Checking your coil? - The Jockey Journal Board
Old 05-12-2015, 07:02 PM   #1
rooster
rooster's Avatar
Default Checking your coil?
Is there a way to check/test a coil?
79FLH runs fine until heat build up and then sputters and misses terribly. Sit for 30 min runs fine, repeats...
I installed a new Andrews coil but have not test road yet. I"m just curious if there is a way to check?
SHOVELHEAD- if it ain't broke it will be.
rooster is offline   Reply With Quote
Old 05-12-2015, 07:08 PM   #2
Racepres
Racepres's Avatar
Default Re: Checking your coil?
I usually end up checking exactly like you are gonna...change and run it...There are ways. but, The Change and run , method is Easy, Fast, and Usually Final.
I might be Guessing!!!
Old 05-13-2015, 02:06 AM   #3
FRISCO67
FRISCO67's Avatar
I don't remember where I got this maybe on here maybe the HAMB. but I kept this info in my files.
"cross the coil leads with a multimeter set on ohms and the lowest setting usually 200
if it reads .5 to 1.5 its prob a good electronic ign coil
if it reads 3.5-6 its prob a good points coil
if it zeros out its bad"
FRISCO67 is offline   Reply With Quote
Old 05-13-2015, 11:46 AM   #4
Dave B
Take one of those sparking plug wire tools and place on the plug wire .If it is weak stick the tester directly in the coil. If it gets stronger you have faulty wires . Those testers don't work in magnetos [well] . They used to be made in USA by Bonney but now all you can get are imports. But it is still a good troubleshooting tool.
Dave B is offline   Reply With Quote
Old 05-13-2015, 01:49 PM   #5
FredoTwoWheels
FredoTwoWheels's Avatar
Heat up the coil with a blow drier and see if you get the same symptoms while the bike is still cold
FredoTwoWheels is offline   Reply With Quote
Old 05-16-2015, 09:19 PM   #6
rooster
rooster's Avatar
New Andrews coil, new points and condenser, new volt reg, new plugs, checked mani for leaks and it runs worse now!
I have checked the points gap and timing, someone tell me what I'm doing wrong!
Old 05-16-2015, 11:08 PM   #7
Mr Bill
Mr Bill's Avatar
Have you inspected the advance unit?
No matter how low you sink there's still a right and a wrong, and you always end up choosing.
You go one way so you can try to live with yourself.
You can go the other and still be walking around, but you're dead and you don't know it.
Mr Bill is offline   Reply With Quote
Old 05-17-2015, 06:26 AM   #8
rooster
rooster's Avatar
Only from the outside to see if the springs are still there!
Old 05-17-2015, 08:52 AM   #9
Cruoficio
Cruoficio's Avatar
I had the same with my ironhead. The coil had one really fine crack in it, very hard to see. Take a closer look at your coil, with a magnifying glas if you can.
If you see no cracks you can rule that one out...
Cruoficio is offline   Reply With Quote
Old 05-17-2015, 09:15 AM   #10
Most of the things to check have already been mentioned. But here are a few more. Check the wiring to the coil isn't backwards. Replace your condenser with the original, if it ran fine before. Then the coil, back to your original, also only if it ran OK before. If your originals were bad, you need to try known good parts. That doesn't mean new in the box it means parts off a good running bike. Call your friends with the same points ignition, their flavor beer will be in order.
joe49 is online now   Reply With Quote
Old 05-17-2015, 10:30 AM   #11
rooster
rooster's Avatar
Well I did find something this morning. The new Vreg i just bought is for a electron ignition, I'm running point. Unfortunately I discovered that after installing and running the engine.
1. I hope I didn't hurt anything!
2. Always check electrical parts before leaving the store! No matter how good the shop is.
Old 05-17-2015, 10:44 AM   #12
Ironsled77
Ironsled77's Avatar
Two things.....
1. I had a bad circuit breaker once that was weak.... when it got hot the contact would trip and kill power. Once it cooled it made contact again and would run. I changed it and it was all good.
2. Are you sure its not a fuel problem? Hot gas i.e. fuel line ran between cylinders can cause running problems. Also a stuck float making it starve? And last poor venting of the gas tank
Just a few things to check
A generation born to witness the end of the world
Ironsled77 is offline   Reply With Quote
Old 05-17-2015, 02:54 PM   #13
Lester
Lester's Avatar
Battery health checked?
A crap battery can cause all kinds og similar symptoms
Lester
'62 DuoGlide Mine for 25yrs
'62 Triumph T-Bird in boxes
'83 BMW R100 commuter
'80's couple of Jap chops too
Old 05-17-2015, 03:35 PM   #14
rooster
rooster's Avatar
It was about 80* coming home from Fuel Cleveland when it first happened but the next time it did it was about 65* so I don't think it is gas, but who knows! I'll keep chasing demons...
Old 05-18-2015, 07:23 PM   #15
rooster
rooster's Avatar
I have now replaced, coil, plugs, points, cond, volt reg and the slide in my CV carb.
Set the static timing and the missing persists. Could rod adjustment cause a misfire? What if the timing was off just a little?
Old 05-18-2015, 08:49 PM   #16
Stator. Check to see what the battery voltage is when it sputters. Carry a volt meter.
I've had to mount one to the bars and run longer leads to the battery and take them out.
The ign coil ain't the only coil. If it's above 12.6 when its sputtering it's not a source voltage issue. Next would be after the Circuit breaker and another ride. Then so on to the ign switch and then positive of the coil primary circuit.
Once that's eliminated, get another condenser and ride on. A good one, not the cheap ass generic condensers that come in the kits.
Is it popping out of the carb?
Will it do it idling on the side stand too? (Keep a fan on the motor)
Old 05-19-2015, 07:35 AM   #17
Did you change or add anything to the bike before this problem occurred?
Old 05-19-2015, 09:51 AM   #18
Lester
Lester's Avatar
Battery !
Old 05-19-2015, 10:06 AM   #19
conn.rod
the condenser could be grounding out,or,if you think there is a crack in the coil,sometimes you can run the engine in the dark and see slight sparks coming from the coil
conn.rod is offline   Reply With Quote
Old 05-19-2015, 11:48 AM   #20
Ironsled77
Ironsled77's Avatar
sounds like fuel too me.....
