knuck cases tech. how they look? - The Jockey Journal Board
Old 05-24-2008, 02:08 AM   #1
sideshow
sideshow's Avatar
Default knuck cases tech. how they look?
These look like good 47EL cases? No belly numbers since the cases are polished. no way of knowing if the case halves match. They look good to me just wanna ask the experts fore i shell out my whole deployment savings plus some.
Photobucket
Photobucket
Photobucket
www.myspace.com/deadelvisrun
sideshow is offline   Reply With Quote
Old 05-24-2008, 02:17 AM   #2
Dragon
Dragon's Avatar
Default Re: knuck cases tech. how they look?
They look like badly-grenaded re-constructed cases.
The area where the number pad is should NOT be recessed like that, whether that is even the original pad or number is highly doubtable....Also I believe the font should be an open-topped '4', but the experts will be here to correct me soon enough....
Here's you a bunch of samples for comparison - http://vintageamericanmotorcycles.com/v/Numbers/
(and there's no excuse for "polishing away" belly numbers)
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
Dragon is offline   Reply With Quote
Old 05-24-2008, 02:40 AM   #3
HD48FL
I think the vin looks suspect as well. Here is another link to check out: http://www.knucklenutz.com/tech/viewtopic.php?t=1425
And yes, no excuse for polishing away belly numbers. I'd pass if I was you.
Old 05-24-2008, 03:15 AM   #4
sideshow
sideshow's Avatar
fuck man. this is like the 4th motor ive looked at and every one has fucked up numbers
What fuckin gives? whatcha gotta do to get a fuggin motor that aint gonna get taken by the cops? this is queer as hell.
You guys rock. Thanks.
I didnt even notice that shit was recessed. Why would they do that?
Old 05-24-2008, 04:25 AM   #5
HD48FL
There are so many Knuck and Pan motors out there with bad numbers. I'd start by looking for a matched set of cases, meaning both belly numbers match. Keep looking at threads like the ones previously mentioned for number jobs. Also, get yourself a copy of Palmer's book, also previously mentioned here in the past. It's probably recessed because someone wanted to pass them off as something else.
Old 05-24-2008, 04:25 AM   #6
HD48FL
Here:
http://www.amazon.com/Restore-Harley...1617530&sr=8-1
Old 05-24-2008, 04:28 AM   #7
sideshow
sideshow's Avatar
Thanks man. I ordered that book about 5-6 weeks ago it hasnt showed up yet though. Sometimes our mail gets sent to the wrong APO's before it finally gets downrange.. We get it eventually though.
What would having it recessed make it look like? or what could they pass it off as?
Old 05-24-2008, 04:47 AM   #8
BLACK13
BLACK13's Avatar
Junk!.......run Away!
" The Man is at the Window"
BLACK13 is offline   Reply With Quote
Old 05-24-2008, 05:00 AM   #9
HD48FL
I just saw those advertised on George's site, dude wants $5000 with title!
http://www.georgesantiquemotorcyclet.../forsale3.html
Item #127
Old 05-24-2008, 05:03 AM   #10
BLACK13
BLACK13's Avatar
Junk!
Old 05-24-2008, 05:10 AM   #11
HD48FL
Originally Posted by BLACK13 View Post
Junk!
Yep, that's a nightmare!
Old 05-24-2008, 05:11 AM   #12
sideshow
sideshow's Avatar
Item #127
Thats the one.
Back to craigslist!
Still need a bunch of parts so I can build my bike between the time i get back and when i deploy again 5-6 months later. Trying to find what I can now, but it aint workin out real well!
Was hoping to have time to build it when i get back AND have time to ride it. imagine the novelty in that!
Old 05-24-2008, 05:27 AM   #13
HD48FL
[quote=sideshow;336388]Thats the one.
Back to craigslist!
quote]
Try AMCA meets and other swap meets.
Old 05-24-2008, 07:02 AM   #14
sideshow
sideshow's Avatar
I'm open to anything with a clear title and OEM cases. send me the details
Old 05-24-2008, 08:32 AM   #15
DouginGa
The left case is a late Knuckle case, there has been welding on both sides of the vin pad between the ribs & the pad to add material to the case to accomodate the top end oil drains in the panhead cylinders. The pad itself looks ok to me I can't see the # good enough to say if its good or not. Is that 4 closed at the top?, in 47 it should be open, not sure from what I see. I can't see the rightside case good enough in the pic to say if its a knuck case or not.
DouginGa is offline   Reply With Quote
Old 05-25-2008, 03:55 AM   #16
sideshow
sideshow's Avatar
interesting.. so material was added to the sides it wasnt like narrowed or something? You seen stuff like this before?
Old 05-25-2008, 07:51 AM   #17
DouginGa
Yes, I have seen this done before, compare the pics of the modified case & the one Dragon posted, see how the area from the case rib over toward the VIN pad is thicker? & more conforms to the lines of the Pan cylinder. The built up weld is almost level with the inside edge of the case rib on the first case. you can also see that the built up area has been shaped & sanded.
Old 05-25-2008, 09:35 AM   #18
sideshow
sideshow's Avatar
wow. interesting. This is why i llove this place!
the wierd part is - who in the hell is gonna modify 47EL cases to ft pan jugs? seems a bit whacky to me..
