couple of sportster questions - The Jockey Journal Board
Old 08-08-2015, 11:14 AM   #1
lilbill
lilbill's Avatar
Default couple of sportster questions
i don't have a lot of experience with ironheads and i've run into a few issues with a 76 basket case i'm trying to resurrect . First off this thing got punched in the nose at some time and it tweaked the frame. I can straighten it but it has a "dimple" on the side of the backbone directly over the top motor mount. It's pretty uniform looking so my first question is did the '76 frame have this feature stock or is it a result of the impact ?
My next question is about the rear tank mount. It had a mustang style tank when it came in and I want to go back with a stock tank. I tried putting what I thought was a stock tank on it (wall hanger of unknown origin) but the rear mounting hole is about 1" off. Were there different length tanks or is mine just a poor fitting aftermarket unit ?
ID:	188578   Click image for larger version
ID:	188586   Click image for larger version
RIP SwedeBobb
Old 08-08-2015, 12:01 PM   #2
joe49
joe49's Avatar
Default Re: couple of sportster questions
I am putting my '75 back into it's stock frame also. The dent belongs there, it was to allow. access to the top motor mount bolt with power tools during assembly. In your first picture the hole you have the tank lined up to is not a original hole it was added by someone. The hole you see in the gusset ahead and below were the tank is in the picture is the front tank mount hole and uses two spacers to mount the tank and the coil mount.
joe49 is online now   Reply With Quote
Old 08-08-2015, 12:11 PM   #3
lilbill
lilbill's Avatar
ah sooooo........ thanks
RIP SwedeBobb
Old 08-08-2015, 09:12 PM   #4
JAWS
JAWS's Avatar
What you call me?
Old 08-08-2015, 09:41 PM   #5
lilbill
lilbill's Avatar
Originally Posted by JAWS View Post
What you call me?
whodawaddahunh ???
RIP SwedeBobb
Old 08-09-2015, 01:00 AM   #6
JAWS
JAWS's Avatar
Not funny if in I has ta 'splain it!
Old 08-10-2015, 07:49 AM   #7
Racepres
Racepres's Avatar
Not funny at all...
another thing on sporty tanks, your tank should have the "ears" for rear mount reaching back an inch or more. The ones straight down or even reaching forward, are newer.
Edit; I meant not funny at all if you gotta splain!
If it Aint a H-D and it Aint from '66 to '84
I might be Guessing!!!
Racepres is offline   Reply With Quote
