Peening HD Big Twin clutch hub studs - The Jockey Journal Board
Old 03-22-2010, 12:13 AM   #1
Flathead4Ever
Flathead4Ever's Avatar
Default Peening HD Big Twin clutch hub studs
I need to replace a couple of broken clutch hub studs in a big twin clutch hub. Got the old broken ones drilled and pressed out, and I see that V-Twin has replacements. Anybody know a good technique to "peen" the back of the replacement stud securely, once I get it pressed in? Do you heat the stud end at all, or just hit 'em cold?
Flathead4Ever is offline   Reply With Quote
Old 03-22-2010, 12:16 AM   #2
JeffO
JeffO's Avatar
Default Re: Peening HD Big Twin clutch hub studs
https://www.jockeyjournal.com/forum/s...t=clutch+studs
JeffO is offline   Reply With Quote
Old 03-22-2010, 01:01 AM   #3
Flathead4Ever
Thanks. I searched the archive for "peening clutch studs" but missed it.
