Home made workshop tools - Page 3 - The Jockey Journal Board
Old 09-27-2008, 02:10 PM   #41
Rasmussen
Rasmussen's Avatar
Great thread!
Worlds simplest wheel truing stand. If you`re just building a single or more similar wheels there`s really no need to go further than this. A piece of rod (old wheelaxle) welded onto a piece of square tubing:
Simple press. Not very sturdy but good enough to press the crank out of a shovel
Rasmussen is offline   Reply With Quote
Old 09-27-2008, 04:14 PM   #42
ca180
ca180's Avatar
http://home.comcast.net/~t.molnar/ShopPress.htm
http://www.jalopyjournal.com/forum/s...d.php?t=169271
................................. ___
.................__________|___\____
..;.;;.:;:;.,;.|__(O)____|____/_(O)|
ca180 is offline   Reply With Quote
Old 09-27-2008, 04:18 PM   #43
ca180
ca180's Avatar
Here's some crimping pliers
Thought this was kinda cool, airplane building use, but could come in handy
Old 09-27-2008, 04:53 PM   #44
ca180
ca180's Avatar
Here's another I found... Pretty good idea for doin exhaust
Old 12-22-2008, 03:31 PM   #45
jason43
jason43's Avatar
I made a sweet metal hammer out of one of these gas canister caps...
All you have to do is put a peice of one inch OD pipe through the holes in the cap and weld it up, I used about a foot long handle and it works great as a hammer and as a dolly too. The best thing is that it cost me $10 from tractor supply and took about 5 minutes to make. Already straightened out an old fender and made a seat pan with it. Works like a champ...
"They're gonna talk to you, and talk to you, and talk to you about individual freedom. But they see a free individual, it's gonna scare 'em."
jason43 is offline   Reply With Quote
Old 12-22-2008, 10:07 PM   #46
alaskanrocket
alaskanrocket's Avatar
Originally Posted by F.St.M. View Post
I got a homemade wheel truing stand:
I got a homemade clutch hub puller:
And last but not least, I got a homemade phase converter so I can run my 3-phase mill & lathe off of residential 220 juice:
The Three phase converter...Holy shit.
alaskanrocket is offline   Reply With Quote
Old 12-23-2008, 12:31 AM   #47
cretin
cretin's Avatar
I'm not understanding what's going on here. What am I missing?
Wanted: 2 Velocity stacks with brass screen for Amal 389's
Please PM me
Older.....Budwiser
cretin is offline   Reply With Quote
Old 12-23-2008, 12:52 AM   #48
tobiism
tobiism's Avatar
Its for welding exhaust tubing together. The open spot in the clamp is where you make your spot welds.
tobiism is offline   Reply With Quote
Old 12-23-2008, 12:57 AM   #49
cretin
cretin's Avatar
Haha thanks. that makes sense
Please PM me
Older.....Budwiser
Old 12-23-2008, 06:56 PM   #50
Slabside Mike
Some torque converters made from sockets and wrenches bought at a pawn shop for $11. Makes retorquing head bolts on a Shovel a breeze.
torque extensions
Slabside Mike is offline   Reply With Quote
Old 12-23-2008, 07:25 PM   #51
Yamaha_chop
There's a lot of them out there, but here's a tubing bender I built:
Pay no attention to the tubing in that photo, I just used thin wall tubing to make sure it would work. It built my frame like a champ. Plus I really liked having the air/hydraulic ram, super easy to get exact and repeatable bends.
Yamaha_chop is offline   Reply With Quote
Old 12-23-2008, 07:32 PM   #52
lairdog
lairdog's Avatar
Geesus dont they have building codes in Alaska?
dang, Conduit isnt that expensive. nice going otherwise on the "IN"verter
lairdog is offline   Reply With Quote
Old 12-24-2008, 12:56 AM   #53
Grease Rag Rob
Grease Rag Rob's Avatar
That tubing bender is way badass
Grease Rag Rob is offline   Reply With Quote
Old 12-24-2008, 01:28 AM   #54
tegulevi
I made a pretty handy litle invention today. i made a flange that mounts the top half of a shopvac directly onto a 55 gallon drum. definately decreases the power but still works great
tegulevi is offline   Reply With Quote
Old 12-24-2008, 04:47 AM   #55
BIG WHEELS
g/box mainshaft nut socket, made with a piece of tube i had laying around and a piece of 1/4" plate drilled and filed to the size of the nut, then welded to the pipe, hole drilled in the pipe to take a tommy-bar,,
BIG WHEELS is offline   Reply With Quote
Old 12-24-2008, 12:20 PM   #56
bhead1968
bhead1968's Avatar
not home made...but it works...
bhead1968 is offline   Reply With Quote
Old 01-04-2009, 11:45 AM   #57
Tan-Dawg
Tan-Dawg's Avatar
Just completed my frame fixture...
Tan-Dawg is offline   Reply With Quote
Old 03-26-2009, 01:12 AM   #58
chopperkid13
chopperkid13's Avatar
Send a message via AIM to chopperkid13
My simple valve guide removal tool. A long shank bolt that fits nicely in the guide and a nut ground to the O.D. of the guide. Grab you BFH and start hammering!
"It feels nothing like, how violent it looks from the outside. It's very serene." -Shinya Kimura.
thejadedandfaithless.tumblr.com -Choppers, chicks, hot rods, and other shit.
chopperkid13 is offline   Reply With Quote
Old 03-26-2009, 02:55 PM   #59
shagy
shagy's Avatar
I have a jiffy stand I made out of some 2x4s screwed together, a pipe and a pipe flange..... It looks ugly but gets the job done.... kinda like a fat chick after midnight
shagy is offline   Reply With Quote
Old 03-27-2009, 01:51 PM   #60
Syco-Billy
Originally Posted by Rasmussen View Post
Great thread!
Attachment 34201
Attachment 34202
Was about to build a trueing stand of "usual" design this weekend. Seeing this definetely changed my mind and saved a few hours of fabbing....Thanks! Gonna modify it a bit to use it as a balancing stand also. Using a hunk of 3" angle insteade of tube cause I have it available....Thanks again.
Syco-Billy is offline   Reply With Quote
