One plug too rich shovelhead - The Jockey Journal Board
Old 05-15-2014, 02:22 PM   #1
I_am_10_ninjas
I_am_10_ninjas's Avatar
Default One plug too rich shovelhead
So I pulled my plugs on my 1980 fxwg shovelhead the other day because it breaking up a little when you'd whack the throttle and farting through the carb when you'd kickstart. I found a nicely tanned plug in the front cylinder, but a VERY black plug in the rear? Soooo....how does that work? I'm running a single S&S Super E on pretty close to default tuning. I assume if there was an intake leak I'd have a lean plug not a rich one, no? Any ideas how one cylinder would be running so rich?
antiquatedmule.blogspot.com
I_am_10_ninjas is offline   Reply With Quote
Old 05-15-2014, 02:37 PM   #2
Mr Bill
Mr Bill's Avatar
Default Re: One plug too rich shovelhead
Pick one.
No matter how low you sink there's still a right and a wrong, and you always end up choosing.
You go one way so you can try to live with yourself.
You can go the other and still be walking around, but you're dead and you don't know it.
Mr Bill is offline   Reply With Quote
Old 05-15-2014, 02:45 PM   #3
I_am_10_ninjas
Oh man. I dunno. Always so hard to tell from these pictures. It was damn black. maybe the carbon fouled one?
Old 05-15-2014, 02:57 PM   #4
Dr. Benway
Mod Squad
Dr. Benway's Avatar
Leaky valve guide/seal?
Old 05-16-2014, 11:39 AM   #5
underrust
underrust's Avatar
A leak with rich carb could cause that ,valve adjustment?
underrust is offline   Reply With Quote
Old 05-16-2014, 03:48 PM   #6
Greenbikemike
Greenbikemike's Avatar
I'd clean'm both and switch'm or try a new set and see if it still does it before I'd start messing with it,could be it just got fouled a bit.....cheap an easy first,
good luck,
Greenbikemike
"The only thing I've cheated on is death.....The only thing I've spit on is the ground".....
I'm just am amateur but....a amateur built the Ark. A large group of professionals built the Titanic!
Greenbikemike is offline   Reply With Quote
Old 05-16-2014, 04:28 PM   #7
KCgran
I like Mike's suggestion. Makes sense to check it, damn good thinking mike.
Old 05-16-2014, 06:00 PM   #8
old stale negative
bad plug, plug wire, or connection will do that. swap and test. repeat. I bet the carb is fine.
old stale negative is offline   Reply With Quote
Old 05-16-2014, 08:23 PM   #9
highcomp
highcomp's Avatar
Pull air cleaner off so you can see into carb and intake. Watch stream of fuel shooting put of accelerator pump nozzle. it should be shooting about 1/4"-1/2" in front of where inner intake manifold forms the "V". Why you ask? Inertia...that fuel will go into the rear intake tract as the bike moves forward and the fuel doesn't. Just have to tweek the nozzle forward a hair. Of course thats assuming everything else is correct.
The vultures are getting closer but I ain't dead yet
highcomp is offline   Reply With Quote
Old 05-17-2014, 07:22 PM   #10
Boneshaker74
I'd look at the spark, spark plug wires and coil. A dark rich spark plug can be caused by a weak spark. Take the spark plug out and check to see how the spark looks and if it's travelling from the centre electrode to the ground electrode and not out to the side. I've had new spark plugs where the spark does this. Apparently there are some fake spark plugs on the market. The spark might look good and blue but it has to travel correctly. Try a different coil and wires if you have one but I'd start with the above first.
Boneshaker74 is offline   Reply With Quote
Old 05-18-2014, 07:08 AM   #11
Englishman
Englishman's Avatar
Fake spark plugs?
The Horse BC.com
[email protected]
Englishman is offline   Reply With Quote
Old 05-18-2014, 09:26 AM   #12
Mr Bill
Mr Bill's Avatar
ain't china wonderful
http://www.ngk-sparkplugs.jp/english/techinfo/fake/
Old 05-18-2014, 01:26 PM   #13
JAWS
JAWS's Avatar
Didn't we have this discussion recently? It was at length too I'm memory serves.
Old 07-02-2014, 08:47 AM   #14
mississippidave
mississippidave's Avatar
Leaky valve guide....
mississippidave is offline   Reply With Quote
Old 07-02-2014, 10:12 AM   #15
joe49
joe49's Avatar
.......something very familiar about this thread.
Old 07-02-2014, 10:20 AM   #16
[JP]
[JP]'s Avatar
yep..sure is familiar!!!
I've already PMd 10ninjas to see if he sorted his problem out..and what was it
Instagram - JPINTHEUK
My 76 Shovelhead build - https://www.jockeyjournal.com/forum/s...d.php?t=100698
My 68 Genny Shovel - https://www.jockeyjournal.com/forum/s...d.php?t=128618
Tags
one cylinder, rich, shovelhead, super e
