 PM   #1
shagy
shagy's Avatar
Default might have made myself an ordeal....
I bought a rear wheel (the cast type) off of a deuce... nothing fits that damn thing the lip in the center of the wheel measures 2.21" so nothing from my sporty changes over.
Are the chain sprockets and brake rotors that hard to find or am I not looking hard enough?
As of now I'm thinking about machining out the center of the rotor and sprocket I have.
shagy is offline   Reply With Quote
Old 04-24-2010, 09:13 PM   #2
skinthead
Default Re: might have made myself an ordeal....
Yeah, the Deuce is an oddball. Nothing fits anything else from a deuce to another bike, and vice versa. If it ain't a deuce you will have to make it work....
skinthead is offline   Reply With Quote
Old 04-25-2010, 12:44 AM   #3
shagy
shagy's Avatar
figures....
Old 04-25-2010, 07:29 AM   #4
M.O.Ther
M.O.Ther's Avatar
It's also a problem working with stuff from different centuries. The Deuce is from this century, and if your Sporty is pre 2000, there's another problem.
In theory there is no difference between theory and practice. In practice there is. Yogi Berra
M.O.Ther is offline   Reply With Quote
Old 04-25-2010, 02:17 PM   #5
Destralo Roach
Moderator
Destralo Roach's Avatar
Yep, all 2000 and later wheels have the bigger spigot hole, so you need to use the later disc, and machine out the spigot hole on a sproket to fit for a chain drive, with a rear belt, just yse the 2000 and later rear pully...And you will have to take down your Axel by about a .001 to fit the seald bearings.....And if your putting it on a sporty, you have to machine off 1/4" from the drive side so the sproket will line up....Roach.
Old 04-25-2010, 05:11 PM   #6
shagy
shagy's Avatar
I might have a rotor to fit but I'm gonna machine the sprocket. The 3/4" axle fits so Im good there. Its going on a hard tail so there are a lot of things coming into play.
