shovelhead crank case breather - The Jockey Journal Board
Old 07-14-2015, 08:49 AM   #1
imwastefull
Default shovelhead crank case breather
evidently mine fell out! and boy was she spewing oil. At any rate, quick question;
What size is the fitting? what do you guys usually run the hose to? what if i just blocked it off, put a bolt in there?
imwastefull is offline   Reply With Quote
Old 07-14-2015, 08:52 AM   #2
govmule84
Forum Dipshit
Default Re: shovelhead crank case breather
1/8" NPT. Run the hose to the ground or over the chain. Don't block it off.
Old 07-14-2015, 09:15 AM   #3
imwastefull
Default
Just curious, why not? I've had a few bikes where the breather is bocked
Old 07-14-2015, 09:42 AM   #4
geezer
geezer's Avatar
If the engine displaces 74 C.I. above the pistons it does so below them too. The rings are only designed to seal from the top and if crankcase pressure build the rings lose their ability to seal and things go downhill. It's hard on seals too.
Old 07-14-2015, 09:52 AM   #5
badassbrutus
badassbrutus's Avatar
Also don't obstruct it by running a filter on the end of the hose keep it flowing freely.
If you like me fine....If you dont Fuck You.
AKA...Hemi Head
badassbrutus is offline   Reply With Quote
Old 07-14-2015, 09:54 AM   #6
johnjzjz
johnjzjz's Avatar
its 3/8 pipe and we put a 45 in it and run the hose up and over the oil tank with the oil vent and return lines than back down and tie it off by the rear chain so the vapor lubes it
some one else may do something different but this we have been doing it this way 40 years as it also helps with a sumped motor keeping the oil in it rather then on the floor
Old 07-14-2015, 10:01 AM   #7
Racepres
Racepres's Avatar
Yes....except mine is 1/8 pipe! ^^^That one appears to be also. tho with a caliper 1/8 pipe may measure 3/8" O.D. thread.
I have never had a problem with a short hose directly to the ground over the chain!
If it Aint a H-D and it Aint from '66 to '84
I might be Guessing!!!
Racepres is offline   Reply With Quote
Old 07-14-2015, 01:06 PM   #8
JAWS
JAWS's Avatar
^^^ How I do it.
Old 07-14-2015, 03:59 PM   #9
johnjzjz
johnjzjz's Avatar
i was incorrect it is 1/4 pipe thread not 3 /8 and the return to the block from the primary is 1/8 pipe
the 3 blocks are a 1967 - a -1977 and 1981 and all 3 do not vent with a 1/8 inch all are 1/4 inch pipe but the returns all 3 are 1/8 inch pipe
Name:	2015-07-14 15.45.38.jpg
ID:	186818   Click image for larger version
Name:	2015-07-14 15.49.52.jpg
ID:	186826   Click image for larger version
Name:	2015-07-14 15.50.01.jpg
Old 07-14-2015, 11:36 PM   #10
Wolfworks Customs
Wolfworks Customs's Avatar
Crank in a nipple, a 1.5' piece of hose then add a Chevy chrome Valve cover breather....all i been usin fer 4 yrs now.....
http://www.ebay.com/itm/chrome-valve...50333#ht_0wt_0
Wolfworks Customs is offline   Reply With Quote
Old 07-15-2015, 08:39 AM   #11
Racepres
Racepres's Avatar
No reason in the world for the breather tho....cept to collect a bit of oil and save it to drool later!!!!
Old 07-15-2015, 12:44 PM   #12
badassbrutus
And once they get saturated with water from a rain storm or a good washing they will no longer Breath while wet there for obstructing occurs to the Free Flow.
AKA...Hemi Head
