ultima 6 speed - The Jockey Journal Board
Old 05-13-2020, 10:55 AM   #1
longbow
Default ultima 6 speed
I bought a ultima 6 speed with kicker it come with belt drive pulley and i want to run a chain final drive the sprocket needs another spacer so the nut will tighten up on it anyone have any info on doing this.thanks craig
Old 05-13-2020, 03:58 PM   #2
Default Re: ultima 6 speed
the seal spacer is different for belt verses the steel sprocket and the belt sprocket is thicker - we have made then on the past but I think they stock them now
the sprockets also come in off sets 1/4 to 1 inch so rear wheel size and location needs to be in its spot before you go buying anything
Old 05-13-2020, 04:28 PM   #3
longbow
ok thanks im working on the rear just waiting on some parts.
