Angry Monkey Motorcycles, "unleashed" pre unit build. - Page 9 - The Jockey Journal Board
Old 09-21-2015, 03:22 AM   #161
KCgran
Default Re: Angry Monkey Motorcycles, "unleashed" pre unit build.
I was looking at the machine marks on your stainless brake adjuster knob. I can tell the reliefs in the outer diameter were mad by plunge cutting an end mill, probably four flute and I'm thinking HSS. My question is how are you clocking your holes and these relief cuts? Dividing head? Or rotating head? Or simply a degreed vise holding a fixture with the part centered over the pivot? Not a real important question, but I'm always interested in how other machinists get over hurdles like this.
Really nice work as always
Old 09-21-2015, 07:21 AM   #162
Chewy750
May have sussed the problem, I have the 30 mm belt and pulley not the 25mm - DOH!! That extra 5 mm will make a lot of difference!!
Chewy750 is offline   Reply With Quote
Old 09-21-2015, 08:26 AM   #163
richbob
richbob's Avatar
Chewy
As i said in the PM i sent you.
Old 09-21-2015, 10:48 AM   #164
Chewy750
Originally Posted by richbob View Post
Chewy
Apologies, missed that completely! I have spoken with Bob, but before spending any more, I'm going to have a look at a little bit of machining of the pulley and a new securing nut. Thanks for the assistance.
Old 09-21-2015, 10:58 AM   #165
richbob
richbob's Avatar
He did mine and a new belt
call him send it back
pully came back like new.
Old 09-21-2015, 11:26 AM   #166
supercrouton
supercrouton's Avatar
Originally Posted by Dan Boy View Post
It is almost a shame to hide that beautiful clutch under the cover but the stators always look so ugly, shame there isn't a "good" looking stator that would persuade me to run the primary open.
BTW, love the carb and throttle ferrels.
Dan.
Thanks Dan. Yes, Triumph have the UGLIEST stator setup ever. It begs to be hidden. I will be cutting this cover to vent/show the BNR at a later time. At least this time the cover itself, which is a one-off item, covers both the stator and clutch with some style.
Originally Posted by Lester View Post
Very informative Dan, thanks for sharing. Great work, its easy to see you are a seasoned builder that knows what he's doing.
Lester
Too kind, Thanks!
Thanks! I use a degree/rotating head to drill and scallop those knobs.
5mm is huge in this situation. Maybe BNR would swap your 30mm for the 25mm setup. It would be worth a phone call.
Old 09-21-2015, 12:44 PM   #167
Dan Boy
Dan Boy's Avatar
Dan, is that the same as a dividing head?
Blown Triple Build
Old 09-21-2015, 01:18 PM   #168
supercrouton
Originally Posted by Tony the torch View Post
I've shaved down several pulleys for stator clearance and ordered a 20m/m wide belts for pre-unit alternator bikes.
McMaster Carr has a bunch of different lengths of 20 m/m wide belts,
http://www.mcmaster.com/#timing-belts/=z1clrh
Thanks Tony! That's good info for anyone with a BNR setup.
Old 09-21-2015, 01:24 PM   #169
supercrouton
Both serve the same function. The difference is a dividing head has pre-drilled holes that a pin drops in to hold the work at a predetermined degree of rotation. A rotating head has no such detents, only a degreed tape around the head and a pointer on the base. The operator must do the math to stop the work any number of degrees of rotation.
Old 09-21-2015, 02:42 PM   #170
Chewy750
Already looking into it, may buy another 30mm and just machine it slightly.
Old 09-21-2015, 02:49 PM   #171
KCgran
A dividing head ,when trued properly to the axis, is slightly more accurate than a rotating head IMOP. A rotating head usually is equipped with a crank that allows you to make radii on a manual mill. But there is nothing wrong with how dan is using it either.
Old 09-21-2015, 03:01 PM   #172
supercrouton
You are 100% correct on the superior accuracy of a diving head. A dividing head can hit the desired positions effortlessly. I use a rotating head for this operation because, well, I have one
Old 09-21-2015, 03:40 PM   #173
supercrouton
In post #1 of this thread I stated that there would be something on this bike that has not existed (to my knowledge) to this point. Well, it is this finned primary cover set for swing arm, pre units. Well, and the alternator model finned timing cover too. Finding decent primary and timing covers is an ongoing hassle and it gets more expensive every year. So I figure if it's going to cost serious coin for a vintage cover that is in only decent shape, why not just make some that are better than stock. But, despite the fins, the best part in my opinion is the newly minted inner primary. It is so nice to NOT have to repair damage done for the past 50+ years, and to start off with a cover that is arrow-straight. Obviously, these are for dry primary only since I deleted the filler cap and bung, but that's the only way I will build a pre unit. These covers are prototypes and are slightly flawed, but the finished ones are close to production. Enjoy!
Old 09-21-2015, 05:42 PM   #174
Jesse_in_NY
Jesse_in_NY's Avatar
And the sleeve opens, and from it he pulls......GLORIOUSNESS!!!!!
“Be not like those whose hearts are filled with the fear of death, so that when their time comes they weep and pray for a little more time.” Shawnee Chief Tecumseh
Jesse_in_NY is offline   Reply With Quote
Old 09-21-2015, 06:23 PM   #175
JAWS
JAWS's Avatar
Dan, those are sweet. So finny and awesome.
I see a new trend coming. Buy stock in angry monkey. Don't want to be sitting around like the other guys who say. "Should have bought stock in trojan condoms before HIV..."
Old 09-21-2015, 08:19 PM   #176
KCgran
So are these cast? Or machined from billet?
Old 09-22-2015, 03:23 AM   #177
RidingHood
Oh my that finned primary is just a work of art ,very cool bit of kit.
I really like the exhaust as well.
Cheers R
Old 09-22-2015, 04:26 AM   #178
Lester
Lester's Avatar
Dan, Let me know if and when these items will be for sale.
Very sweet! Your primary spacer had me to looking too.
Good stuff. Have you thought about finned motor mounts for pre unit too. To my novice knowledge these are only offered for Unit.
Lester
'62 DuoGlide Mine for 25yrs
'62 Triumph T-Bird in boxes
'83 BMW R100 commuter
'80's couple of Jap chops too
Old 09-22-2015, 10:38 AM   #179
fightclub
fightclub's Avatar
Lester, don't want to speak out of turn but I believe Dan uses these finned motor plates from Joe at
Choppedtriumphs.com
fightclub is offline   Reply With Quote
Old 09-22-2015, 11:24 AM   #180
Englishman
Englishman's Avatar
Breathtaking!
The Horse BC.com
[email protected]
Englishman is offline   Reply With Quote
Tags
angry monkey motorcycles, pre unit, supercrouton, triumph
