Pan rigid frame question??????? - The Jockey Journal Board
Old 01-22-2011, 09:09 AM   #1
sugarlou
sugarlou's Avatar
Default Pan rigid frame question???????
Im looking for a rigid frame for a Pan/4 speed combo. Stock dimensions on the rake, no stretch. I thought Pauchco made these in the past JUST FOR Pan /Shovels. Now looking at them they also fit EVO motors. That means with a Pan Engine there will be that space above the rear cylinder. Now I know its not a big space but it bothers the shit out of me.
The V-twin replica is nice but pricey and I was just wondering if anyone else was making a stock geometry Pan /Shovel frame. If not I may have to save my pennies cause that gap is a no go for me. Thanks
sugarlou is offline   Reply With Quote
Old 01-22-2011, 09:16 AM   #2
panheadmark
Default Re: Pan rigid frame question???????
all new paugcho have the gap. I am with you its pretty big too. a older frame would not.I see them from time to time they usaly dont have numbers cause everybody used motor numbers. another option is chopped oem. here is a link to one for sale on the horse board > http://www.network54.com/Forum/47852...hovel+frame%21 I think you guys are sort close by? he says it needs work? but it takes money or skill but everything good cost
panheadmark is offline   Reply With Quote
Old 01-22-2011, 11:45 AM   #3
sugarlou
sugarlou's Avatar
I guess I need an early Paucho Pan frame or bite the bullet on the Vtwin
Old 01-22-2011, 12:28 PM   #4
Throwback
Throwback's Avatar
Ive seen some some pretty decent original frames on ebay lately for a lot cheaper than say;;; 1 year ago. Thats the rout I'm taking for sure.
Throwback is offline   Reply With Quote
Old 01-22-2011, 12:38 PM   #5
sugarlou
sugarlou's Avatar
I just looked..not cheap
I mean I guess there is a fair market value..Im just dealing with shallow pocket syndrome
Old 01-22-2011, 05:18 PM   #6
Larry T
Larry T's Avatar
The early pan/shovel Paughco frames also had quite a bit of clearance over the rear head.
I bought the frame for the red/white bike in the late 80's or early 90's. It is Pan/Shovel specific. Look at the clearance between the rocker cover and the FatBobs.
The black bike is also a Pan/Shovel frame. There is so much clearance there that I bought an second set of CCE finned aluminum rocker boxes, so I could use the fully finned front rocker box on the back head.
I included a shot with the stock CCE rear cover too.
The Santee frames I've seen fit a little tighter there.
Larry T
ID:	58666   Click image for larger version
ID:	58671   Click image for larger version
Name:	french kiss (3).jpg
My old Panhead build: https://www.jockeyjournal.com/forum/s...ead.php?t=9455
Occasionally updated Knucklehead project: https://www.jockeyjournal.com/forum/a...p?albumid=3625
Old 01-22-2011, 10:50 PM   #7
sugarlou
sugarlou's Avatar
Thanks Larry I see what you mean.
