Forks - The Jockey Journal Board
Old 05-19-2020, 10:45 AM   #1
longbow
Default Forks
Anyone use fork exstensions my son wants a little more ground clearence on his 82 fxr and is thinking about 2 inch fork exstenders or buy longer forks just wanting to know what you guys think of the exstenders are they a good idea or not? thanks craig
longbow is offline   Reply With Quote
Old 05-19-2020, 11:22 AM   #2
joe49
joe49's Avatar
Default Re: Forks
Slugs? No. Forking By Frank don't waste money on cheap china tubes.
OLD MOTORCYCLE ENTHUSIAST
Old 05-19-2020, 11:36 AM   #3
govmule84
Forum Dipshit
Default Re: Forks
Avoid with extreme prejudice.
Old 05-20-2020, 11:06 AM   #4
VonWegener
VonWegener's Avatar
Default Re: Forks
Hmm, I am of a different opinion. A stock 41mm uses slugs. They are short and called fork tube plugs. Making longer versions of those gave rise to the slug as cheap way to extend forks. A two inch slug is fully safe in my opinion. The bad ones are 3" and longer. The killers are the ones that go below the triple tree.
As far as I know there are no extended fork plugs available for the FXR front ends so a machinist would have to make them. Which in the end probably would cost as much as new tubes. And yes Forking by Frank makes excellent fork tubes.
Old 05-20-2020, 01:19 PM   #5
magnum45pete
magnum45pete's Avatar
Default Re: Forks
just buy new longer tubes, they are cheaper than a funeral...........
Old 05-20-2020, 04:39 PM   #6
Bryan83
Bryan83's Avatar
Default Re: Forks
Yeah avoid slugs. Go check out TC Bros fork tubes. Quality stuff. I run their 4 over on my Sportster and 6 over on my shovel (both 39mm).
Bryan83 is offline   Reply With Quote
Old 05-20-2020, 08:15 PM   #7
govmule84
Forum Dipshit
Default Re: Forks
Originally Posted by VonWegener View Post
As far as I know there are no extended fork plugs available for the FXR front ends...
I think Randy's does 'em. https://customcycleengineering.net/p...s/show-chrome/
Old 05-21-2020, 07:16 AM   #8
longbow
Default Re: Forks
Thanks guys he bought a set of forks.
Old 05-22-2020, 08:08 AM   #9
Elektron
Default Re: Forks
FYI, in Florida slugs in forks are outlawed.
I've bought Forking by Frank tubes and they were fine, OEM-style replacement, and less-expensive. You can order them 'over,' should you desire.
http://franksforks.com/
http://franksforks.com/products/harl...on-fork-tubes/
http://franksforks.com/get-a-quote/
Elektron is offline   Reply With Quote
