1966 Bsa 650 on a budget - Page 9 - The Jockey Journal Board
Old 04-08-2020, 09:16 AM   #161
Elektron
Default Re: 1966 Bsa 650 on a budget
That kickstarter pedal looks like something you would see in the movie Fargo, a part on a wood-chipper, dispensing red chunks onto a field of fresh snow.
Looks like you had a good amount of time to ponder the build, to have it be aesthetically-appealing while functioning-well, and not being annoying (rattling, rotating from vibration).
Elektron is offline   Reply With Quote
Old 04-08-2020, 09:55 AM   #162
MikeJustice55
MikeJustice55's Avatar
Default
Haha the mini chipper dont kick it barefoot. squeaks and rattles drive me insane. Part of the reason ill never do a springer again. 2 in a row had a squeak i couldnt get rid of. I see you're from miami, I live in fort pierce so u might see it in person sooner or later at shows. Ive never put any of my bikes in shows but ill make sure this one makes it to some of them in the maimi or ft Lauderdale area. And ofc daytona next year.
MikeJustice55 is offline   Reply With Quote
Old 04-17-2020, 06:31 PM   #163
MikeJustice55
Default
So I had a little down time at work so i revamped our powdercoat booth into a paint booth. I also do powdercoat and industrial painting for the shop but the powder oven is currently broken with no eta on getting fixed so ive just been painting when needed. The boss had no problems with putting up some new lights and white epoxy to brighten things up. I framed in a 12'8' area with 2x6 so i can staple plastic to make it a clean environment and the room already has filters and exhaust for shooting powder. Hopefully i can get my frame in there next weekend.
ID:	256934   Click image for larger version
ID:	256936   Click image for larger version
Old 04-17-2020, 07:03 PM   #164
Ratso
Ratso's Avatar
Black frame? Or you going to do something flamboyant and wacky?
Old 04-17-2020, 09:10 PM   #165
MikeJustice55
Default
Black frame for sure. Ill get fancy with it by doing gloss. I hate bright flashy frames about as much as i hate chrome. Maybe why i never fit in with the harley guys.
Old 04-18-2020, 02:55 PM   #166
Stormin
Stormin's Avatar
Nice little booth...that'll get the job done. Wouldn't mind see the powder coating process, might try that on my frame.
Old 04-18-2020, 05:05 PM   #167
Ratso
Ratso's Avatar
I'd *really* like to see it done with your broken powdercoating rig.
Old 04-18-2020, 10:48 PM   #168
MikeJustice55
Default
Our small oven still works so i can powder smaller parts (24x24x40). To be honest I have access to a great powdercoating system and an oven that can do most motorcycle parts but i prefer paint. Its not quite as durable but its easier to work with and has better results. Powder can be very tricky to get to lay flat, have super high gloss, its hard to do finer details and the prep on this old aluminum is terrible with offgassing and fish eyeing. The only thing i would have liked to powder was the frame and it wont fit.
Maybe ill do a couple smaller parts with powder to show the process and do a comparison of high gloss black powder vs gloss black base clear.
Old 04-21-2020, 05:22 PM   #169
MikeJustice55
Default
Fabbed up a stainless steel battery box yesterday. Mounted my ignition switch and podtronic to it so most of my wiring will be out of the way. Drilled and tapped the box so the studs sit flush so i could make the box as small as possible. Mounted it on some 1/8" neoprene and wrapped the lower half of the battery with neoprene as well to eliminate vibration.
ID:	256968   Click image for larger version
ID:	256970   Click image for larger version
ID:	256974   Click image for larger version
Old 04-21-2020, 05:36 PM   #170
Ratso
Ratso's Avatar
I love a nicely fabricated box, perhaps because making such things is about as high as my skill set has ever taken me. That's a particularly good one.
I'm suspecting that it sits on the bottom rails. behind the transmission ... ?
Old 04-21-2020, 05:36 PM   #171
MikeJustice55
Default
Took the bike off the stand today because FAB WORK IS DONE!!!! Here is a few shots before i disassemble and start painting. My paint came yesterday, i got organic green kandy basecoat from house of colors, bone white, and a gallon of clear. I still had almost a quart of black and some 2k dtm primer so i think i have everything i need. (I know i need to adjust the rear fender and bend my pegs a bit to make them straight. It will be done before paint) I also planned on running the bike before paint but i would have to put the actual engine in and wire the whole thing and then disassemble it. I feel like it would be better to just paint it and assemble for real and work out the hiccups later and try to be more confident in my work.
ID:	256980   Click image for larger version
ID:	256982   Click image for larger version
ID:	256986   Click image for larger version
ID:	256988   Click image for larger version
Old 04-21-2020, 05:43 PM   #172
MikeJustice55
Default
Yup. Thats the spot! This only took me about an hour because my buddy at work cut the top and flanges it bolts to with the water jet so no drilling or grinding needed there. I just bolted them together and set the box on it and welded it. Ez perfect fit. I am very very lucky to have access to the tools i have. I would have at least triple the fab time if i didnt work at this shop. Plus the lazer and waterjet have tons of good stainless and aluminum drops that i can grab for free.
Old 04-21-2020, 06:10 PM   #173
Ratso
Ratso's Avatar
Haw! That's a great-looking bike, man. It's unique without being a dick about it. It's RAKISH. It's INSOUCIANT. It is FUCK YOU, JUNIOR, but in a nice way.
Old 04-21-2020, 06:27 PM   #174
Thebigguy0811
Default
Are the fittings on the tank side for a visible gas gauge?
"It does not take a majority to prevail. What it takes is an irate, tireless minority, keen on setting brushfires of freedom in the minds of men."-John Adams
Thebigguy0811 is offline   Reply With Quote
Old 04-21-2020, 06:34 PM   #175
MikeJustice55
Default
Hahaha. I like you Ratso. Im picking up what you're putting down here. Thanks.
Old 04-21-2020, 06:34 PM   #176
MikeJustice55
Default
Yes, there will be one on the oil tank as well.
Old 04-22-2020, 08:18 AM   #177
Nanonevol
Beautiful. You've got quite an eye. Love the chainguard shape, tank, all of it.
Nanonevol is offline   Reply With Quote
Old 04-23-2020, 07:00 AM   #178
MikeJustice55
Default
Thanks. Its turning out better than i expected
Old 04-23-2020, 07:58 AM   #179
richbob
richbob's Avatar
Yea looks good
how is the rear suspension it works ok?
i presume you sat on it and bounced up and down?
richbob is online now   Reply With Quote
Old 04-23-2020, 09:44 PM   #180
Stormin
Stormin's Avatar
What did you expect, you have some awesome skills! Would like to see the rear suspension in action before paint...just in case.
