Mikuni VM38 Support - The Jockey Journal Board
Old 05-20-2017, 05:59 PM   #1
vinlesposito
vinlesposito's Avatar
Default Mikuni VM38 Support
Does anyone have a good solution for supporting a VM38 on a big twin? I was thinking of modifying an older support that I have to sit under the fuel bowl drain bolt.
72 Triumph TR6R
61 Triumph Bonneville
69 Shovelhead/53 Wishbone
vinlesposito is offline   Reply With Quote
Old 05-20-2017, 06:15 PM   #2
Default Re: Mikuni VM38 Support
They are a very Light Carb & I know it's not recommended, but I ran one for 5 years with no support and had No Problems with air leaks or anything,, I think it was partially supported by the fuel line,.... as I said, not ideal but it worked fine.
Old 05-20-2017, 06:52 PM   #3
nmaineron
Could you drill through the bottom bowl drain and tap a 1/4" stud in.You could go to the center case stud.
nmaineron is offline   Reply With Quote
Old 05-20-2017, 07:47 PM   #4
geezer
geezer's Avatar
I ran a bracket bolted the center case stud to a bolt in a hole drilled into the back of the air cleaner. I also ran one unsupported on my '68 XLCH. Did have to carry a screwdriver to reinstall it if the engine backfired and popped it out of the manifold too.
Patina doesn't come in a can........
geezer is offline   Reply With Quote
Old 05-21-2017, 10:30 AM   #5
Tim The Grim
Tim The Grim's Avatar
Silver solder a 1/4-28 nut to the bottom face of the float bowl drain plug.
Clean out the threads with a bottoming tap. Cut off a 1/4-28 screw and dress the end. Thread in the stud with permanent thread locker and fab up a bracket to the center case through stud.
I used two thick washers brazed to a 5/16 rod.
'54 KHK, '76 XLCH (sold), '13 XL72 Hard Candy, '96 Valkyrie. Retired
Tim The Grim is offline   Reply With Quote
