cv 40 carb. - The Jockey Journal Board
Old 05-06-2020, 01:45 PM   #1
longbow
Default cv 40 carb.
I need to rebuild my enrichener or plunger on a cv 40mm carb and cant find a plunger kit anybody know of a place to get it? Thanks Craig
Old 05-06-2020, 05:03 PM   #2
Default Re: cv 40 carb.
you need the choke cable - the spring or the valve
the plastic nut cracks and then the choke wont stay out - that is a cable issue
Old 05-06-2020, 06:43 PM   #3
longbow
the valve
Old 05-20-2020, 07:04 PM   #4
horshak
after you replace the cable be sure to fit the rubber boot on the body of the carb. The carb will run lean without the boot on as it will suck air.
horshak is offline   Reply With Quote
Old 05-21-2020, 07:23 AM   #5
longbow
Thanks Johnjzjz he sent me the plunger.
