Triumph crank repair - The Jockey Journal Board
Old 02-26-2016, 02:20 PM   #1
Dave T
Default Triumph crank repair
I have a T100 Triumph crank with the keyway on the stator end is beat out and cracked. Has anyone tried a repair in this area? I have thought about welding it and remachining it or cutting the end off and making new stub that would thread into the crank. I don't know if drilling and taping the crank would weaken it too much. I don't think welding out on the end of the crank would cause a warpage problem if I don't get carried away with the heat. What kind of rod to use is another question. At this point I have nothing to loose, with out the repair the crank is junk. Any ideas and imput would be helpful. Thanks, Dave T
Dave T is offline   Reply With Quote
Old 02-26-2016, 02:37 PM   #2
beaverbikes
beaverbikes's Avatar
Default Re: Triumph crank repair
Don't know how bad yours is. I've made my own special key before. Clean and square up the slot in the crank using a dremel. Then you get a thicker key and file, file, file. Get it to fit your new slot, then narrow down the top to fit rotor keyway. Incredibly fussy and takes a while. I'm not the only one to have done this, I'm sure I probably read it on one of the forums first, it can work good.
beaverbikes is offline   Reply With Quote
Old 02-26-2016, 02:54 PM   #3
vorhese
vorhese's Avatar
I had Wes' machinist fix my crank keyway when he did the journals. All this thing is really doing is turning a rotor, so it's not too big of a deal.
My projects: 1 | 2 | 3 | 4 | 5
vorhese is offline   Reply With Quote
Old 02-26-2016, 03:04 PM   #4
Luckypabst
Just cut a new keyway 180 degrees out from original.
Edit: this will throw off your timing marks on a later engine so don't forget to re-mark the rotor.
Chris
Luckypabst is offline   Reply With Quote
Old 02-26-2016, 04:10 PM   #5
Dave T
The crank has a crack that comes out of the inboard end of the keyway and about 45 deg. around then all the way out through the threaded end. I'm afraid that if I don't cut all of the crack out the area will be to weak to support the rotor. A custom fit key is a good idea but he crack is the big problem. Same deal if I cut a new keyway, the crack, I think, weakens the stub too much. This is what makes old stuff fun.
Old 02-26-2016, 05:36 PM   #6
bobscogin
You may want to consider another crank.
Bob
bobscogin is offline   Reply With Quote
Old 02-26-2016, 07:35 PM   #7
Dave T
A new crank, only as a last resort. A good idea, but I don't want to admit defeat. I'm used to making junk work. I'll let you all know how it works out.
Thanks for the imput. Dave T
Old 02-26-2016, 10:37 PM   #8
Luckypabst
In my experience, forging alloys like to crack at the weld toe using ER70S-2. I've only kept it crack free with lots of pre- and post-heat. It can be pretty frustrating... And then you'll have time in getting the OD concentric without removing any material beyond the weld, and getting the threads fixed on the ID. Are cranks that hard to find/expensive?
Chris
Old 02-27-2016, 12:10 AM   #9
Chris
Hey Chris ...
if you get bored we still have stuff that needs welding around the shop.
Tony
