oil filter - to run or not to run - The Jockey Journal Board
Old 09-18-2008, 11:54 AM   #1
sideshow
sideshow's Avatar
Default oil filter - to run or not to run
I'm looking for personal experiences from people who have run without a traditional oil filter. I'm talking about running without your normal run of the mill bike oil filter.. If you ran with a small inline filter or some other idea post your experiences!
I'm trying to make some decisions on what to run on my pan, but id like to hear experiences from as many people as possible first..
www.myspace.com/deadelvisrun
sideshow is offline   Reply With Quote
Old 09-18-2008, 01:25 PM   #2
Creepinogie
Creepinogie's Avatar
Default Re: oil filter - to run or not to run
I've run with and without and recommend to run with one. You can get filters that slip over the return tube inside the oil tank and are hidden. Why would you not want to run one?
Creepinogie is offline   Reply With Quote
Old 09-18-2008, 01:47 PM   #3
sideshow
sideshow's Avatar
Im going to run with SOMETHING.. Just want to get away from the big twist on filter.
Looking at a small inline magnetic filter on the return line and maybe a magnet on the bottom of my oil tank?
looking for something invisible sort of. Any links on the oil filter youre talking about?
Old 09-18-2008, 02:05 PM   #4
Creepinogie
Kiwi Indian sells something made for an Indian oil tank which slips over the return line inside the tank but the same principal can be used for any dry sump oil tank. Personally, I like external filters with some cooling capability. And you'd need to make sure the return tube inside the tank is accesable from the fill cap. Or, do something like the HD square oil tanks and run a filter housed inside the tank. Very similar to KiwiMikes design.
Old 09-18-2008, 02:05 PM   #5
Fredo
I've run both, A while back Trent told me about running the small inline unit. I'm real happy with it. Easy to clean out, looks good, works fine. I do run a magnet type plug in my oil bag for the bigger chunks. You never know when you might want to reclaim that wrist pin keeper!!
Fredo is offline   Reply With Quote
Old 09-18-2008, 02:16 PM   #6
ryangobie
ryangobie's Avatar
anyone have a link to the inline magnetic filter. i had it bookmarked on an old computer and remember it took a good long while for me to find.
-Ryan
ryangobie is offline   Reply With Quote
Old 09-18-2008, 03:05 PM   #7
2_wheel_nation
2_wheel_nation's Avatar
i have an inline from Earls, if you're running a HD you can get the sifton units a little cheaper. you can kinda see it peeking out down there.
i'm an asshole, you probably shouldn't listen to me.
2_wheel_nation is offline   Reply With Quote
Old 09-18-2008, 03:23 PM   #8
blackcrown
blackcrown's Avatar
how would you go about making that work if you've got hard lines?
an intelligent man wins his battles with pointed sticks...I'm sorry, I meant words...pointed words.
http://mrcrownsmotorservice.wordpress.com/
blackcrown is offline   Reply With Quote
Old 09-18-2008, 03:31 PM   #9
=mike=
motorcycle enthusiast
=mike='s Avatar
Send a message via AIM to =mike= Send a message via Yahoo to =mike=
break the line somewhere and add it with 2 pieces of tubing .
My blog . . . mostly-uninteresting
=mike= is offline   Reply With Quote
Old 09-18-2008, 04:18 PM   #10
Coco
Coco's Avatar
Sorry to hijack.
2 wheel, is that your only filter on your Triumph? I still have no idea which way I'm going to go so I am still looking at all of my options. I may go with an oil tank that has the stock Triumph type filter in the tank or your version if I run a tank without a filter bung.
Coco is offline   Reply With Quote
Old 09-18-2008, 11:29 PM   #11
gryer
gryer's Avatar
That's exactly what I'm looking for my ride. Do you know the p/n or description? There are several different types/models.
Que lastima!!
gryer is offline   Reply With Quote
Old 09-19-2008, 07:39 AM   #12
2_wheel_nation
no, it's not the only filter. there's also a screen filter in the sump (it's a preunit) and another screen filter in the oil tank. so i'm triple screen filtered.
i got all the pieces from here: http://www.anplumbing.com/shop/index.php
the filter itself is 230304, and then you need to get -4 AN 'superstock' hose barbs. don't bother with the superstock hose, it won't go on anything but those fittings (trust me, i've tried). the shits a little pricey unfrotunately.
Old 09-19-2008, 09:02 AM   #13
sideshow
sideshow's Avatar
were gettin off track! Lookin for more personal experiences and setups...
Old 09-19-2008, 09:09 AM   #14
2_wheel_nation
my apologies, i'll try not to provide such relevant information in the future.
Old 09-19-2008, 09:12 AM   #15
Bugles
Bugles's Avatar
I was thinking, 'Isn't this as relevant as you can get?' Filter, availability, plumbing...What else are you looking for, other than +1's?
Bugles is offline   Reply With Quote
Old 09-19-2008, 09:50 AM   #16
thesanchez
here's one that comes with barbs, 5/16, 3/8
http://store.summitracing.com/partde...5&autoview=sku
thesanchez is offline   Reply With Quote
Old 09-19-2008, 10:53 AM   #17
Dr. Benway
Mod Squad
Dr. Benway's Avatar
Yeah Josh, stop derailing the thread!
Old 09-19-2008, 11:07 AM   #18
Trent
Atomic Custom
Trent's Avatar
Send a message via Yahoo to Trent
I run inline screen/magnet "pre filters"... and thats ALL I run.
Atomic Trent
Atomic Custom
https://atomiccustom.bigcartel.com
http://instagram.com/atomictrent/
"Custom parts are good only when they're cooler than factory parts. By cooler I mean have better lines, work better, etc."
Trent is offline   Reply With Quote
Old 09-19-2008, 11:49 AM   #19
lowbrowcustoms
lowbrowcustoms's Avatar
MAP Cycle makes a nice universal oil filter kit, check it out here
http://mapcycle.com/itemdesc.asp?ic=MAP6510&eq=&Tp=
Haven't used one yet, I think I will on my next build I am just getting started on, a '61 T100
Cheers
Tyler
lowbrowcustoms is offline   Reply With Quote
Old 09-19-2008, 12:37 PM   #20
sideshow
sideshow's Avatar
Thank you Doctor. Where would we be without you?
