NZ Shovelhead build - Page 5 - The Jockey Journal Board
Old 07-21-2020, 11:39 PM   #81
-BW-
-BW-'s Avatar
Default Re: NZ Shovelhead build
Awesome bike mate, outstanding fabrication work!
I was living in chch when I started my triumph build back in 2009. I moved back up north now, bikes still not finished...
Hopefully get to see your bike in person some time
-BW- is offline   Reply With Quote
Old 07-24-2020, 09:12 PM   #82
Ridgy
Originally Posted by VonWegener View Post
First Kangaroo leather seat I've seen. Wonder what else they make out of kangaroos.
Great seat base and transition from the curved fender area to the flat seat base.
Nice design too.
Kangaroo tail soup is a winner
Ridgy is offline   Reply With Quote
Old 08-03-2020, 11:31 PM   #83
NZT100
Been working my ass off getting this thing ready for paint.
I'm doing all the molding and prep myself to save money and being the first time i've done this it's a steep learning curve, i'm enjoying the process though. My painter friend who works for Glasurit supplied me all the materials and will be doing the base coat, and ill be carrying out the graphics after which hell lay the clear on. So far i'm in about 30 hours in and have the tins/fender/springer molded and into high build primer as well as roughing in the molding on the frame. Pics below are the process so far -
First step was sanding everything with 80g to clean metal, i also had the frame and springer sand blasted as it was far easier than sanding all those curves.
Then came Epoxy primer. I'm lucky enough to have a oven and wet spray setup (we use it for powder coating)at work so i took the opportunity to use that. Cleaned everything with metal prep, warmed it up in the oven, then laid the Epoxy on.
Next was filler work. What ive learned here so far is its better to do many thin layers than one thick layer. I pretty much did 3 rounds of filler and sanding to get it all flat, i used guide coat and blocking to check each time. I sanded it first with 80g, then 150g, and finally with 240g. It all came out spot on.
The lastly i hit it all with 2.5 coats of High Build Epoxy again. All these parts are ready for final sanding in 400g now then its onto the frame which i have since roughed in from the below pic.
Thats it so far. Lots left to do but sure enough its getting there.
NZT100 is offline   Reply With Quote
Old 08-23-2020, 11:40 PM   #84
NZT100
Well about 80 hours later and prep for paint is done. I have a new respect for guys that do this for a living, its tough work! I tell you what, man it feels good to know that's the last major job done!! Chrome is well underway, off to paint in two weeks time....holy shit i can see the light!
Old 08-24-2020, 10:07 AM   #85
Dutch Dennoz
Dutch Dennoz's Avatar
Really a great job , patience is the key word in this stage...we are dying to see the result
If you canít fix it..do it anyway.
Dutch Dennoz is offline   Reply With Quote
Old 09-10-2020, 05:39 PM   #86
NZT100
Got the base coat laid down over the past weekend, then wet sanded with 800g and grey scotched everything back for the flames to be laid down over the next week or so. Have started laying the patterns on as of last night. Its my first time doing any of this so i'm pretty happy how things are turning out so far.
Old 09-10-2020, 07:54 PM   #87
Ratso
Ratso's Avatar
You don't need me to tell you how good that looks, or to say "great job."
That's just too bad, 'cause I already said them.
Thanks for the fresh batch of pics. That bunch and the preceding, molding/sanding pix gave me powerful nose memories. (I hope Bondo still smells as good as it used to.)
Old 09-13-2020, 07:30 PM   #88
MikeJustice55
MikeJustice55's Avatar
Default
Well done. Can’t hide bad body work in black. Good thing you took the extra time to make it flat. It’s lookin nice.
MikeJustice55 is offline   Reply With Quote
Old 09-27-2020, 05:12 PM   #89
NZT100
Well, here's a sneak peak of what went down on the paint so far. Clear goes on in 4 days time then were into re-assembly. Chromes has come in minus a few parts that are being re-done by i have grabbed any photos yet.
I spent the weekend just been repainting the lifter blocks and barrels, cleaning the cases and heads with Aluminum brightener, filled the trans to check for leaks (none), and just generally prepped parts for re-assembly.
All going to plan in 3 weeks time it'll be finished!!
Old 09-27-2020, 06:00 PM   #90
richbob
richbob's Avatar
Default
Top job
I’m waiting for the AC boats to fly around your basin
Old 09-27-2020, 06:12 PM   #91
Medyo Bastos
Great attention to detail!
Sent from my iPhone using Tapatalk
Medyo Bastos is offline   Reply With Quote
Old 10-08-2020, 09:04 PM   #92
NZT100
Paint is done and man i'm stoked how this came out. This was a mammoth task with about 140 hours of my time in it, i am a first timer so probably took longer than it should have. After the black was laid down a 800g wet sanded everything flat and then used 1/8" 3M fine line tape to lay out the flame patterns, then i masked back over and cut everything out all u there was 15 hours of masking in this alone. I did flames on the oil and gas tanks, rear fender, rear springer leg, and the downtubes and legs of the frame.
I went with the blackest black i could get and then a Metallic Champagne Gold with Gold pearl, in the sun the gold has a lot of red/orange that comes through too.
Now for some pics -
Old 10-09-2020, 03:43 AM   #93
magnum45pete
magnum45pete's Avatar
very nicely done fella, good to see care taken to get things right with no short cuts or rust or patina puke,
your going to have one nice Shovel when finished..... well done
by the way, a mate Chris,. in the north island, does the tech inspection of bikes for registration, shout if you need help or pointers on how to pass, he's a long time bike builder himself & isn't an ass about it...
Old 10-09-2020, 10:44 AM   #94
Dutch Dennoz
I like rust and patina , but i realy like the shiny fat paintjob , like if it took a paint bath!
Old 10-10-2020, 08:36 AM   #95
VonWegener
VonWegener's Avatar
Beautiful, just beautiful!
Old 10-10-2020, 08:44 AM   #96
Ratso
Ratso's Avatar
It's excellent from close up. But I think it'll also look so intricate and interesting from forty feet away that bystanders will drop their lunch buckets and come on over for close inspection. Pretty fair work for a first-timer!
"Bite the parts like a monkey." --Dutch Dennoz
Old Yesterday, 10:14 PM   #97
NZT100
Made a good start on assembly over the weekend, am at a dead end for now waiting on my rocker boxes to return from chrome which will be later this week.
So far everything has gone together like butter, taking my time and ensuring everything was right during the fab stage has meant all the parts are fitting up really easily and as planned.
Threw some old bars on it for now while my actual ones are being finished up so i could roll it outside for a pic.
Old Yesterday, 11:20 PM   #98
Dutch Dennoz
Wow , you can be proud
Old Today, 02:04 AM   #99
rhysmort
rhysmort's Avatar
Excellent work mate! i've told you this 25 times, one more won't hurt.
I had the same experience with my knuck. No shimming, no nothing. Just all fell together. Super pleasing to say the least!
King or street sweeper, everbody dances with the grim reaper.
Similar Threads
Nothing Special: '76 Shovelhead build... guitar.romantic The Board 49 04-30-2017 01:22 PM
shovelhead countershaft build up alexml The Board 7 05-28-2016 03:21 PM
Gilera Bobber #3 Project, And my first build for a customer Path Thirteen The Board 17 03-19-2016 09:47 AM
First Shovelhead bobber build up have ??? mdiorio The Board 5 10-22-2013 03:03 AM
1970 Shovelhead Build. MarkWinch The Board 60 02-26-2011 08:39 PM
