50 Pan project.. lots of pics - Page 4 - The Jockey Journal Board
Old 01-21-2009, 07:28 AM   #61
Kuda
Kuda's Avatar
Default Re: 50 Pan ACO bike updates
Originally Posted by sideshow View Post
Nice!! Love that intake, looks like a hot rod sheet metal intake. Nice welds too, what a cool idea. Just to be even nosier, how are you planning on the outboard support for the Linkerts? And fuel lines? That could be a bit tricky...
-Kuda
'49 panchop
Kuda is offline   Reply With Quote
Old 01-21-2009, 07:41 AM   #62
sideshow
sideshow's Avatar
-Kuda
'49 panchop
Probably going to run something up off the engine case bolt thats between the cylinders. If not that then something off the top motor mount. Suggestions?
Fuel lines... I wanted to run two petcocks and two fuel lines, but that whole areas so busy now I think I might run one llike an then split it under the carbs..
Im figuring all this stuff out as I go. Its all new to me. I'm pretty excited about gettin er done.
www.myspace.com/deadelvisrun
sideshow is offline   Reply With Quote
Old 01-21-2009, 08:01 AM   #63
Nottso
Nottso's Avatar
You're just a kid, for Chrissakes. What are you? Mid 20's? Unbelievable skills and vision for a man your age. Damn it, man. Carry on.
Nottso is offline   Reply With Quote
Old 01-21-2009, 08:36 AM   #64
sideshow
sideshow's Avatar
Thanks man I appreciate it. Of course yall dont see the 10 times I fuck it up before I get it right once.
I'm also lucky enough to have some real sharp friends that I can call for help or tech questions.
Last edited by sideshow; 01-21-2009 at 08:38 AM. Reason: id like to thank the academy
Old 01-21-2009, 08:46 AM   #65
Nottso
Nottso's Avatar
At the risk of sounding completely stupid, what is meant by ACO?
Old 01-21-2009, 09:51 AM   #66
Kuda
Kuda's Avatar
Better bet would be to run two independent L shaped brackets using the cylinder base bolts. Advantages: 1) beefer mounting base (larger bolt and more surface area; 2) shorter brackets; 3) ability to remove each carb (and bowl) independently...
I'd stick with one line for sure, split into a Y near the carbs. One option would be to use metal line (steel, not copper) split into a Y, then use a short piece of rubber to each carb. If your skills are up to it, split the line into a Y further back and run steel all the way to each carb. No leaks, less worry about abrasion/heat. Split it further back to give you some wiggle room when pulling only one carb.
One last thing: can't tell from the picture how far back that divider in the intake goes, but if it's not too far (meaning the carb's input isn't differenciated too much), you might consider a progressive linkage for the carbs. Linkerts don't flow *that* much, so you don't really need it, but it could make tuning it a bit easier and increase your mileage a bit...
-Kuda
'49 panchop
Old 01-21-2009, 06:34 PM   #67
sideshow
sideshow's Avatar
Much better idea. Ill probably do that.
I like the idea. I've never done any hard lines before. Ill probably give it a shot once its completely done. I've got so many other things to do that take more time then I have that I dont wanna add it to the "right now" list, but time permitting Ill go for it.
I'm with ya on this one. There actually is no divider in the intake at all and the plan is to run a progressive linkage where im running idle to mid on the small rear carb (m61b) and mid range and up on both carbs - the front one being an larger M74b
Thanks for the info. Always up for new ideas.
Old 01-21-2009, 07:31 PM   #68
sideshow
sideshow's Avatar
The fuggin black tank I was gonna narrow was sealed. Can I strip it somehow so I can still weld on it or..??
Old 01-22-2009, 06:49 PM   #69
hellsheros
hellsheros's Avatar
air craft coating remover you can get it at most parts stores its pretty gnarly stuff.
hellsheros is offline   Reply With Quote
Old 01-27-2009, 09:17 PM   #70
sideshow
sideshow's Avatar
Default Re: 50 Pan project.. lots of pics
I dont know if anyone here ever deals with Rick T in Florida for carbs (ABCGang) on ebay, but he is a damn good guy to deal with. I sent him the other linkert to rebuild after he did my first one. He calls to tell me it arrived yesterday and today I got these pics via email. Hows that for turn around time?
Photobucket
Photobucket
Old 01-27-2009, 10:21 PM   #71
Dragon
Dragon's Avatar
Rick is Sinner1 on here, and he's great to deal with directly too.
Dragon is offline   Reply With Quote
Old 01-28-2009, 10:20 AM   #72
image1's Avatar
nice!
August 4-7, 2016!!!!!!!!!
http://r4yl.blogspot.com/
Old 01-28-2009, 06:24 PM   #73
HD48FL
Super Moderator
That's a beauty of a rebuild!
Old 01-29-2009, 11:38 AM   #74
not45blesk
not45blesk's Avatar
The project looks great.
I dont know about the double Ls though...
I wonder:
- apart from the looks (...) why to Ls in single intake manifold (torbulence issues)?
- what kinda fire you'll have to smoke all that gas ?
cheers
Knot Blesk
3ciprestescycles
http://3ciprestescycles.blogspot.com
http://fatfredtowing.blogspot.com/
not45blesk is offline   Reply With Quote
Old 02-07-2009, 08:49 PM   #75
sideshow
sideshow's Avatar
I wonder:
cheers
its an 84 inch stroker built by truett and osborne. i was told one linkert would not be enough for the motor so I went with two! plus dual carbs are badass. the guy who built the manifold has had experience using them in the past on knuckleheads with good sucess. I aint worried about it other then the ass pain of getting it started the first time.
as for fire Ill be running a morris g5 magneto thats in the mail as we speak. Thanks blackcrown!
p
Old 12-04-2009, 10:22 AM   #76
staccio
looking good super work!
staccio is offline   Reply With Quote
Old 12-04-2009, 11:09 AM   #77
mr haney
you look like a snot nosed kid, where did you get that eye for cool ? ? better be prepared to beat the chicks off you, when that sucker hits the streets ! ! cudos
haney
mr haney is offline   Reply With Quote
Old 12-04-2009, 11:17 AM   #78
mybox
mybox's Avatar
great looking bike
mybox is offline   Reply With Quote
Old 12-04-2009, 12:03 PM   #79
lairdog
lairdog's Avatar
If you want EZ tuning go with S&S E, If you want bad ass (&pain in the ass)
go for the duels! oh yeah...bitchen machine.
lairdog is offline   Reply With Quote
Old 12-04-2009, 03:23 PM   #80
sideshow
sideshow's Avatar
Thanks fellas. I just got back to the states yesterday after a 10 month deployment. Hope I can get crackin and get er done soon.
I'm uploading a pic of how she sits now. Plus a lot of rust and dust from sittin around that is..
