Rigid Gilera Racer - #2 project - Page 2 - The Jockey Journal Board
Old 08-28-2015, 01:32 PM   #21
Ratso
Ratso's Avatar
Default Re: Rigid Gilera Racer - #2 project
Remarkable bike-in-progress! Is that a 250cc Lodola engine?
Old 08-28-2015, 01:37 PM   #22
Path Thirteen
Hello Ratso. Close! It's a Gilera 210
Path Thirteen is offline   Reply With Quote
Old 08-28-2015, 07:03 PM   #23
Path Thirteen
Today I made the rear wheel adjusters and chain tensioner, So for the first time its rolling, Heres some pictures of me on the bike, yes its a very small bike. and some other pictures in a less busy place as the shop is full of shit.
Next step is to make the rear sets and define the exhaust.
Old 09-04-2015, 09:21 PM   #24
Path Thirteen
Almost finished the Rear Sets, Started to design on monday, so it took a shitload of time. at least by designing firts and then fabricating then was a big time saver, i learned to first think then grind, saves lots of time and raw material, i used brass bushing from a starter, i just could use a ball bearing but i had those from my Ford starter so i just used what i had. Still not finished, i need to keep filling and kill all those square borders on the lever, and some form correction to the main plate.
Hope you guys like it!
If someone wants to use the design, i can send the cad file!
Old 09-04-2015, 09:22 PM   #25
Path Thirteen
Old 09-04-2015, 09:24 PM   #26
Path Thirteen
Old 09-04-2015, 10:39 PM   #27
JAWS
JAWS's Avatar
How close it the fender to the tire? The center looks like it has enough for growth, the sides where it tapers looks like it could shave.
You'll find the rear controls will be more positioned down pedal wise. Rather than flat like the mids or up like forwards. Prolly not set up yet though, right?
Old 09-04-2015, 11:14 PM   #28
bobscogin
The bike may be small, but your skill and enthusiasm are large. Nice work!
Bob
Old 09-05-2015, 01:11 AM   #29
Path Thirteen
Howdy Jaws! Yes, there's enough clearance, at least with this fucked up, old, petrified and deformed tire, that has almost no centered part (it was on a bike for about 20 years, so the part that remained on the floor for 20 years makes a funny S and then it goes straight again, i don't know how to explain this. the sides are tight, i think ill have to shave a little off the fender or open it up a little and make it a little wider.
Funny thing about this tire it took me about an hour to put in on the rim haha the tube was impossible to fit, and i punctured the tube when fucking hammering that fucker to make it go in the rim, but without air still holding the bike weight and mine no more flats (?)
And yes, you are right about the rear sets, but that was the only way i could put a vise grip(is not a vise grip is like an U with a screw to adjust things together, don't know the name in english, tried to google it but had no luck this time) to stick it to the bike and take the photo, but.. now i realize that pedal not gonna work, i think ill just have to make a "rod" also more easy to set up in any position the lever goes! So... Thanks again man!
Old 09-05-2015, 01:14 AM   #30
Path Thirteen
Bob
Thanks for the words Bob!!
Old 09-05-2015, 01:34 AM   #31
Path Thirteen
Made this manifold last week, just forgot to upload it here
Old 09-05-2015, 04:14 AM   #32
Lester
Lester's Avatar
You forgot to up load it again... Lets see it. Nice work so fra!
'62 DuoGlide Mine for 25yrs
'62 Triumph T-Bird in boxes
'83 BMW R100 commuter
'80's couple of Jap chops too
Old 09-06-2015, 12:06 AM   #33
Path Thirteen
Try now, Lester
Old 09-06-2015, 08:00 AM   #34
KCgran
I think the word you're looking for is C-clamp, and I too am enjoying your work. Thanks for posting
Old 09-06-2015, 02:19 PM   #35
Lester
Lester's Avatar
Try now, Lester
Sweet!
Old 09-07-2015, 10:12 PM   #36
Path Thirteen
I took some pictures for you, JAWS, i checked again and theres a reasonable amount of free space fro growth and the sides are OK, even with this fucked up tire it doesn't grind at all.
ID:	191617   Click image for larger version
ID:	191625   Click image for larger version
Old 09-07-2015, 10:14 PM   #37
Path Thirteen
Yes Sir, i was so burn out that day and couldnt figure out how it could be named, it was easy! Thanks!
Old 09-07-2015, 10:23 PM   #38
Path Thirteen
Well, finally i could attach the rearsets to the bike, i need to file down all the borders and polish everything, but i need to move on to other stuff, i did the rearsets because based on the legs position stops me from doing the exhaust, which im doing tomorrow, gonna use a cocktail shaker/triumph muffler almost side by side with the engine. lets see what happens!
Hope to finish this bike before october 8(yeah i know im fucked up), there's gonna be a big classic car show, bikes and swap meet, its the biggest show in latin american, and i want to sell this bike as now I am unemployed and my wife too, so... i need to buy some plane tickets to move from this shit hole and search for a better life somewhere else!
btw, the bike is not comfortable at all ha!
ID:	191649   Click image for larger version
ID:	191657   Click image for larger version
ID:	191673   Click image for larger version
ID:	191681   Click image for larger version
Old 09-07-2015, 11:11 PM   #39
OleDirtyDoc
Awesome fab work
OleDirtyDoc is offline   Reply With Quote
Old 09-08-2015, 08:30 AM   #40
Mike Britton
Mike Britton's Avatar
I really like where this is going.
Tags
drag, gilera, homemade, racer, rigid
