Wla cam cover on Ironhead.... - Page 2 - The Jockey Journal Board
Old 02-18-2015, 01:26 AM   #21
Default Re: Wla cam cover on Ironhead....
Originally Posted by little d View Post
Ya mean like a jimmy 4-61 with a birdcatcher hanging off of it?
You know thats what I mean....
Exposed valve train!!! Oh please combine all the threads for this build into one so WE dont have to go searching and risk missing the awesomeness.
Yeah, its that good.
Old 02-18-2015, 05:33 AM   #22
little d
little d's Avatar
Originally Posted by Rebuilder View Post
Thanks for all the great info guys.. I'm seriously just wingin' it here so all help is appreciated.
The second issue is that hole on the right also feeds the top end which then drains down and oils the piston skirts. I plan on running exposed valvetrain which is an issue for another post but for the sake of this post I could probably just T off another external line to the top end and bypass the passages in the stock cam cover all together? External copper lines = awesome anyway so win win.
From what I can tell all the cam bushings all get splash oiled so the only real oiling issues are listed above.... I think.
Would this give you enough to lube the wrist pins?
I'm with Jaw's, this is going to be an epic build, please include it all in here so it doesn't get lost.
"Apparently, any asshole can wrench on a newish, un-fuckered bike. Takes a goddamn genius to take this shit on."-Liam.
little d is offline   Reply With Quote
Old 02-18-2015, 09:29 AM   #23
Rebuilder
Rebuilder's Avatar
I'm thinking the external lines would basically just be replacing the internal passages in the stock cover so it should still oil what it's supposed to oil as long as I use the correct size tubing.
Question for you Magnum 45 guys. You use an Ironhead crank in a Magnum 45 correct? so does that mean the pinion end that goes into the cam cover is the same or does it need to be modified?
Rebuilder is offline   Reply With Quote
Old 02-18-2015, 09:59 AM   #24
although the pinion shaft is not the same overall i believe the end into the cam cover is the same diameter.... someone here with a 45 crank out will be able to measure it to be sure....I didn't use an Ironhead crank in my MAgnum I used a brand new 45 crank....
Old 02-18-2015, 01:50 PM   #25
IF you are doing external lines, why not add piston squirters to help with lubing the wrist pins? Would this not work with case scavenging? Probably not even an issue really, just kicking this around in my head outloud er...typing.
Old 02-18-2015, 08:24 PM   #26
Friday
the other MAGNUM!
would it help to make a aluminium template of the XL cover then screw it to the WL cover , you have inside view of the differences
cool thread
Friday is offline   Reply With Quote
Old 02-18-2015, 10:34 PM   #27
Rebuilder
Rebuilder's Avatar
Few things I learned tonight....
I was able to take the #1 cam bushing out of the XL cover and put it into the WL cover. problem solved.
New probl.... I mean solutions...
The pinion shaft on the XL is about 1/4" longer and is a smaller diameter than the WL so hopefully I can do the bushing swap like on cam 1 and taking 1/4" off the end shouldn't be a big deal.
I'll need to machine the WL cover to fit this bushing for the idler gear.
Cam 2 bushing is set in about 3/16" on the XL so I'll have to mill down the WL cover to match. This will also align the gear in the mag hole.
XL
WL
I think that's it for now. I'm sure there will be more "solutions" tomorrow.
Old 02-18-2015, 11:42 PM   #28
Okie Pete
Okie Pete's Avatar
I love projects like this and the Guys who not only think outside the box but go the extra mile to make it work . Keep up the great R&D machine work .Thanks for posting pictures.
Not enough time for windmills
Okie Pete is offline   Reply With Quote
Old 02-19-2015, 10:29 AM   #29
Jesse_in_NY
Jesse_in_NY's Avatar
Most awesome! that is an exciting project.....
“Be not like those whose hearts are filled with the fear of death, so that when their time comes they weep and pray for a little more time.” Shawnee Chief Tecumseh
Jesse_in_NY is offline   Reply With Quote
Old 02-20-2015, 04:33 AM   #30
gearhead1951
If the sportster has its own oil pump separate from the timing cover then why not take the oil from that 1st hole and run it thru a proper remote mounted oil filter and then back to the engine via the second hole !
A plate to accomplish this shouldn't be too hard to create !
gearhead1951 is offline   Reply With Quote
Old 02-20-2015, 05:15 PM   #31
Rebuilder
Rebuilder's Avatar
I think the remote oil filter goes in-line in a different part of the oiling system. Probably a few of those lines coming out of the pump that I can't remember where they go.
Old 02-20-2015, 05:18 PM   #32
Rebuilder
Rebuilder's Avatar
Originally Posted by Friday View Post
the other MAGNUM!
cool thread
the other MAGNUM!... I like that.
It probably would have in the beginning but I'm past needing that at this point. I also have an early and a late model XL cover to look at and measure.
Old 02-21-2015, 01:59 PM   #33
Racepres
Racepres's Avatar
FWIW...My XLCH has never had a Filter...certainly Not a Proper one.
I have only ever had Poblems with external filters excepting on O.E. Applications...Hate to see something like a Cheap ass spin on filter affect this project.
I might be Guessing!!!
Old 02-22-2015, 10:38 AM   #34
Samhain
Samhain's Avatar
damn, you're making a sportster look a hell of a lot cooler. Is there no room to make an internal oilway instead of running an external line?
Samhain is offline   Reply With Quote
Old 03-02-2015, 06:16 PM   #35
antiquespeed&machine
We have met at the AMCA meets before, If you need any help with the exposed valve set up, let me know.
antiquespeed&machine is offline   Reply With Quote
Old 03-03-2015, 10:01 AM   #36
Rebuilder
Rebuilder's Avatar
Yeah, your Mag 45 inspired me to give it a try. I've been meaning to contact you to see how yours is holding up. Any problems with rocker tip or push rod tip wear? If I recall you only had grease fittings for the rocker shaft.
Old 03-03-2015, 03:01 PM   #37
mads4
mads4's Avatar
^ Yes, that I would like to know as well. Inspiring stuff, both of you!
Folloving closely.
Mads
mads4 is offline   Reply With Quote
Old 03-03-2015, 03:19 PM   #38
Rebuilder
Rebuilder's Avatar
Last night I machined down the cam 3 hole in the WL cover to match the XL dimensions. All 4 cams and the idler gear fit great now.
My next issue and possibly the biggest one is the pinion ends are totally different.
Here's the XL pinion. It's got a smaller diameter and the threads for the retainer nut are right were the bushing needs to be.
Here's the WL pinion. No threads, shorter and larger diameter.
I'm thinkin' maybe turn the threads off and press a sleeve over the end to make it the correct OD. The WL didn't run a retainer nut so I'm guessing it would work here too as long as the end of the gear is smooth enough to run against the cover bushing.
Anyone have any other ideas?
Old 03-03-2015, 07:07 PM   #39
kickstarts
kickstarts's Avatar
How about an earlier XL pinion shaft? No threads, but I can't say I know the difference in taper or length.
Real tomato ketchup, Eddie?
kickstarts is offline   Reply With Quote
Old 03-03-2015, 09:50 PM   #40
Rebuilder
Rebuilder's Avatar
Here's a '57-76 pinion. Looks like they used a smaller case bearing. It's worth looking into though. Maybe the old case bearing will fit the newer case.... EDIT... Early models had cage bearing, not needle bearings.
