1978 Ironhead build - The Jockey Journal Board
Old 04-28-2014, 03:26 PM   #1
jakespade77
jakespade77's Avatar
Default 1978 Ironhead build
Started with a hacked up tweaker job and trying to get road ready.
I'll post pics as the progress goes on.
I noticed it doesn't have an oil filter. I happen to have a remote filter set up so would the filter go from the tank to the oil pump or where in the oiling cycle would it go best?
"One cannot achieve ingenuity through imitation."
- Zephros Major (The Shovel Revival)
jakespade77 is offline   Reply With Quote
Old 04-28-2014, 05:10 PM   #2
old stale negative
Default Re: 1978 Ironhead build
put the filter in the the line returning oil from the engine oil pump to the top of the oil tank.
note there is also a case vent line, make sure you identify your oil pump correctly—don't put the filter on this vent line.
be sure you have the correct filter for your oil pump—you can easily back up the oil if you're using the wrong filter. All filters are not created equal.
old stale negative is offline   Reply With Quote
Old 04-28-2014, 05:17 PM   #3
jakespade77
Right on! Thanks man!!
Old 04-28-2014, 05:19 PM   #4
jakespade77
I have the one I got off here in the for sale section a few years back.
How would I know if its good for the Ironhead or not??
