74" Panhead magneato plugs - The Jockey Journal Board
Old 06-05-2014, 12:02 PM   #1
jessee
Default 74" Panhead magneato plugs
What kind of plugs can I use ??? I can't find auto lite or champion j12yc
jessee is offline   Reply With Quote
Old 06-05-2014, 06:19 PM   #2
old stale negative
Default Re: 74" Panhead magneato plugs
hope this helps.
info is specific for XLCH Sportster, but applies to mags in general too…
my XLCH magneto cheat sheet:
- only use solid-core wires on a Harley with a magneto
- do not use resistor spark plugs or resistor spark plugs
- cracks in wires will drain spark, inspect carefully
- mag uses an open-ended double secondary lead coil, both plugs fire at the same time
- best points to run are Fairbanks Morse part# F-M B2437A or Morris Magneto P-5
- set mag points to 0.015"
Spark Plugs
Autolite AP4316; Champion H8 and H8C (H8C aka 587)
plug gap .020 (max) on the plugs (0.018-0.020)
points gap = .015 on the magneto points
plugs torque to 14ft/lbs; always use anti-seize on threads
plug type notes:
previously used on my 1966 XLCH = AC Delco C43L; Autolite XS85
Champion H8 and H8C = replaced the HD4, the OG, and most-reliable plug -- now unavailable
- DO NOT use HD4R it is a resistor plug
- Spark plug gaps on a magneto bike need to be small
old stale negative is offline   Reply With Quote
Old 06-05-2014, 08:46 PM   #3
LeftLane
I got a set at my indy today. $2 each.
Drinking may cause memory loss. Or worse , memory loss.
42wla 51fl 56fl
LeftLane is offline   Reply With Quote
Old 06-06-2014, 07:19 AM   #4
ralphiejantz
autolite 4275 for a panhead with a magneto
you can get them off ebay.
http://syndicatechoppers.com
authorized dealer for
Biltwell Inc
Lowbrow Customs
Buchanans Spoke and Rim
Wargasser Speed Shop
Universal Vintage Tires
Paughco
V-Twin MFG.
Fab Kevin
Colony Machine
Morris Magneto
Baker Drivetrain
Andrews
Cycle Electric
